Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Hardrive issues hi....k the deal is my hard-drive started groaning. I'm serious...it started making funny noises like something was spinning off its orbit on the inside. Now its not just something that will go away...i know computer hardware. The thing is im more worried about getting my files then fixing this...but i spose they go hand in hand eh? PLEASE help asap....thanks:)
  • amyklein May 21, 2008
    It's an external drive
    Problem Solver:
  • 13 Answers
Hi, remove and put the hard disk in another machine where you disconnect the cd rom and fix the hard disk so as to view two drive(c(hard disk in the machine)&e(the faulty hard disk))open c and create a folder ,open e and copy your files to c .
after remove the e drive and fix it to its machine.
format the hard disk then copy the files in c(in the other machine)using the above procedure
Posted on May 21, 2008
Groaning noise
Check the wheel bearings, or have them checked, immediately. This is the most likely cause of the groaning sound you are hearing, and if left uncorrected, it can cause serious problems, possibly leading to further mechanical damage to the car, or even an accident.
Jul 14, 2013 | Cars & Trucks
I get a knocking when i turn on my computer
Sounds like your dealing with a lose component here. Sounds like maybe a fan is going out or the hard drive is knocking making noise. It works however I would take it apart carefully if you know what your doing if not take it in and get it looked at. It may be something really simple a loose screw hold down something. I have heard hard drives make a load type noise before they go out. Something is not right that is for sure. Inspect it before something serious happens. Have it done if you do not know how to do this. John
Apr 16, 2012 | Compaq Presario Notebook
The screen color started flashing funny. I turned the TV off. When I turned it back on, it makes a horrible groaning almost grinding noise, on and off, then finally stops trying to do what ever it's trying...
This tv have a colors wheel,it dying,now it dead.Colors flashes black&white and grinding noises,the colors wheel was spinning off of it motor axis and rubbing it sides wall.The colors wheel,now require changing to make the tv work again.The colors wheel it pretty hard to replaced,because it require take out many machanicals parts even can get to the colors wheel to replaced it.Best it to hire a tv tech. to do the job.If u never done or change anythings,that require take out alots and many machanicals parts before.
Oct 20, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
No response freez making funny noise
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Is it an external drive?
If it is, open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
Lastly, if its not an external drive, the same applies because, its still all about hard drive.
I wish you all the best.
Jan 08, 2010 | LaCie F.A. Porsche (301177) Hard Drive
It keeps making funny nosies and won't turn on...
The 'funny' noise would clicking or spinning 'seeking' noises made by your player trying to read its micro Hard Disk in order to start: this is usually indicates that you have a faulty internal disk drive which may have been caused by accidental mis-handling (eg. accidentally dropping or sudden movement while writing to the player).
Dec 24, 2009 | Microsoft Zune JS8-00001 Digital Media...
My maytag won't spin. The agitator moves but the
Sounds like the transmission is shot. Call a repair shop, or buy a new one.
Oct 21, 2009 | Maytag Performa PAV2200
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
Possible transmission issue
You have a serious transmission problem, by driving the car you are making a bad problem worse. You will need to have the transmission overhauled.
Dec 20, 2008 | 2002 Ford Explorer
Hard drive clicking
Hi dsthrasher,
Anything making a clicking sound in your pc is a bad sign. it means that there are lose parts or somethings rubbing where it shouldn't be. I would recommend that you backup your data onto cd, dvd or an internet data storage a soon as possible. If it is the hardrive that is clicking that means it doesnt have much life left in it and even if they did last forever its a great idea to have a recent backup.
Also make sure its the hardrive and not the fan. cause if the fans malfunctioning more serious problems can occur.
Nov 13, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
70 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
