Question about Sampo PME-42S6 42 in. HD-Ready Plasma Television
Power gets in but does comes on
My TV takes in power but does not come on,. Whenever i try to power the unit I hear a relay clicking but the unit refuse to come on. I manage to see a red LED light on the power PCB coming on after sometime,Please how do i fix this problem?
  • 1 more comment
  • Anonymous Oct 23, 2008
    My power led comes on but the tv wont turn on
  • richiep Nov 07, 2008
    same exact problem. red led, clicking, everything the same
  • IAMKANET1 Dec 04, 2008
    My TV
    i fix this problem?
Got it two. Is it a 42" ?
Posted on Mar 18, 2010
UNIT WILL NOT POWER UP / NO FROUNT LIGHT / NO RELAY CLICK / HAVE CHANGED POWER SUPPLY BOARD ALREADY
if you change power supply then make sure it working check for stby 5 volts and check volts on power switch if voltage are there then power supply may be good. try to disconnect connector or sc board and ss boards. both on side of the tv then turn on the tv it will give you click turn on tv you should hear somr sound if not then your main board is defective if tv come on when disconnect the ss or sc boards then one of them boards are defective
Dec 03, 2011 | Panasonic TH-42PD60U Television
No picture or sound
try first unplugging power cable for 5 minutes
Aug 10, 2008 | Televison & Video
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
Disconnect it from power cable 30 mins, see if this reset works, for the rest sounds like you have a problem with the power unit.
Mar 28, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
JVC Model #: AV-56p575--------problem with power
If this clicking is a continuous clicking sound its likely that its coming from the ballast.The ballast is the component that powers the lamp.If this component fails your lamp wont ignite and wont allow the start up to continue.
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Power light comes on,clicks before picture comes on then shuts of
Yes, it is either that or the "Startup Circuit" is faulty usually it is the associated relay. Thats the clicking sound you hear. When you turn on the TV, the relay is activated along with a timing transistor, the Relay has to make contact within a certain time frame. If the contact is not made during that time frame, the TV shuts down. This is a safety feature in all TV's. If you can get a schematic it will show you where the relay is or, after you unplug the TV and wait 15 minutes, you can take a look inside at the main circuit board, sometimes they mark the area with either "START UP" or "SHUT DOWN" and there you should see a relay.
But a new one usually has to be soldered in.
Mar 26, 2009 | Televison & Video
Startup Problem with my 42pf7321d/37 Phillips plasma TV
I need to know how long do you have the tv?In the other word,approx. how many hours you have put into it?
Secondly,did you wall mounted the tv or setting it close the the area which there is not much room for the back of your tv to breath?
solutiondoct
Nov 06, 2008 | Televison & Video
Hyundai plasma model HP-4200
Hello ****, I have the same problem. However. I manage to get the TV on by pulling the cable out and then plug it back in again several times. A couple of times just after you have heard the first click and the a couple of times just when you hear the second click. Sudenly the TV decided to work again. I think it must be a problem with one of the two relays that sits next to each other near the centre of the TV. If you take the back of and then plug the power back in you will see the two lights next to those relays come on and then die out when the relays let go. This is what hapens if the TV doesnt work. If the TV works those lights/LED's will stay green and the relays will hold on and feeding the TV screen. I will probably try to see if I can buy replacement relays and replace these. If I can get hold of them, then probably I would take the existing relays appart to see if I could see any fault. If those relays ar ok and the replacement relays appear in the same manor like the old ones I would look for problems before those relays. Maby order a new circut board from Samsung.
Con
Jan 08, 2008 | Televison & Video
Sampo PME-42S6 42 in. HD-Ready Plasma Television Logo
124 people viewed this question
Top Sampo Televison & Video Experts
Lyle Siemens
Lyle Siemens
Starnley Johnwells
Starnley Johnwells
Are you a Sampo Televison and Video Expert? Answer questions, earn points and help others
