Linksys RangePlus Wireless Router WRT110 - Wireless router + 4-port switch - EN, Fast EN, 802.11b, 8 Logo
Posted on Sep 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I already have a Modem provided by my ISP. I bought a linkSYS range plus WRT110 for better wireless connectivity.. Can anyone please explain how to use new router step by step???
Anonymous
Level 3:
  • Master 550 Answers
  • Posted on Sep 23, 2010
Anonymous
Master
Level 3:
Answers
550
Questions
Helped
420170
Points
1147
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Dsl modem = to 3 linksys wrt110 routers for wi-fi ?
What you are trying to do is a rather big job. Hire a company to connect the equipment properly. The headaches you save will be your own. If you install it, you will have to fix it everytime it goes out if you contract someone to install it and you buy a support contract when they install it, THEY get to come fix it and the headache is theirs, not yours. And NEVER install that type of router in an attic, they will overheat and fail very quickly.
I used to have a simple cable modem (coax cable in, network cable out) connected to a separate Linksys wireless router, model WRT400N. This worked beatifully. To improve download speed, I recently...
Welcome to FixYa!
For you to be able to do that, you will need to set the SMC router to bridge mode, you will not be able to do that by yourself because only tech from your ISP have the capability of doing that since they have this tool that can operate on the router setting it to bridgemode. Basically, you will need to call your ISP to set the router to bridgemode and from there, you will be able to configure the linksys router.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
2answers
I can connected to my linksys, but the the linksys
there is nothing issue with the linksys ist chk the ipaddress which u had provided to the modem and router is in same serious for eg: if ur modem is in 192.168.1.1 ten provide ur router ip as 192.168.0.1 and also chk whether the connection type is in PPPoE and also chk whether u r able to browse through modem which is provided by the ISP....
I am unable to use my internet due to the router. I can connect from the modem to my laptop but unable to connect from the modem to the router. What can I do to fix it?
You will need to check the wireless settings of the router
Make sure that your computer is able to go online directly through the modem.
Then you need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
If your IP address is within the range of: mine 192.168.1.1
  • modem reconfiguration must be done with the ISP support, then the linksys support must be done by linksys support, --set it to mac spoof only using computer mac address to connect online hardwired
Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
2answers
Configure WRT300N wireless Router to connect internet using PPPoE
Often the nets and subnets are NOT the same.. ie The Fixed connection often uses 192.168.0.1, 192.168.1.1, however sometimes the wifi is setup 10.1.1.1, or 10.0.0.1 etc, have you checked this? Esentially tho ya router is an "Acess Point" and ya Lappy etc is ya "Client" the links below has a lot of tutorials to help have a look. http://portforward.com/routers.htm http://portforward.com/guides.htm
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
