Question about Singer 7422
Machine Won't Sew
I used my 7422 machine to add a button hole on a pair of pants. It worked fine, but now I can't get it to work for any other stitch. I pushed the BH lever back up, but when I try to use the foot pedal it just beeps. The only stitch that is still working are the large and small BH regardless of if the lever is up or down. Anyone else had this problem or an idea of how to fix it?
  • Anonymous Mar 31, 2014
    When you pull down the lever to make a button hole it makes the first bar tack and side but springs back up before the remainder of the button hole is stitched
  • 323 Answers
It sounds like the sensor on your buttonhole lever is out of adjustment.Contact the people listed on your warranty papers for repair.
sewman7
Posted on May 23, 2008
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
I have my machine threaded and it runs with no beeps however it is not sewing the material together
I'm wondering if you have the flat side of the needle in correctly. If your bobbin assembly is in the front of the machine, the flat side should be towards the back. Also, check to make sure your needle is ALL the way up in the needle clamp.
Sep 02, 2014 | Singer Advance 7422 Electronic Sewing...
Singer advance 7422 bobbin jumps
Did you get it fixed? Here is a video that may help.
Mar 20, 2014 | Singer Advance 7422 Electronic Sewing...
For the Singer Advanced 7422 machine. I put on
have you got a buttonhole lever on the sewing machine that has to be pulled down first before starting the buttonhole?
Aug 29, 2013 | Singer 5050 Mechanical Sewing Machine
Singer confidence quilter beeps 8 times won't sew
http://www.singerco.com/uploads/download/549_7469_efs.pdf
http://www.singerco.com/uploads/download/683_7469_efs.pdf
here are 2 links for a free manual, you can choose which one you need
try changing the needle
if you just bought the machine,, you may have to take it back & get
another one
Jun 08, 2012 | Singer 7422
Won't sew in forward just reverse
the machine needs to be serviced
May 19, 2012 | Singer 7422
I bought a yamata fy-900 from a thrift store. used it for a couple of days, it worked fine untill i tryed to sew a pair of jean pants and the needle got stuck and it hasent worked right sence it does not...
You have probably knocked out the timing on the machine. Most household machines, inexpensive machines especially will not sew denim without a fair amount of coaxing. Check the threading and do try on lighter fabrics first. to see if its just the denim.
Derek
Jan 17, 2011 | Yamata FY900 Mechanical Sewing Machine
Frozen machine
Hi this is techcrazy
the motors in ur sewing machine is not runnin because there is no proper rotational motion inside the motor of sewing machine.so one way of rectifyin is replacing the old pair of magnets with new ones..which may prove costly.so if possible my sincere advise is to go in for a new one
please do rate me on this solution
Feb 02, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Oct 31, 2008 | Singer 7422
Singer 7422 Logo
143 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
