Question about Seagate Barracuda 7200.7 200 GB Hard Drive
My external harddisk is not detecting
External USB HDD is detecting but no data can be seen n also no icon in mycomputer. so plz guide me.
  • Anonymous Aug 16, 2008
  • 655 Answers
Hi kiran,
If you are using Windows 98 then you have to istalled driver for your external USB HDD.
If you are using Windows XP/Vista then the masstorage drivers for USB HDD is allready installed in your system, as it comes with the OS.
Some time due to conflict or bad contact your system might not read the USB devices:
  • Be sure that switch is on (if there is any switch in USB HDD).
  • Try to check the connection.
  • Try in different USB port.
  • Also check the USB cable is good.
If still no success try to use in another system and let me know your feed back.
Posted on May 21, 2008
This drive 250gb hitachi is not being recongnised by my computer.
maybe its in the bios settings that set to first boot was your external hdd,,,open bios settings and set first boot to harddisk drive,to boot your primary hdd so your external will be now detect
Feb 12, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
Bad luck if harddisk controller has failed you have to go in for new harddisk
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Harddisk not detected by system
Do you see the drive light on and can you hear the fan on your disk? If yes then try using a different usb port and a different usb cable. Check to see if there are any other drives with the same drive letter.
You can find this by right mouse clicking my computer, select manage, select disk drive manager see if the drive is recognized and if it trying to use the same letter as another. If so change the letter and it will be seen.
Mar 13, 2010 | Western Digital 250GB MyBook External USB...
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
Other freeware data recovery software GL.
Feb 15, 2010 | Maxtor Hard Drive
Toshiba StorE ALU 3.5" external HDD stops out of the blue.
Toshiba could only replace my HD after destroying the data on it, So I just bought a separate empty HD casing instead and opened the Toshiba casing and took out the Western Digital Harddisk. The harddisk was perfectly working, It seems that the Toshiba controller in their casing got messed up. (Never a Toshiba for me, because by solving the problem myself in the appropriate manner I lost their useless warranty).
Oct 02, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
HDD enclosure does not work
For that you need to uninstall all usb driver from device manager.
Right click on my computer icon then you see system property then go to hardware -> device manager then uninstall usb drivers 1 by 1 .
Then restart computer then all usb drivers are automatically installed.
Then connect your harddrive if still face same problem then connect your harddrive to another computer then check.
If another computer cant see your harddisk then your harddisk has hardware issue.
It need repairing .
If it is in warrenty take it to service shop they replaced it.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
New external harddisk cant be detected on my computer
Since you have not given any specifications about model of your HDD hence I'd consider your HDD connects through USB. Your USB driver is old you shall consider upgradation.
Jun 15, 2009 | Western Digital My Book Essential Edition...
External hard disk not being detected by computer
Now it is clear that your system is of good configuration and the fault was occurred due to removing of power supply directly. Do one thing check the same drive on another pc with good configuration. If same thing will happen, then you can visit your nearest service centre but remember it should be in warranty period.
Thanks and regards,
Rakesh Kumar
Apr 01, 2009 | Computers & Internet
Acer laptop is not detecting harddisk
i thought you have SATA interface, in that case your XP will not be able to access your HDD. But now as you told there is no option for SATA means you don't have SATA interface in your motherboard and the problem might be in your HDD.
  1. So, check out your HDD connection from motherboard and try to install again if no luck then do the following step.
  2. If you have important data/files on your HDD make a backup copy. Then make try to delete all partition and make new partition, then proceed further installation OR if you have recovery disk try to use it to recover your system as factory setting.
May 17, 2008 | Acer Aspire 5004WLMi Notebook
Seagate Barracuda 7200.7 200 GB Hard Drive Logo
356 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
