Question about Konica Minolta bizhub 250 All-In-One Laser Printer
Very slow PDF and large files printing
I have a problem with bizhub 250. When I send a .pdf file to print, it goes very slow - it prints every single page with long time intervals, so it take about 15min to print 30 pages from .pdf. I don't have that kind of problem when printing .doc or other documents. Any sugestions? Thanks
  • 1 more comment
  • nutwing Jun 06, 2008
    Same problem here. Ours takes 60 to 70 minutes to print an 80 page PDF - some photos and graphics in pdf
  • kirandra Jun 12, 2008
    I do have same problem, very slow to print PDF file, firstly I thought it's because SP2 of win XP PRO that just installed then I remove SP2 but same problem still appear.
    Need solution please..
  • Anonymous Jul 09, 2008
    Same problem but for us we were able to get around it by printing say 5 pages at a time. I realize that this is silly for a 60 page doc or more but it was a work around.
Change to print as an image.
Go to print then click on advance and select image.
Posted on Dec 22, 2008
  • 3 Answers
It has nothing to do with your files but with a setting on the copier. Press*utility*user management*number 5 or 6 and make sure to select priority device to printer.
Posted on Jul 10, 2008
This seems to be a common problem for many printers. When printing, try changing your print resolurtion to the lowest possible for the printer - 300 dpi will be fine for text documents. Reduces the size of the file sent to the printer enourmously, and prints faster.
Posted on Dec 01, 2009
  • 167 Answers
It is most likely being caused by complicated elements within the PDF. The fact it is only SOME PDFs indicates this.
You could try sending it to a user box, this way it will download the file and then you can recall it from the panel. This will reduce the amount of time the MFP is offline due to thge slow printing.
Try reducing the file size, if it is colour, convert to B/W and send.
Posted on Jun 09, 2008
Might be worth while -- same problem here with larger size PDF's but if you print them 5 or so pages at a time the problems seems to vanish!
Hope that helps someone out there!
Posted on Jul 09, 2008
Check to make certain that your preferences are not set to convert the document into a bitmap before printing. I actually have to do this when printing to avoid some nasty vertical lines which show up with fonts like Times New Roman, and trust me...3 hours to print a 16 page test of our tabloid sized newspaper just because the alternative is an ugly and unreadable is indeed the proverbial "Rock and a hard place".
Posted on Jul 07, 2008
Using PostScript drivers seems to fix the problem.
Posted on Jun 13, 2008
Offffffffffffffffffffffff it makes me nervous, i cant wait 30 minutes for every paper,
Posted on Jun 12, 2008
Why IR105 slow printing of PDF copies
theres a check box in adobie that says print as image check that and it should speed up your printing tenfold other wise its sending each line increasing the size dramatically
Jun 02, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Print error page Bizhub C351
Google the full error.
this sounds like a font realted postscript error.
Jan 05, 2010 | Konica Minolta bizhub C351 All-In-One...
Time takes WAY too long to print pdf
this machine came with a fairly slow processor and small amount of memory so if the size of the file you are printing is larger than about 1mb it will slow the spool down considerably
Oct 02, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Aug 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Missing lines on PDF from a large TurboCad file
Will TurboCAD allow you to export to a .pdf instead of printing to a .pdf? Have you tried printing to a file (.prn) before turning the file to a .pdf? To print to a file, click Print Setup, there should be a box to check to Print To File. Make sure you check that box. Then you should be asked to pick a file format which should be .prn if you are using windows. After you create the .prn file, then open Acrobat and convert the .prn to a .pdf. I hope this helps you with your problem. Printing can be a pain with CAD programs.
May 07, 2009 | Adobe Acrobat 7.0 Professional
Slow Printing Problem
It sounds like compression has been applied to the PDF.
Are you using the PCL or PS driver?
Is it a 350 or a C350/Fiery. How are you able to see the finsihed size of the file when printed?
If it is a Fiery, try importin g the file directly to identify if it is a software/driver issue.
Jul 02, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Slow printing of large pdfs
Sounds like you are just bogging down the Printer's memory.
Your best option is to upgrade the memory.
May 21, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
15,210 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
