Question about Toshiba Satellite M45-S331 Notebook
Wireless does not show up in Network Connections
For some reason, my wireless does not show up in network connections. Even the antenna switch in the front of the laptop, if set in the ON position, does not light up, saying that the wireless in on. I went to the Toshiba support site and DLed all the drivers for WiFi and installed them, but it still does not work. Any ideas?
  • sahaja May 21, 2008
    I should also mention this is the first time I have had this problem in three years of owning the laptop and the only thing that changed from it working this morning to not working now is that I uninstalled the driver for my keyboard
  • ocxcardinal5 Jul 09, 2008
    I've have the same problem. I tried using the recovery disk. Everything was deleted and reinstalled except the wireless light still doesn't come on and wireless is not listed in the network connections. What now?
I had this same problem sometime ago and I first reversed my last action and I still did not get back my wireles. So out of desperation I backed up my files and made use of the recovery disk that came with my laptop, Although I had to wait through the process of deleting the contents of my computer first, after the operating system was reinstalled, to my suprise my wireless connection was initialised and it started working. All I had to do after that`was to point it to the right wireless network to work with. I hope this solves your problem Sahaja.
antelopexes
Posted on Jun 05, 2008
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
HOW DO I TURN ON THE WIRELESS ON MY TOBISHA LAPTOP
If you're using a Toshiba laptop and you can't figure out how to enable WiFi you probably aren't alone. Thankfully there are several approaches you can take from a hardware and Windows Operating System stance to turn on your wireless connection while making sure you can properly connect to a wireless network.
Difficulty: Easy Instructions
      Look at the keyboard options on your laptop. You should see a button that looks like a small antenna. The button placement may vary from device to device. For instance, you may have a dedicated button or it may be placed much like the option circled in the picture to the left of this step.
    • 2
      Click on the "Windows Start Button" and Navigate to "Control Panel" then click on "Network Connections" or "Network and Sharing" depending on your version of Windows.
    • 3
      Right-click on your wireless connection icon once the "Network Connections" window opens. Choose "Enable" and left-click on that option with your mouse. Wait for the wireless connection to enable.
    • 4
      Alternatively you can try clicking on the " Windows Start Button" and then clicking on "Connect to," where you will click on "Show all connections." When the connection window opens up, you should right-click on "Wireless Network Connection" and then choose "Enable." Now right-click on "Wireless network connections" and then choose "View Available Wireless Networks" to see if your WiFi adapter is enabled.
Hope this was helpfull
Mar 10, 2011 | Computers & Internet
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
How to get hp wireless assistance
If you need to find the Wireless Utility to scan for available networks, it should be in Start > Programs under HP Wireless
If you need to turn your wireless adapter on:
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections
Click window opens. Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | HP Computers & Internet
Cant get wireless internet to work
May 28, 2008 | Computers & Internet
Wireless not functioning
HI there,
Check the hardware. Most network problems stem from improper software and hardware settings, but occasionally hardware failures are responsible. If a shared Internet connection seems to be down, try to watch a cable television channel if you have a cable modem or use the phone if you have DSL (Digital Subscriber Line) to see if the entire service is down. If it is, contact your ISP to see if there is a problem in your area. Check all cable connections and consider replacing Ethernet cables if the problem seems to be confined to a particular computer or device.
Click on the HERE..
Thank you & post back how things get done..
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Did you try - after switching on the "antenna switch" or WiFi hardware - to "Enable" the WiFi adapter, under (XP) Start - Settings - Network Connections - LAN or High-Speed Internet - Wireless Network Connection? (select, right click and select Enable)?
p.s. Once your WiFi hardware is recognized (by Win XP) there is (should be) always a "Wireless Network Connection" in your Network Connections, enabled or disabled, active or not.
Trying to connect to the internet wirelessly
is it detecting in the device manger if it detects in the device manager it show in the network connections . i think there is a switch for wireless enable or disable on the laptop
Mar 24, 2008 | Fujitsu LifeBook S6231 Notebook
Wireless network card in PC loses connection
The best reccomendation I might make is to stop using the manufacturer's proprietary management software. Use Windows' own built in wireless management. You can select this by selecting the network adapter in the 'network connections' control panel and checking the box that says 'let windows manage this device' That should fix the problem. Also, try getting the most recent updates for both windows and the network adapter.
Nov 09, 2007 | Computers & Internet
Toshiba Satellite M45-S331 Notebook Logo
157 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
