Question about DeLonghi Pinguino PAC-210 Air Conditioner
Air not getting cold
I haven't used my delonghi pinguino in over two years. It is now hot in Southern California and i turned it on an i no longer get cold air...??? Do i need to add or replace something? And how do i clean the filter??? Suggestions are greatly appreciated.:)
  • 828 Answers
You should have the unit serviced. If the compressor runs and does not cool it may have lost its refrigerant charge.
Posted on May 21, 2008
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Only a third of the vent is blowing air
hello. here is a link to some helpful info. http://www.sylvane.com/delonghi-pac260.html
THis unis is no longer being made so finding a manual will be a challenge. Remove the filter and use it without one for tonight. then get a new filter tomorrow. be cool.
Aug 12, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Pinguino ct 90 trips the circuit breaker and soaks the carpet....
My Delonghi Penguino ct90 no longer blows cold air out for longer than a couple of minuets need a fix for this and it is no longer under waranty. Please help.
Jul 05, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
How to conect my air condittinion pinguino pca L90
This really Expensive AC quite on me. The fan works great, I hear the Compressor turn on and it still doesnt blow cold air. Should I flip out?
May 14, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
K 900, pinguino
I had the same problem with my Delonghi K900.  I have an extended warrantee for both my Delonghi air conditioners.  It was taken into the shop and discovered that the hose that allows the water to drip into the collecting tank was clogged with dirt and dust. I find it is a good idea to have them cleaned and checked once a year, especially if used often. For under a hundred dollars, I have a warrantee that will last until the year 2010.  Sears offers warrantees for any home appliance, even if it wasn't purchased there. Taking the air conditioner apart yourself can cancel any warrantee on them machine. Hope this helps. Trisha
Jul 27, 2008 | DeLonghi Pinguino PAC-77E Air Conditioner
Pinguino pac-166 not cooling enough
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Jul 06, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Delonghi piguino k900
does anyone no where to find a user manual for this air conditioner?
Jun 08, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
DeLonghi Pinguino PAC-210 Air Conditioner Logo
559 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
