Question about Compaq ProLiant 5500 Server
Run Compaq Array Configuration Utility
I bought one of these servers second hand to do some of my assignments on. I installed windows server 2003 and then the array configuration untility for windows. The server has 5 9.1Gb drives in. I then tried to make a raid 0 with 2 disks and a raid 5 with the other 3. So i made some changes and it wanted a reboot so i re booted the server. Now when the server boots get i message "1785-slot 7 drive array not configured. Run compaq array configuration utility" if i press F1 to ignore and continue it says no boot disk and if i try install sever 2003 from the cd it does not find the disks. Ive looked at the HP/Compaq support site and i can find a "Compaq System Configuration Utility" which gives me an option to to run Drive array configuration but when i select it it asks for the drive array configuration disk (floppy). I also get a message saying no logical drives detected. So the way i have it is i have to configure the array with drive array configuration and then install windows on the configured array, but i can not find the drive array configuration disks any where, nor can i get my havd on a copy of smart start 5 or lower to test if that works.
Please Help
    Problem Solver:
  • 17 Answers
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
Posted on May 30, 2008
How to boot from CD
Do you have smart start installed on it? If so:
The F10 "Bios" partition is only available if the server has had SmartStart installed on it. The SmartStart partition is actually a 20Mb (ish) partition on the configured hard disks. If the partition is available, you will be prompted to press F10 at the end of Post boot just before the OS would kick in.
The position of the drives is important so keep them in 0,1,2 & 3. Once you can boot off SmartStart (v5.50 as mentioned), you can reconfigure the Array config in the Array Configuration Utility (ACU).
Jul 30, 2014 | HP Compaq ProLiant ML530 Server
Hp proliant dl380 g4 not booting from hard drive
I bought an HP DL380 G4 from here, and called them up any time I had a question like this. These guys were amazingly smart. Perhaps you can call them up and pretend to be a customer?
May 07, 2012 | HP Compaq ProLiant DL380 G4 Server
Hi guies the windows srever 2003 files in my hp ml370 is corrupt and i tried to fix the prblem by format one hard disk partition in my scasi disks array and installing win srv 2003 on it but whe i log on...
HP SmartStart CD x32
The utility to use to set up the ML370 g3 server is the SSCD (smart start cd) this is a guided installation cd that will help you set up the array, install drivers and diagnostic utilities and after that
will request the windows cd so that you can finish the installation.
instructions:
1. download SSCD from here
2. extract the zip file
3. burn the ISO image to a cd
4. boot the server to the cd
5. choose from the main menu the option "Deploy server"
6. follow the wizard
Oct 26, 2010 | HP Compaq ProLiant ML370 G3 Server
I want to install windows 2003 on compaq proliant ML350 G3,but I have not a disk called server guide.please help me.
1. turn the server on, when you see the smart array controller posting
hit f8 to enter the controller settings, here create the array (1, 5,0)
2. insert the windows cd and follow the normal installation procedure
or download the smart start cd from here for a guided installation
with SSCD just insert the cd and follow the directions
Aug 30, 2010 | HP Compaq ProLiant ML350 G3 Server
I want to install a new scsi but when my os windows small business server 2003 it gives me "setup either detected multiple disk in your machine that are indistinguishable or detected raw disk(s). Setup has...
using the ACU (array configuration utility) create a raid 0 with this drive after the hard drive is being formatted and is configured as raid 0 (no redundant) restart the server and the hard drive should be detected as a new logical volume with a assigned letter "D" "E"
ACU
Jul 30, 2010 | HP ProLiant ML370 G3 Server
Problem with harddrive
It could be because the disk is not a part of any array. Log into the server and go to the array controller utility from HP and check for any unassigned disks. It will be displayed there rather than the diskmanagement window.
Feb 01, 2010 | HP Compaq ProLiant ML350 G3 Server
New install scsi hard disk no detect in ibm x3400 server
you will need to add the new drive to your array bbfore it will how up to be formated do this throught the array configuration util
Regards Al "alstech"
May 26, 2009 | IBM x3400 Server
I have a HP DL 380 server and its configured as domain controler.... and has a raid5 configration .while we are woking it makes a restart and when its restarted windows was unable to boot asking for NTLDLR...
Are you able to get into the array configuration and make sure the logical drive is still intact? If the logical drive is gone, then your partition may be lost. If you are able to recover the logical drive in your array (which you should be able to if the RAID5 striping was stable) then you should be able to recover your data. You can get into the array configuration during the boot up sequence.
Jan 06, 2009 | HP Compaq ProLiant DL380 G4 Server
Audible alert
Run Array Configuration utility from your SmartStart disc. If the array is degrades the system will show to you.
Nov 07, 2007 | HP Compaq ProLiant DL380 G4 Server
Compaq ProLiant 5500 Server Logo
2,693 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
