Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Changing bushes on a hotpoint wd63
My washer would not go round, got stuck in a cycle, the bushes have been removed and they are much worn down. we have bought more which cost £30 but my husband is having trouble getting the bottom bush screws in the holes as you can not see where they go as it is under the motor and the motor is even worse to take off, any solutions how to do this?
  • steverodo Jul 28, 2008
    I cannot get the motor off it's housing.
    Guru:
  • 859 Answers
There is a screwdriver that you may need to buy that has a retainer on it to hold the screw in place while you attempt to seat it in the hole. Here in the States we call the place to buy one of these the Hardware Store. There must be a store where you can explain the tool you need based upon my description.
After you replace the bushes for the machine you will want to replace the bushes for the motor as well. So, the motor will have to come off now or sooner than you realize. When one goes the other is soon to follow. So, while you have everything apart and are in the midst of it all you may as well do the motor while your at it.
I also assume you were able to manually move the machine and it is not seized by frozen bushings or bearings.
Hope this helped and fixed ya.
Worldvet
Posted on May 21, 2008
My washer is stuck on a wash cycle the washer is full of water its not emptied
I'm in a rush, but it sounds like your drain pump is clogged or bad .might also your door lock.
Mar 14, 2013 | Hotpoint Aquarius WD63 Front Load...
Fills with water,but does not continue with cycle,ie does not rotate,thank you for your help.
Try a new motor brush kit its often the case its worn.........Cost around £18 parts Simple to fit ,take care when fitting as they can get easy broken...........
Feb 10, 2011 | Hotpoint Aquarius WD63 Front Load...
Could you please tell me where i can find the filters on the hotpoint aquarius extra WD63? Thank you
Remove rear panel completely from washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
Spin cycle not draining
Hi-ya Brian
Probably blocked filter.
To locate and clean, remove rear panel altogether, locate large black hose at bottom of drum, remove from drum, and you will find the filter located inside the hose.
Check drain hose is not blocked also.
Thanks.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Door wont open on my hotpoint aquarius washer/dryer
Turn the dryer dial to off, making sure you can hear it click off, wait 1 min, and then try door. If it will still not open then you may have faulty door lock, or a prob with the door handle.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD63 Random Fault
if the drum will not turn it may be the motor brushes
Sep 30, 2008 | Hotpoint Aquarius WD63 Front Load...
My hotpoint washer is stopping mid cycle if i dont pump the water out it floods it will only work on thr h cycle
I WOULD HAVE THE PRESSURE SWITCH CHANGED OR CHECK THE SMALL TUBE GOING FROM THE PRESSURE SWITCH TO THE DRUM AS IT MAY BE CHOKE WITH WASHING POWER AT THE DRUM
Jul 15, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
136 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
