Question about Epson Office Equipment & Supplies
The printer keeps telling me that I have a paper Jam. I have turned the printer off and pressed start as directed. The paper will go through when I eject a sheet
Thank you but we have fixed the problem. we uninstalled the printer and started again
Posted on May 22, 2008
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
We have a sp 3250 all in one printer. We had a paper jam. We removed the paper jam and now the printer is telling us that there is still a paper jam. Please tell me what to do next. Thank you.
It is just sensing as if you haven't yet removed the jam. So, while switched on, keep pressing the load or toner or cancel buttons on top. Also make sure you cleared the printing queue that was instructed when the paper jammed.
Dec 04, 2010 | Kodak Esp 3250 Allinone Multifunction ( ...
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
My epson cx3200 says paper jam, I dont see any paper jamed, when i press the button to say ive cleared it,it then runs a sheet of paper through it and says paper jam again, surely if there was a paper jam...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
Paper jam
try to check it again maybe there is a small piece left inside the printer or you can try to restart your computer and turn off your printer then during the restart process practically the BIOS booting start your printer.
Jun 19, 2009 | Canon PIXMA MP470 All-in-One Printer
Printer HP psc 1610 alll in one, the problem keep happening every time I go to print. The printer tells me Paper jam clear and then press ok. I do so and then it keep happening every time I clear even if...
open the back door and roll the rollers in backward direction and then disconnect all the cables like usb and and hold down the power button for 30 sec...and then reconnect the cables..and try shold work..otherwise do a comlete reinstallation.
Nov 25, 2008 | HP Office Equipment & Supplies
Paper Jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
