Question about Microsoft Windows Server Standard 2003 for PC
Re-Synching problem with RAID5 Arrays in windows 2003 server
I have some drives in an external array box. When I create a RAID5 array it works fine. But when I move the drives to other slots or another Server computer with the same Docking bay/External Array then windows Server 2003 starts to re-Synch the drives.
If we do this with RAID 0 it works perfectly and can be moved around without any problems. The whole concept of this hardware is to provide mobility for data. I will look at going to a Hardware RAID card.... but if possible I would like to get it working correctly using Software RAID.
    Scholar:
  • 65 Answers
I beleave RAID5 needs all 3 disks to be present and maybe even on the same channels as they where set up for really id depends on the capability of your software or hard card. Good Luck!
Thank you,
Rel
Posted on May 28, 2008
Following arrays have missing required members and cnnot be configured: Array#1-RAID-0
RAID 0 will fail with a single drive loss. So if you lost a drive, you lost the array, and most likely your datas. It should never be used in a production environment, because it can not be rebuilt.
http://www.acnc.com/raidedu/0
Feb 25, 2013 | IBM x3400 Server
Operating system corrupted how to recover the data
RAID is only to protect data in case of hard drive failure. Data is only recoverable from backup.
However, if you have a separate arrays for the OS and data. Meaning two arrays, you can swap arrays onto an identical server with same array configuration. Drive positions (bay /slot) are critical.
Oct 01, 2012 | IBM x3400 Server
I have got a 3 disk raid5 IBM xseries Server which does not boot. How can I resque data from these disks?
I'm going to go out on a limb and assume that you don't have a good backup of the data on your RAID array. So, generally speaking, the operating system is probably installed on a separate disk from your raid array (not a guarantee). But if this is so then you should be able to reinstall your operating system and drivers (esp RAID controller) to that (separate) disk and you're off to the races (replace this system disk if necessary). -OR- Depending on the make of your RAID controller you may be able to transplant your RAID controller into another machine and all the original drives along with it, so long as it has a battery backup and you place all the drives in their original order. If there is no battery backup on your RAID controller then DON'T PULL THE PLUG ON THE ORIGINAL MACHINE AND DON'T EVEN CONSIDER removing the RAID controller in any way. If you have any doubts, whatsoever, have someone with experience in RAID arrays do the work for you. It will be well worth it! (RAID arrays aren't for the faint of heart)...
Aug 24, 2011 | IBM eServer xSeries 225
Hi guies the windows srever 2003 files in my hp ml370 is corrupt and i tried to fix the prblem by format one hard disk partition in my scasi disks array and installing win srv 2003 on it but whe i log on...
HP SmartStart CD x32
The utility to use to set up the ML370 g3 server is the SSCD (smart start cd) this is a guided installation cd that will help you set up the array, install drivers and diagnostic utilities and after that
will request the windows cd so that you can finish the installation.
instructions:
1. download SSCD from here
2. extract the zip file
3. burn the ISO image to a cd
4. boot the server to the cd
5. choose from the main menu the option "Deploy server"
6. follow the wizard
Oct 26, 2010 | HP Compaq ProLiant ML370 G3 Server
I have a Compaq Proliant ml370 G3 with an HP smart array 641 controller that I am trying to load SCO open server 5.0.6 on. This is tied to three drives in a RAID 5 config. When I try to run the Smartstart...
SSCD is not supported for the installation of SCO 5,6,7 or 8 you may need to create the arrays using ORCA at the bios of the 641 controller at post and then install SCO directlly from the installation cd.
To access ORCA press F8 or F9 when the smart array controller is posted at the bios screen
Sep 21, 2010 | HP Compaq ProLiant ML370 G3 Server
Hi. We have a ML110 server with RAID 5 (4x250gb HD SATA) in a Adaptec 2610SA. The RAID has 2 Arrays (#00 Operating System and #01 Data). We have tried to replace a failed HD and since then the Windows...
Did you make sure that your hard drive has been made into a "dynamic volume" instead to the usual "simple volume"? It has to be "dynamic" before your can put it into a RAID configuration. You will have to use your RAID Controller to create a dynamic volume or to make the hard drive part of a dynamic volume.
Aug 04, 2010 | Adaptec 2610SA (0H2052) Serial ATA...
Unable to see RAID 5 config on Asus kfn32-D SLI/SAS MB
NVIDIA RAID does not support > 2TB (18xxGB) arrays. It will NOT show up properly in Windows.
Feb 20, 2009 | ASUS KFN32-D SLI /SAS Motherboard
I have a HP DL 380 server and its configured as domain controler.... and has a raid5 configration .while we are woking it makes a restart and when its restarted windows was unable to boot asking for NTLDLR...
Are you able to get into the array configuration and make sure the logical drive is still intact? If the logical drive is gone, then your partition may be lost. If you are able to recover the logical drive in your array (which you should be able to if the RAID5 striping was stable) then you should be able to recover your data. You can get into the array configuration during the boot up sequence.
Jan 06, 2009 | HP Compaq ProLiant DL380 G4 Server
Problem with new array.
Do you see your new disk in the "Disk Management" window? To get there go to "run", type "compmgmt.msc", then click disk management. If you do see the disks there, then you need to format the disk to a "basic" configuration. If your new disk/volume does not show up there, I would suggest a hard reset on your server whenever possible. I see this issue at times with Windows and newly added storage array logical drives.
Aug 31, 2007 | IBM Total Storage DS400 (13n1777) Fibre...
Microsoft Windows Server Standard 2003 for PC Logo
356 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
