Printers
Problem for Printers
Generic problem for all Printers
Paper Jam
By Steven1996 on May 21, 2008
Hi Experts I really need your help,my HP PSC 1400 series is on a problem!The paper didn't jam but it just show "Paper Jam" on the status of my printer!Can anyone help me ?!
Solution #1
posted on May 21, 2008
Somewhat Helpful)
jonniewalker
Rank: Guru
Rating: 88%, 609 votes
Causes of repeated paper jams If paper jams occur repeatedly, one of the following may be causing them: The paper is being pushed in too far. The paper should only be pushed in until the first resistance. Continuing to push the paper in will force the paper up into the paper rollers and will cause the printer to pull in multiple pages. Obstructions in the paper path. Open the all-in-one (front and back) and check for obstructions.
  • Unlocked rear access door. Follow the steps above to install the rear access door correctly (see Figure 3). If this condition is present, the paper will skew in the all-in-one.
  • The paper guides are not positioned against the paper. Adjust the paper length and width guides so they fit snugly against the paper.
  • Incorrect paper. The paper should be flat and smooth with no folded, torn, or rough edges. Papers with a glossy finish and coated papers may not feed into the unit correctly. Paper that has already been printed on once can also cause problems.
  • Partially installed paper tray. The paper tray must be inserted all of the way into the all-in-one.
  • Dirty paper feed rollers. Over time paper fibers and dust will stick to the rollers and should be removed.. Also verify that the rollers on the rear access door are clean and turn freely.
Check Paper light flashes but there isn't a paper related problem The check paper light may also flash if there are other problems. Verify the following conditions:
  • Verify that the print cartridge door is closed.
  • The print carriage may be jammed, follow these steps to correct the problem:
    1. Open the print cartridge access door. If the print carriage can move, it should move to center. If the print carriage stays all the way left, unplug the power cord and then plug it back in. This will reset the unit and may allow the print carriage to move from the left.
    2. Disconnect the power cord from the all-in-one.
    3. Remove both print cartridges.
    4. Move the print carriage left and right slightly to verify that the print carriage will move freely. If the print carriage will not move freely, check for obstructions.
    5. Close the print cartridge access door.
    6. Plug the power cord back in.
    7. After the all-in-one initializes, the print cartridge light will flash. Open the access door and install the print cartridges.
    8. Close the print cartridge access door. If the problem returns, remove the print cartridges and wipe the electrical contacts before reinstalling them.
  • Try to make a copy. If it pulls in paper but cannot make a copy, there may be a problem with the scanner mechanism
Comments:
May 21, 2008
- go to the link http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=uk&dlc=en&docname=bpu00697
but you sounds as if the paper sensor flag either got stuck or broken when the paper got jammed - you might have to take it to a shop to get an accurate diagnosis, without seeing it I couldn't tell you more than that....but you can still try this
, take a piece of ~70lb cardstock, and with the POWER OFF, gently push this through the paper-path of the printer - this will help to possibly reset that switch, and will help push anything else out that's in the way that may be blocking it.
again check the quality and the type of paper you feed it does it comform this could be one
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
I need to make my existing Canon 2400 up and running. The existing external controller is burned... (More)
Answer
Is c4200 stil availabl eto buy?
Answer
i am trying to print from my netbook using an hp printer. i am getting an error message saying that... (More)
Answer
hi the printer stopped working on my mac and i tried to reinstall from the web but is ays the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
