MODEM PROBLEM I HAVE TOSHIBA MODEL TECRA S1 FOR THIS MACHINE MODEM NOT WORKING MESSAGE WHEN I DAIL MESSAGE RECEIVE MODEM IS CONFLICT OR POEN PORT
    Genius:
  • 2,785 Answers
Which operating system you are using
Posted on May 21, 2008
My toshiba tecra S1 is showing blank screen after cleaning the motherboard and switching it on
check the cpu sometime the lock is not closed enough ,,, and check the rams did replace them will ? ,,, check the cable connecting the monitor to the motherboard ...
Mar 08, 2012 | Toshiba Tecra S1 Notebook
While switching to "standby" mode,
I would browse www.toshiba.com and download updated drivers and firmware. It is a very well laid out site and easy to use.
Hope that helps.
Feb 22, 2011 | Toshiba Tecra A5-S416 Notebook
My Toshiba Tecra S1 Laptop has lines up and
hello,
the flex of your is either getting weak or it has shifted from its original location.. the flex is what connects the screen to the panel of the laptop and when it has a problem you experience lines on your screen..
what you should do is to open up your laptop and try to set the flex to its normal position and see if it stops the lines on your scree, if it doesn't then you have to change the flex
if you cant open your laptop,get someone with experience to help you
goodluckk
Feb 18, 2010 | Toshiba Tecra S1 Laptop Notebook
Toshiba Tecra S1. My laptop has power but will
It has a memory problem, take the laptop to your local store and ask if they will test the memory for you, if it is the problem then you will have to purchase a new memoy module.
Jan 29, 2010 | Toshiba Tecra S1 Laptop Notebook
VGA problem
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 24, 2009 | Toshiba Tecra S1 Notebook
I have a problem on my Toshiba Tecra S1 Laptop, Suddenly it stopes working, The main problem is the power indicator front lamp showed the electricity is plugging and the machine also turned on while their...
check your inveter in screen or vga cable maybe los only,.. if the power indicator is working and if you turn on the uit is working but no desplay.. check first the inverter.. if the inverter not problem it means need to open you pc and check the board...
if this underwarranty bring to warranty..
Jun 05, 2009 | Toshiba Tecra S1 Notebook
Cant install windows XP on my Toshiba Tecra S1 laptop.
Where did you get your disk from? It sounds like you may have a bad install disk?
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
How to get driver vga
Here is the link to the driver
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modSel.jsp
seach for your driver these, all you need is the laptop model to find it..
or
www.drivermagician.com thiss will detect and install the drivers for you.
Jul 23, 2008 | Toshiba Tecra S1 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
