Question about HP Color LaserJet 2600n Printer
Faint printing Hello My hp laserjet 2600 demo page is suddenly showing faint quality prints (u can see above)....any idea whay is this happening....my cartridges are almost full....when i put the same cartridges in another printer, it works pretty well......please help me out here regards Raj
  • Sniper7 May 22, 2008
    no mate i've actually tried restoring factory default on this printer
  • 3 Answers
Indeed, the problem here is dust building up on the scanner mirrors. The mirrors are hidden deep inside the printer, but if you have an hour to kill, you can disassemble the printer, clean them off carefully, and solve the problem. See the very detailed PDF disassembly guide at http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1221679079368+28353475&threadId=1182873 . Solved all my problems.
Posted on Sep 26, 2009
    Scholar:
  • 87 Answers
Have u used this printer quite a bit....? if so the following may be the problem and I just did run across this recently in a printer we had in the shop....I recently read in one of my technical magazines that there may be a design flaw in the placement of the laser scanners and the openings that protect them....it seems that excess toner dust can readily get in to scanner area and specifically inside the scanner assembly and accumalate on the scanner glass and lens. Just cleaning through the opening in the back of the printer will not eliminate the issue. Machine will have to be disassembled, scanner removed and opened and the glass/lens cleaned with a q-tip....the placement of the fan (behind cartridges, lower right) seems to speed this process up and it usually becomes first notable with the magenta cartridge, seeing as it is at the bottom of the printer closest to the fan. Hope this helps..
Inkworks
Posted on May 22, 2008
  • 138 Answers
You have adjusted your print out settings too dark. ..judging from your samples
Posted on May 21, 2008
HP LaserJet 3030 Printing comes out light but copies are fine.
Have you calibrated your printer after changing ink cartridges?
Mar 19, 2014 | HP LaserJet 3030 All-in-One
Ink is faint
two possiblities
1)not enough ink for the saturation of the media
2) media is not correctly saturated by the ink
sounds like the same issue- let me explain
your image may be purposely printed light because of 'ink save printing'( driver cuts down reqired ink levels to give a draft print.)
or your problem may lie with the paper type itself,
firstly have the machine print off its internal demo page ( read user manual to find how to print)
this print being held by the printer cannot be affected by external controllers, if the demo page looks nice aand even and strong in colour then your issue is software related and you should have a look at how the pc is handling these documents before they get to the printer.
if the demo image is light then you have a problem inside the printer
if it is the latter please re-post as internal demo page printing light in colour
Mar 16, 2014 | HP Officejet 4622 Multifunction Inkjet...
Two faint white horizontal lines
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
Jan 09, 2014 | HP LaserJet 1000 Printer
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
Hp laserjet 4200 printer printing vertcal faint line
Check the cartridge and make sure that there is no scratch on any of the cylinder. If any cylinder is scratched you will need to replace it. Perform a cleaning with isopropylalcohol in these cylinders if they are not dirty and test the printer. If the problem persists, probably the fuser film is damaged and will need to replace it. If the line still continues to appear, the laser scanner may be dirty or damaged. Try to clean it or replace it.
Apr 11, 2012 | HP Office Equipment & Supplies
I have refilled my HP LaserJet M1132 MFP toner and the print quality does not look good. It is very faint and if I try to increase the contrast, it is not readable. Please advice.
Nov 19, 2010 | Office Equipment & Supplies
Dear Sir, i have buy hp laser jet p1007 printer but it gives no quality. it gives faint print and when i give pdf file print command it give very faint print so what can i do. Thats the faint...
Hello and Welcome to FixYa!
Hmm, faint printout may occur due to so many issues, like paper quality, bad connection, bad/dirty pick-up roller, wrong settings...
To counter all these issues, writing all the text here will be difficult and will decrease the understanding quotient. So I'm attaching a link below, where you will find all the possible solutions with pictorial / graphical representations, I hope you will find it helpful and will definitely come up with some solution.
In Case you are having any issues/questions, do ask me. I'm here to help.
If you think I was of help, your token of appreciation in the form of rating will be esteemed.
Concerned, Nooh
P.S: Resolving Print quality issues
Aug 09, 2010 | HP LASERJET P1006 Printer
Poor print quality on hp 1312
Hello Terry there are few things i would check :
1) Try printing a demo page directly from the printer, go to Setup>Reports>Demo Page
If you see the poor quality on this internal page that means that the issue could be related to hardware failure. Laser scanner assembly most of the times
2) Check on the toner level for the cartridges by printing a supply status report
3) If the problem is not on the demo page i would try replacing the printer driver for a Post Script Driver, you can download them from www.hp.com
4) You can Adjust the Print Quality by going to Printer Preferences under the driver
Jun 24, 2010 | HP Laserjet CM 1312NFI Color Printer
Refilled my #21 cartridge, poor or quality or nothing is printed.
You have an air bubble between your print head and ink supply. This is something that commonly happens when you hand fill these cartridges. These cartridges need to be filled under vacuum to prevent this from happening. I recommend refills from Cartridge World because they have good prices with a 100% satisfaction guarantee.
Jun 17, 2009 | HP LaserJet Q2612A Printer
HP Laserjet 2420dn - Faint ghosting of printed matter above & below actual print. Have tried cleaning page twice but no better Grateful for any suggestions
  • Please perform a half page test, by printing a test page from tray 1.
  • Open the top cover as soon as the paper is 70% through from tray 1 so that the media
  • Check if the ghosting appears, if yes, fuser needs swap out.
Oct 30, 2008 | HP Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
322 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
