Question about Microsoft Windows Vista Ultimate Edition
System service 1. my system service status is " stopped" 2. how to enable this for smart cards for installing safenet i key token
  • Microsoft Master
  • 13,433 Answers
Right click on the service, select properties
in the properties window make sure the service is set on automatic or manual, automatic would be better in your case.
Click on start.
Thats it.
Posted on May 22, 2008
How can i reset a system error E007
Good answer here:
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
<quote>
How to reset E000, E001, E003 and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
Jan 20, 2015 | Canon IR2020 Copier
F101 Error Toshiba estudio2040c
F101-4: Partition mount error (The HDD cannot be connected (mounted) caused by damage to the "/work" partition.)
1. Turn the power of the equipment OFF and check the connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- Perform [3C] - [5] (Key Backup Restore) and check that each Key Status is "OK".
- If not, recover the key (copy "SRAM Key Status" to "FROM Key Status" or vice versa).
3. If the error persists after step 2, perform
[5]+[C]+[POWER]?2. Recovery F/S?3. /work, and then restart the equipment.
4. If the error persists after step 3, perform
[5]+[C]+[POWER]?3. Initialize HDD?2. /work, and then restart the equipment.
5. If the error still persists after step 4, perform the following.
- Perform [3C] - [3] (Format HDD), and then install "System Software (HD data)" with [49] - [4].
Notes:
The following items will be deleted by performing [3C] - [3] (Format HDD).
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
If the error persists after performing step 5, perform step 5 after performing [4]+[C]+[POWER]?1. Revert factory initial status HDD.
6. If the error persists even after step 5, replace the HDD.
Oct 31, 2012 | Toshiba Copier Gm 2040 Print Scan Enabler...
Add token ninja saga
1. Get Firefox 2. Download Cheat Engine 5.5 Steps: OpenCheatengine5.5 Go into Ninja Saga Go toAcademyand Click on a skill that has "Training Time - Instant" In C.E, Enable Speedhack and set value to "0′ Click the "BUY" 3 times Now click on the skill that you want tolearn(a skill that requires Tokens tolearn) . Change the Speedhack back to "1′ Now go to theARENAandChallengeyour friendsand fight them to save the game Refreshthe game and you still have the Token Skill Repeat toacquireall the Token skills you want. 1. Open Cheat engine 5.5 2. Go into Ninja Saga 3. Go to Academy and Click on a skill that has "Training Time - Instant" 4. In C.E, Enable Speedhack and set value to "0′ 5. Click the "BUY" 3 times 6. Now click on the skill that you want to learn (a skill that requires Tokens to learn) . 7. Change the Speedhack back to "1′ 8. Now go to the ARENA and Challenge your friends and fight them to save the game 9. Refresh the game and you still have the Token Skill 10. Repeat to acquire all the Token skills you want.
Sep 22, 2011 | Ninja Saga
Error 1203 on a Dell Printer - what is this?
2080 1203 2055...Critical / Failure / Error...2080 1203 2346The Storage Management Service performs alert monitoring and logging. By default, the Storage Management Service starts when the managed system starts up. If you stop the Storage Management Service, then alert monitoring and logging stops. Alert monitoring does the following:
  • Updates the status of the storage object that generated the alert.
  • Propagates the storage object's status to all the related higher objects in the storage hierarchy. For example, the status of a lower-level object will be propagated up to the status displayed on the Health tab for the top-level Storage object.
  • Logs an alert in the Alert log and the operating system (OS) application log.
  • Sends an SNMP trap if the operating system's SNMP service is installed and enabled.
    http://search.dell.com/results.aspx?s=gen&c=us&l=en&cs=&k=Error+1203&cat=sup&x=10&y=12
Mar 23, 2011 | Vacuums
No audio/sound output from this compaq presario laptop despite having installed realtek audio driver and HD driver? what might be the problem
Well as you mentioned that you have already tried installing the driver then also the issue persists then it might be either a problem with the service responsible for the sound to work or the sound card .
In order to check that the sound card installed on the system is working perfectly we need to perform certain steps.
1.Restart the system and tap on the F10 key for while till we get to the BIOS SET UP UTILITY.
2.As soon as we get to the Set up Utility try tapping on any keys on the keyboard it would give BEEP sound.
3.If we get the Beep sound then the sound card is working and its a problem with the Operating System and we need to perform a couple of more steps,if it does not beep then the sound card is bad and call up Hp to get it replaced or get in touch with a local store.
4.Now if the keys beep on the Bios screen then we need to perform a couple of more steps on the Windows to check the functionality..
5.Click on Start, in start search or run type SERVICES>MSC and then hit enter.
6.Locate a service which reads as WINDOWS AUDIO.
