Question about Samsung YH-925GS MP3 Player
Still no luck
I'm reading the manual link you provided but I still can't get my computer to recognize the device
  • 242 Answers
What have you tried?
Have you looked in the device manager as explained in the manual?
Is the mp3 listed there under Disk Drives and/or Universal Bus Controller? If not, is there a device listed with a question/exclamation mark?
Think we should go step by step through this, as there are several possible reasons for your problem.
Posted on May 21, 2008
  • Thx_nb May 21, 2008
    Think you got that right, but just to make sure..., you have the charger plugged into a power outlet, when connecting?
    This question is continued here
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
Nov 14, 2013 | Acer Aspire Computers & Internet
Verbatim store n go usb flash drive 8 gb device not recognized
My Verbatim Sto N Go 8GB USB Flash Drive does not work in any port, in any computer. When I plug it in, the "Device is not recognized" error comes up. When I click on it, and the Unknown Device Properties comes up, the device status reads: "Currently, this hardware device is not connected to the computer. (Code 45)
To fix this problem, reconnect this hardware device to the computer."
The driver details read:
Provider: Advanced Micro Devices
File Version: 1.0.11.82 built by: WinDDK
Digital Signer: Microsoft Windows Hardware Compatibility
This is the 2nd drive of this same brand that quit working within 6 months. I have MONTHS of work on files in this drive, and would hate to have to redo all that work! I was real careful after the first one went bad to use the eject button when removing it from my computer. But I am thinking the last time I clicked the eject button, it froze, so I just pulled it out without the message coming up. Hopefully there is someway to get the computer to recognize this drive again???
Sep 26, 2012 | Verbatim ® Store `n` Go USB Flash Drive,...
Acer aspire 7741z optical drive not reading
Try Using a cleaning disc in the drive. If still not working, drive broken, replace.
Sep 05, 2012 | Acer Aspire 7741z
Either software or device issues? The software doesnt recognize the device!
Here's a lil tip 4 u...not all softwares work properly in a computer even if its installed/downloaded properly with the instructor's manual
try returning it back with your insurance guiding it then get a new one and try it again...good luck
Dec 28, 2011 | Vtech V.reader Reading System
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
I installed a Belkin broadcast router and my computer won't hook up to internet. My other computers (like the one I'm relaying this message) does fine. Downloaded D-link 520 drivers to a...
Go to my computer control panel network connections and see if the setup for networking is correct DHCP should work most of the time. Check the device manager and see if your nic is properly recognized. If not you might need to install drivers for the card.
mycomputer - control panel
mycomputer - view system information - hardware - device manager
Also, sign onto your router and see if the router recognizes the computer.
It should tell you how to do this in the routers manual.
May 09, 2011 | D-Link DWL-520 Wireless PCI Wi-Fi...
My pc now recognizes the drive as a local drive, but the drive cannot be read. Is it possible to restore the drive without deleting the files on it? They are some extremely important.
There are several things to try:
1) Disconnect all USB devices and restart the computer. Then plug in your external Hard Drive. In some cases, this has worked to enable external devices as there's a conflict between some USB devices. Once working, you can add any other USB devices you have.
2) Since the drive is recognized by XP, right click on it and if you have access to Tools, try to check the volume for errors. It may ask you to reboot and do a scan disk on startup. Sometimes although the computer recognizes the volume, it hasn't sufficient information as to how to access it. Running a scan disk can cure that problem.
3)Re-assign the drive letter; Occasionally XP can't access a path to the external drive; if it assigns a letter, in turn it will gain access
Change Drive Letter
The link above provides step by step instructions to change the drive letter
4) Run Windows Update and install SP3; Service Pack 3 addresses issues with external devices that weren't fixed in either SP1 or SP2
I do hope one of these answers provides a solution to your problem. Please post back with any other questions or just to let me know how you made out. Unfortunately, you have a common problem but no one FIX has been identified by Windows to solve it.
Best of luck!
Greg
Nov 06, 2009 | Western Digital My Book Essential Edition...
My mp3player isn't recognized by my computer.
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
H
May 07, 2009 | iRiver T30 MP3 Player
I cannot get the computer to recognize my camera
kindly visit the link provided www.download.com
and you can find generic driver for your device
May 02, 2009 | Labtec 2200 webcam
Samsung YH-925GS MP3 Player Logo
37 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
