Question about Dell Wireless 2350 Router
Disconnection problems Hi! I have this router and I have a problem that has become worse. I have vista and i connect to the router wireless and in the network sharing center or what its called i can see my connection to the router and if im connected to the internet, but sometimes it disconnects from the router and have problems to find the router again. but sometimes it just disconnects from the internet but im still connected to the router and sometimes i can do a diognostic and reset the network and it works again, but often I have to go and turn off the router for 10min or so to connect again. this problem has become worse and worse and will disconnect more often..
  • 4 more comments
  • one2be May 21, 2008
    I have tried without any wireless things around.
    1. its a dell 2350 router
    2. it is a dell inspiron 9300 laptop
    3. it works fine with other wireless networks
    if i reset the router it will work for a moment but then later it disconnects again... and i have to shut i down or reset it to make it work again :(
  • one2be May 23, 2008
    The problem is that the router has already the newest firmware, I checked that before.. and the second problem is, now its worse then before.. i cant connect to the router at all, not even with a cable... It connects to the network as a unidentifyed network and i cant connect to my router via 192.168.2.1 like i used to, and your http://my.router didnt help. tried pushing the resetbutton on the back but nothing happens... the lights still blink as it should... can it break like this one small step at the time? is it time to buy a new? is it possible to make a full reset of the router so all settings (lika username and password and all other stuff)?
    the channel i used before this all happend (and have used for over a year) is channel 7, does that matter?
    I read something about problems with using torrents that could make the router mad, but if this is so, shouldnt it work after a reset? but how do I reset this router? because when i reset i with the reset on the back nothing changes? shouldnt the user and pass change back to standard?
    hm.. what setup wizard? im not sure I follow...
    Im going to test if I can connect to the router again tomorrow, but if I can connect to the web based utility, is there a option to reset the router from that and if so, do you know where it is / under what menu?
    thanks for the help!
  • one2be May 26, 2008
    Hi again! I tried to have the router out of power for a few days and then reseted the router with the switch on the back, now its back to login/pass admin. so it worked, and it works with the cabel, but still when i use the wireless connection it say unidentifyed connection and gets no connection to the internet... does this help anyway in the problemsolving? :)
    damn routers, cant they just work :P
  • Ella Grace Leynes
    Ella Grace Leynes May 11, 2010
    You can check for wireless interference in the area. Move the wireless devices away from Microwave ovens, cordless phones that run 2.4 GHZ and other wireless devices that may intervene with the connection. To further isolate the concern, may I know the following information:
    1. brand and model of the router
    2. is the computer a desktop or a laptop? Does it have an internal or external wireless adapter?
    3. Does the wireless adapter connect fine to other wireless networks?
    Scholar:
  • 70 Answers
I see. You can try changing the wireless settings of the router. You can do that by accessing the web based utility of the router. Here are the instructions:
1. Click the Start button, and then click Run.
2. Type the following text in the Open box: http://my.router
3. If this is the first time configuring your Dell Wireless 2350 Broadband Router, or if the user name and password have not been changed from the default settings, type admin in the User Name field and admin in the Password field.
4. Click the OK button. The Configuration screen appears.
5. Under the Basic settings, under Wireless Settings change the channel from Auto to 1, 6, or 11.
If that does not work, you can try updating the firmware of the router. You can download the firmware from this site:
http://www.dell-drivers.com/dell-drivers-downloads/Dell-Wireless-2350-Broadband-Router_8689.shtml
Here are the instructions on how to upgrade:
1. Reaccess the configuration page of the router using a wired computer.
2. Click on System Tools, find Firmware Upgrade.
3. Click Browse and search for the firmware you downloaded from the site I gave you earlier. Select it and then start the upgrade. Let the firmware finish its upgrade.
Posted on May 23, 2008
  • Ella Grace Leynes
    Ella Grace Leynes May 23, 2008
    Yes it should. If the reset at the back does not change, there is a possibility that the router is already defective. If the web based utility does not work, have you tried using the setup wizard instead?
  • Ella Grace Leynes
    Ella Grace Leynes May 30, 2008
    you can try to change the wireless settings of the router. Make sure that the network name is unique and that the channel is either 1, 6 or 11 for better coverage
I have problems WLAN on my DIR-855
You might have a lot of neighbours using wifi, you get interference. Download "Inssider" and scan your area, usually this type of problem means several people on the same channel of wifi. to change your channel, log into your router (type 192.168.1.1 or 192.168.2.1 into internet explorer. then change the channel settings.
Mar 21, 2010 | D-Link DIR-855 Wireless Router
Wifi disconnect on vista business
Try resetting your wireless router frm the reset button on your router....After that goto -control panel-network connections-right click on wireless connection-click on repair
May 02, 2009 | Microsoft Windows Vista Business DVD...
Windows Vista Ultimate: Internet connectivity
Make sure your IPv4 settings property is set to AutoObtain the IP address under the Network properties for the wireless card
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Error when connecting usb wireless adapter
hi there, windows vista, as we all know is more focused on to the security... but it becomes very difficult if it detects other devices as an error...
With vista you can try to run the installation CD for the router, so that the vista knows that there is a driver for that router, without that it will not recognize the router and will keep detecting as an error...
was i helpful?
for more help log on to http://primustel.blogspot.com
Nov 18, 2008 | Computers & Internet
Wireless connection of netgear wireless router for compaq laptop
When you look on the box that the router came in, you have to look to see what Operating Systems it is compatible with. In many cases, routers will not be compatible with vista. I have a Linksys WRT300N, and it works great with Vista.Hope this helps.
May 04, 2008 | NetGear WGR614 Wireless Router
Frequent disconnects
If the Xbox is connected wirelessly through a computer
ie. Bridge?
Then the problem would be with Windows XP, the Operating system scans every 2min's or so for new networks and at this point you will notice a "lag" or disconnect if it is bad enough.
XP: your going to have to turn off the Wireless service via msconfig.
Vista: Download WLAN Optimizer, easy fix there...
Apr 30, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Windows Vista and Dell Wireless 2350
Try updating the driver for your wireless adapter.
Jan 22, 2008 | Dell Wireless 2350 Router
Netgear DG834G router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Dell Wireless 2350 Router Logo
178 people viewed this question
Alun Cox