7.Right click on that service and click on properties.
8.Check the status of the service...if the service is already started then the STOP tab would be highlighted or vice-versa.
9.If the service is started stop it and then again restart it, and if the service is stopped start it..
10.Now in the middle of the screen we would see a start up type tab, there would be a drop down menu next to it.
11.The drop down should be set to Automatic
12.Click on APPLY and then OK.
13.Restart the computer and then try installing the Realtek Audio driver and check the functionality..
Hope this works
Regards
KEN
May 10, 2010 | HP Compaq Presario V2000 Notebook
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to...
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
effect when the computer restarts.
Computer Setup Defaults
To return all settings in Computer Setup to the values that were
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
Jan 01, 2010 | HP Pavilion dv4000 Notebook
My wireless adaptor can not find my wireless router
Please check tour wireless adapter if its working and properly installed in your computer. Here's how to do it;
Checking Device Status on the Device Manager
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
If your wireless adapter is not working and installed properly, you have to re-install the wireless adapter software driver. When the wireless adapter is already properly installed you can follow this steps below;
Enabling Wireless Zero Configuration Utility
1. Please click on Start, Run and type in services.msc and click on OK.
2. Scroll down and look for Wireless Zero Configuration. Right click on it and click on Start.
3. Right click on Wireless Zero Configuration again and click on Properties.
4. Under the General tab, set the Start up Type to Automatic and Service Status to Started. Then, click on Apply and OK.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 10, 2009 | NetGear WGR614 Wireless Router
HOW DO I REMOVE SMART CARD FROM WINDOWS XP LOGIN
1. Click Start
2. Click Settings
3. Select Control Panel
4. Double click Administrative Tools
5. Double click Services
6. Scroll down and highlight the service you want to adjust
7. Right-click on it and choose Properties
8. Click the stop button.
9. Select Disable or Manual in the Startup Type scroll bar.
Services to Disable:
  1. Smart Card / Smart Card Helper - If you don’t have a smart card system, you don’t need this service. As smart cards have really never taken off… i doubt you need this. Kill it.
  2. TCP/IP NetBIOS Helper service - Unless you run NetBIOS on your system, you don’t need this service. Kill it.
  3. Uninterruptible Power Supply - Although I should have a UPS, I don’t. If you don’t, then disable this service.
  4. Remote Registry service - This service allows one to remotely edit the registry through a network connection. If you are editing your registry remotely, then you are too jedi-ninja to be reading this guide. The rest of us should have this off for security alone.
  5. Error Reporting Service - A program crashes and microsoft wants to know about it. Give up your extra CPU cycles to help Gates polish his OS, or you can just disable it.
  6. Wireless Zero Configuration - Unless you use wi-fi, you can safely stop this service. If you use wi-fi, this is actually a nice little service.
  7. Alerter - This is so useless SP2 turns this off for you. For the rest of you folks, you should turn it off too.
  8. Clipbook - This service allows you to cut and paste across your private network. Most programs that actually allow you to do this use their own ways for doing this.Useless.Stop it.
  9. Computer Browser - If you are on a LAN, keep it enabled. If not, stop it. It allows you to see the other computers on your network.
  10. FastUser Switching Compatibility - If you keep multiple users/logins on your current computer, you should leave this enabled. If you always log-in the same way as the same person, you should disable this.
  11. Messenger Service - Kill it, kill it. We’ve been saying to kill this forever.
  12. NetMeeting Remote Desktop Sharing Service - If you don’t use NetMeeting, you should stop this service.
  13. Network DDE/Network DDE DSDM - DDE DSDM was an excellent idea by Microsoft that flopped. Disable both of these.
  14. Remote Desktop Help Session Manager Service - I use remote desktop all the time. However, you should not have it enabled unless you use it.
  15. Telnet Service - This allows you to use telnet to log into your system from a remote location. It’s a security risk so don’t keep it enabled unless you use it.SP2 disables it by default now.
Nov 26, 2008 | Audiovox Computers & Internet
Cannot make a wireless connection between a sagem router and a ralink wireless mini card 802.11g
  1. Make sure that your wireless mini card is properly installed into your computer. You can check the status of your wireless adapter by going to Control Panel>System>Device Manager. Then go to Network adapters and look for ralink wireless mini card. Right click on it and click properties then look for device status. It should state there, Device is working properly. Otherwise, there is a problem in the installation of the adapter.
  2. Then, verify the wireless settings that are enabled in your router by accessing your router's setup page.
  3. Take note of the SSID or wireless network name and the security enabled in your router.
  4. Configure your computer that has the wireless adapter with the same wireless settings in your router.
Hope this helps!
Nov 13, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
