Question about Toshiba Satellite M45-S331 Notebook
Wireless does not show up in Network Connections
For some reason, my wireless does not show up in network connections. Even the antenna switch in the front of the laptop, if set in the ON position, does not light up, saying that the wireless in on. I went to the Toshiba support site and DLed all the drivers for WiFi and installed them, but it still does not work. Any ideas?
  • 2 more comments
  • sahaja May 21, 2008
    The hardware is not recognized by my computer I think, b/c even when i turn the toggle switch to the ON position, the Led indicating that it is on does not light up, and there is nothing appearing in network connections window
    The net adaptor does appear in Device manager, and it is enabled and says it is working properly, I used the driver disc and reinstalled all drivers from the webstite - I have the Atheros wireless LAN one. I also tried to do a system restore to yesterday because it was working this morning and now it is not. What happened in between is that my keyboard went haywire and started typing LLLLLs and wouldn't stop and therefore started opening and closing windows...Since it was just the keyboard (it hasnt worked in a while, nothing new happened) I uninstalled the keyboard driver so it wouldnt function at all. I think that or the keyboard craziness somehow either corrupted or uninstalled my wireless hardware. ..
  • Anonymous Sep 14, 2008
    wow, i have the same problem, it just doesn't show up with the switch switched on or off.. soooooo frustrating!!!! i dont know what to do but i tried windows hardware updates and i downloaded all the drivers from toshiba's website and installed them several times... NO DICE! :( this really sucks cause i dont wanna have a bulky network card sticking out of the side..
    eltareb@gmail.com
  • Anonymous Feb 04, 2009
    K My LED shows that the card is recieving power but no connection, it doesnt even show up in the list of unidentified hardware PLEASE HEPL I HATE PLUGGING THIS THING IN!!
Did you try - after switching on the "antenna switch" or WiFi hardware - to "Enable" the WiFi adapter, under (XP) Start - Settings - Network Connections - LAN or High-Speed Internet - Wireless Network Connection? (select, right click and select Enable)?
p.s. Once your WiFi hardware is recognized (by Win XP) there is (should be) always a "Wireless Network Connection" in your Network Connections, enabled or disabled, active or not.
Posted on May 21, 2008
2 Suggested Answers
SOURCE: Wireless does not show up in Network Connections
I had this same problem sometime ago and I first reversed my last action and I still did not get back my wireles. So out of desperation I backed up my files and made use of the recovery disk that came with my laptop, Although I had to wait through the process of deleting the contents of my computer first, after the operating system was reinstalled, to my suprise my wireless connection was initialised and it started working. All I had to do after that`was to point it to the right wireless network to work with. I hope this solves your problem Sahaja.
antelopexes
Posted on Jun 05, 2008
How to load Integrated Wireless LAN on my toshiba satellite a45-s1202
If your Toshiba Satellite notebook computer is equipped with a wireless Internet card, you can connect to a Wi-Fi access point by turning on the wireless switch on the side of the laptop. However, the signal may not always be picked up by your wireless receiver; if that is the case, you will need to check your wireless-network settings and reconfigure the network connections manually.
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 03, 2013 | Toshiba Satellite A45-S1202 Notebook
HOW DO I TURN ON THE WIRELESS ON MY TOBISHA LAPTOP
If you're using a Toshiba laptop and you can't figure out how to enable WiFi you probably aren't alone. Thankfully there are several approaches you can take from a hardware and Windows Operating System stance to turn on your wireless connection while making sure you can properly connect to a wireless network.
Difficulty: Easy Instructions
      Look at the keyboard options on your laptop. You should see a button that looks like a small antenna. The button placement may vary from device to device. For instance, you may have a dedicated button or it may be placed much like the option circled in the picture to the left of this step.
    • 2
      Click on the "Windows Start Button" and Navigate to "Control Panel" then click on "Network Connections" or "Network and Sharing" depending on your version of Windows.
    • 3
      Right-click on your wireless connection icon once the "Network Connections" window opens. Choose "Enable" and left-click on that option with your mouse. Wait for the wireless connection to enable.
