Question about Toshiba Computers & Internet
I have the keyboard on my satellite 200 set to UK and believe I need to change this to US as the keys are set incorrectly ie back-strike is # and # key is £ and dont know how to change it
    Problem Solver:
  • 13 Answers
Go to control panel double click on keyboard icon go to hardware,troubleshoot ,properties then ok.
on ctrl panel go to regional and language icon then language ,details,key setting,change key sequence then click ok
Posted on May 21, 2008
How do I get my @ symbol I've tried all keys but no joy.techgear active strike pro mini
Probably the keyboard is set up to the wrong language. US keyboards use Shift 2, UK keyboards use Shift ' for example.
Oct 30, 2016 | Computers & Internet
Forgot bios pass word on acer 7540 aspire
Hi I hope this we help you.
First check all programm menu and locate hp security folder in it you find recovery manager click on it and restored your computer to factory settings. if your computer has corrupted to the extent that the process stop then restart your computer at the process of booting strike on escape key on your keyboard to enter into series of procedure, which will indicate (f2, f9, f10, f12) with their respective actions strike on the function key that is set for recovery manager then follow the process. I believed this should resolve your issue.
May 01, 2014 | Toshiba Satellite A100-S8111TD Notebook
@ key not working on toshiba laptop
probably your keyboard mappings, this is definite if you get the @ when pressing shift [2]
go in control panel, regional settings you have probably looked at keyboard settings which is the logical place for this problem, but not correct one.
change US to UK keyboard or vice verse depending on your location.
Jun 01, 2011 | Toshiba Satellite L655S5078 Notebook PC
The keys are not synchronised properly. The @ key and the " are typing each others symbol. ie I have to press shift 2 to get the @ symbol and vice versa.
you are using a usa keyboard.
if you want to use the uk keyboard layout change the regional settings, go to languages and there is an option to change the keyboard.
uk keyboard will print " when pressing shift+2
Jan 12, 2010 | Dell 0Y3740 Keyboard
I need to replace a couple of letter keys on my laptop. Where can I purchase them. How much and how easy is the work to replace these keys.?
if your problem is (the keys writing are worn out) then you can neatly write on it, but if the keys (some ) are not working, then your keyboard will not work, even tyou replace the keys...the plastic tracks can be damaged, and only it can be replace by changing the whole keyboard...check out on ..if hard to get 1, plug a usb external keyboard
Oct 25, 2009 | Toshiba Satellite P205-S6347 Notebook
The upper case figs ie @ and " have swopped positions how do i get them back to their right postions
The difference in the @ and " symbols occurs between US and UK keyboards, where UK keyboards have the " symbol on the "2" key and US keyboards have the @ symbol on the "2" key.
Regardless of what physical drawing you have on the keyboard, you can change the actions of the keys by setting up the appropriate US or UK keyboard layout in Windows.
First, determine whether you'd prefer a US or a UK layout. In the US layout, pressing SHIFT+2 will write @. In the UK layout, pressing it will write ".
Now, from the Start menu, select Settings and go to Control Panel. Once there, search for "Regional and Language Options". Under the "Languages" tab there is a button labeled "Details". Press it, and a new window opens with the keyboard layouts. Use the "Add" button to select the keyboard layout you want (English, US or UK, Qwerty - not Dvorak), then Remove your old keyboard layout. Press OK and exit all the screens, you're done.
Hope this helps.
Aug 13, 2009 | Compaq Keyboard
Key @ and " changing place
I have had the same problem before. I found that setting the keyboard to U.S.english caused it on mine, so a good guess would be that you have done the same. Try switching the U.S./U.K. keyboard settings and that might be the solution.
You will find in in the control panel,keyboard options.
I hope this helps
May 09, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Laptop Keyboard problem
My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
Keys swapped
ok you do not have a bad chip - check you keyboard settings I have both an American keyboard and English upgraded, but like the keys where they were (English settings so i have English keyboard with an American keyboard therfor to get it back (tell me if I am correct please).
go to start In Win XP, to change the keyboard languages and layout, click Start , then choose Settings, Control Panel, and Regional and Language Options. Click the "Languages" tab, then the "Details" button, I hope this helps
Mar 17, 2008 | Logitech 967437-0403 Keyboard
Sony Vaio PCG K115M keyboard problem
Hi, its easy to fix. you have your keyboard layout set to US Layout, ie americans have a couple of keys in reverse from ours. All you have to do is this Windows XP Start, Control Panel, regional & language settings, change all US Settings, in there to UK British, And it will fix your problems :-) if its windows 98/ME ETC start, control panel, Keyboard, and change the US Keyboard setting to UK British, u usually have to set it twice, ie select uk, apply it, then do it again before it changes... If you dont get it sorted will guide u though it just email me.. All the best John
Jan 31, 2007 | Sony Vaio PCG-N505 Series Laptop...
Computers & Internet Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
