Question about Acer Aspire 1640Z Notebook
Bios i up grade my bios mistacely from 3a18 to 3a24 and after restart the lcd doesn't turn on and hear 3 beep (1 long 2 short) i cant find any jumper and i remove the battery but he do the same think the bios chip is installed and can not be removed my notebook is acer aspire 1640z. most service here in albania can't repair it i don't know why? they neither show it. please help me with this problem. how can i install the bios version from begining my notebook doesn't have floppy. thanks
  • 36 Answers
Hi, I just did a quick search. Maybe the info here can help. http://www.wimsbios.com/phpBB2/topic8541-15.html
Posted on May 21, 2008
After power on beeper beeps 9 times and computer doesn't working. What is it? Motherboard ga-g41m-es2l
error: 9 beeps is ROM checksum
Turn OFF the PC
1.- Clear the CMOS (jumper near the battery)
place the jumper in 2-3
return the jumper to normal position
2. Remove the battery
Turn on
enter to BIOS
Update bios from the Gigabyte web page
remeber rate my answer,,
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 20, 2011 | Gigabyte GA-G41M-ES2L Motherboard
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Ram beep but no display bios jumper is clear stat bios jumper is normal then no start machine
Please see this as reference
Continuous long beeps-RAM error
2 short beeps- BIOS error
1 long and 8 short beeps- Display Card error
1 long beep after few seconds 2 short beeps-FDC error
1 long beep after few seconds 1 short beeps-FDC is Ok
1 long beep and 2 short beeps-Display Card Error
Most probable cause is Ram memory, please try removing modules and reinserting, also try using alternately just one of them to determine which one is defective.
Mar 04, 2011 | ASUS P4GE-MX Motherboard
My 741gx-m2 motherboard produces continuous beeps when i turn on the power, when i remove the ram i get a long 1 second beep followed by a few beeps, i return the ram i get continuous beeps but no display.
reset your cmos see if this helps pull the jumper on the jp3 circuit on the motherboard and short the 2 and 3 pins with the power off and unplugged then put the jumper back to 1 and 2 ! the bios settings are wrong and this will reset the bios to defaults.
Oct 14, 2010 | EliteGroup 741GX-M Motherboard
Pc beeps 4times y?
4 short beeps
Your problem could
be a bad timer. The system timer failed to work properly. It will
require motherboard replacement.
1 long and 3 short beeps
Memory test failure. An error has been detected
in the memory over the first 64K. Try replacing the memory, and if
that doesn’t do it, the motherboard.
Beep codes are the beeps you hear from the
PC speaker when you turn on your computer. They are your computer’s way of letting you know what’s going on when there is no video signal. These codes are programmed into the BIOS of the PC.
Nov 10, 2009 | Dell Vostro 200 Desktop Computer
Bios problems
If this is under warenty take it in if not your going to need to access inside of it and move the bios jumper and the flash the bios again, This time back to its orginal settings before you did this.
Remember if there was nothing wrong with the computer in the first place you nevr want to flash the bios i do not care if its a unpdated one.
Jul 18, 2009 | Acer Aspire 1640Z Notebook
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
Bios problem
Yes, I want to know about this problem.
May 19, 2008 | Acer Aspire 1640Z Notebook
Won't turn on
reset the bios jules
Apr 23, 2008 | Intel Motherboard
Acer Aspire 1640Z Notebook Logo
170 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
