FixYa.com
Tags:
PC Concepts Bitronics Auto-Switch
Help! Auto switch box and Canon Multipass 2500
By Gary10 - usenet poster
I have only one free parallel port on my system and want to use both a
Connectix Quickcam and a printer- the multipass 2500 from Canon. The
parallel auto switch box I bought is by PC Concepts, is non-powered and
bi-directional, and can be used as a 2-1 or 1-2 device. But it doesn't
seem to work with either the quickcam or the printer- the computer
(windows95 operating system) indicates that the port is in use by
anothegr device. According to Canon, the multipass won't work with a
switch box. Has anyone else had different luck?
jane.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Most auto switch boxes will not work with two devices unless they have a
manual switch as well, from which you can specify  a or b. Sorry, don't
know what a quickcam is but most auto switch boxes that work with two
printers will not work with other devices. Also almost all auto
switch boxes have problems with true bi-directional devices also
known as bi-tronic. Best suggestion is to either use a manual switch box
with full 25 pin switching or add another parallel port or, if you want
what you want and are prepared to pay for it - check out some specialist
switch box companies. Note: that Canon is probably right about their
device not working with auto switch boxes.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Networking Hubs and Switches problems?
at-8624t
how to give an ip address to a... Answer This...
N-tron 9000 problem.
I have an N-tron 9000 that has... Answer This...
ignition switch
lucas 7 SA seven pin need... Answer This...
can't use winchat
hi, when i am trying to... Answer This...
my renter messed up the...
Got a call from a tenant that... Answer This...
Repair Service
Find Networking Hub and. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