    • 4
      Alternatively you can try clicking on the " Windows Start Button" and then clicking on "Connect to," where you will click on "Show all connections." When the connection window opens up, you should right-click on "Wireless Network Connection" and then choose "Enable." Now right-click on "Wireless network connections" and then choose "View Available Wireless Networks" to see if your WiFi adapter is enabled.
Hope this was helpfull
Mar 10, 2011 | Computers & Internet
I keep losing the internet signal and going offline. LAN indicates pending??? How do I perform a system reset with Linux??
Power cycle the system by shutting it down and switching it on after at least thirty seconds. Check network settings to verify the IP address and other related information. Determine if the network card is working adequately. Identify the malfunctioning adapter by disabling the cards one by one. Move one of the portable hosts--such as a laptop--closer to the router. If it works better, interference or low signal strength is the reason for poor Internet access. Inadequate signal performance can be caused by several factors including cordless devices working within the frequency range (2.4 GHz) of a wireless network, shiny surfaces and too much distance between hosts and access points. Resolve this issue by using a wireless repeater?a device that amplifies wireless signal so it reaches distant areas within the premises. Minimize signal interference by maintaining a distance of at least one meter between cordless devices and the router. Alternatively, buy gadgets that function at frequencies other than 2.4 GHz. Try changing the WiFi channel for better results. Check the functioning of wireless router and access points. Adjust the router antenna to get an optimum signal. Most wireless routers come with omni-directional antennae to send signals in all directions, a situation appropriate for a square-shaped network. If hosts are arranged in a linear fashion, use an antenna that sends signals only in one direction. Some portable routers have internal antenna, giving more freedom to users who are on the go. Use an external antenna with such routers. The market now offers antennae with varying strengths, implying some are more powerful than others. See if using a more powerful antenna fixes the problem. Aside from increasing the range of transmitted signals, the reception capacity of hosts can also be enhanced. External WiFi-enabled antennae attached to laptops are now available for this purpose. Change the location of the router and access point. They should ideally be placed centrally between all computers. As the signal bounces off smooth and shiny surfaces, routers and access points should be placed away from windows, doors, mirrors and other metallic surfaces. Examine signal performance by using the monitoring utility that typically comes with the access point. Check that the devices show correct lights. Device lights are an indicator of accurate connections. Different lighting patterns indicate different things. For example, some network cards show green light on successfully establishing a connection. Similarly, the router's wireless LAN (WLAN) light is turned on at all times, even if no device is connected to it. Further, this light blinks when a host communicates with another host. Unexpected lighting indicates a problem. Go through user manuals to get familiar with this feature and make sure the devices show desired lighting behavior. Use wireless Internet utilities to check the SSIDs and channels neighboring wireless networks are using. Change your network's SSID and/or channel if they are the same as that of other networks in the vicinity. See if correct drivers have been installed. Check configuration settings for encryption keys.
Sep 24, 2009 | ASUS Eee PC 2G Surf Notebook
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Help
First, check to see if there is a button on the keyboard that looks like an antenna. It usually has a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 28, 2008 | Computers & Internet
Laptop Idiot
May 27, 2008 | Computers & Internet
Wireless not functioning
reinstall it clean or reinstall wireless drivers..after that just unplug the router and let it reconfigure ..this will get the wireless network in sight again ..sometimes it just stops transmitting or makes issues like that ..but if the wireless card is fine ..than all it may be wrong is the router ..In worse case just reset the router and configure it again .. but I think it will be enoug to unplug it for 30 seconds..
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
HI there,
Check the hardware. Most network problems stem from improper software and hardware settings, but occasionally hardware failures are responsible. If a shared Internet connection seems to be down, try to watch a cable television channel if you have a cable modem or use the phone if you have DSL (Digital Subscriber Line) to see if the entire service is down. If it is, contact your ISP to see if there is a problem in your area. Check all cable connections and consider replacing Ethernet cables if the problem seems to be confined to a particular computer or device.
Click on the HERE..
Thank you & post back how things get done..
antelopexes
Trying to connect to the internet wirelessly
is it detecting in the device manger if it detects in the device manager it show in the network connections . i think there is a switch for wireless enable or disable on the laptop
Mar 24, 2008 | Fujitsu LifeBook S6231 Notebook
Toshiba Satellite M45-S331 Notebook Logo
2,638 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
