Question about IBM eserver xSeries 200 8479
XSeries 200 8479 Problem
Hi
thank you for the reply.. how do you update the bios? is there a general flash utility of a specific one? do you have the bios file on you? i 'cant seem to download anything from the ibm site.. no idea why...
cheers
kbh
  • Arcadian Duran
    Arcadian Duran May 11, 2010
    Sometime Spyware will prohibit you from getting to a site. Try running a spyware remover program like spybot search and destroy or microsoft defender make sure they are updated.
    Depending on how old the computer is, BIOS updates may not be available for the motherboard, since companies wants you to go out and buy new hardware.
    Arcadian
    Problem Solver:
  • 17 Answers
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
I want upgrade bios ga 8simlh rev 1.0,but can not
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
Hi, I would like to update my GA-8I848P-G motherboard's BIOS. But I don't know how I can do it. Could you send to a soft to flash the new BIOS?! Kind regards, Grafi
You can get the BIOS flash utility at the Gigabyte website. As far as the actual flashing is concerned, it is a fairly simple and straight forward process. The specifics will depend on the utility that you download. You will need TWO things. The flash utility and the firmware you wish to install. Just a bit of warning, improper flashing of the mobo's BIOS can lead to catastrophic failure of the motherboard, so take care and follow the instructions to the letter.
May 05, 2011 | Gigabyte GA-8I848P-G Motherboard
I need boot my computer from usb. what I need?
Generally, you need a few things:
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS settings to make this possible assuming your BIOS supports it. Some BIOS's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
Check out this comprehensive link to make a bootable USB / flash drive in your choice of several different Operating Systems.
I hope this helps and good luck. Please rate my reply. Thank you!
Apr 13, 2011 | Sony VAIO VGN-SR220J/B Laptop
D946gzis bios.bin file i need pls help
You need to update your bios interface and to do so, CLICK HERE. It's a PDF file and all you need to do is to click on the 3rd topic which is for the BIOS Update and what you need to do are as follows:
Updating the BIOS with the Intel® Express
BIOS Update Utility
With the Intel Express BIOS Update utility you can update the system BIOS while in
the Windows environment. The BIOS file is included in an automated update utility
that combines the functionality of the Intel® Flash Memory Update Utility and the ease
of use of Windows-based installation wizards.
To update the BIOS with the Intel Express BIOS Update utility:
1. Go to the Intel World Wide Web site:
http://support.intel.com/support/motherboards/desktop/
2. Navigate to the D946GZIS page, click "[view] Latest BIOS updates," and select the
Express BIOS Update utility file.
3. Download the file to your hard drive. (You can also save this file to a removable
USB device. This is useful if you are updating the BIOS for multiple identical
systems.)
4. Close all other applications. This step is required. Your system will be rebooted at
the last Express BIOS Update window.
5. Double-click the executable file from the location on your hard drive where it was
saved. This runs the update program.
6. Follow the instructions provided in the dialog boxes to complete the BIOS update.
Feb 16, 2011 | Intel D946GZIS Motherboard
Hi, Hope you can help. I've just fitted a new motherboard to my computer (ASUS crosshair 2 formula). My memory is 2 x 2GB DDR2 running at 800Mhz. Th machine will run fine using either of the sticks, but...
Hi. Asus has a great utility that lets you update your bios even in Windows.
http://www.asus.com/product.aspx?P_ID=EIDxaW1Ln3YR9RA2
At the download section select your OS and in Utility section find "ASUS Update V7.14.01 Install Program" This program will automatically update your bios.
As for your Ram issue. Did you try each stick in each ram slots ? If you did and saw no issues, then I am only suspescting of incompability between your Rams.
Oct 12, 2010 | ASUS CROSSHAIR Motherboard
How to flash my BIOS
Flashing Your BIOS
General Instructions:
Flashing [aka upgrading] your bios should be the last resort to solve a problem. Most people flash to gain the use of larger hard drives although recently, many are flashing to get all the features of XP to work. Other people have to upgrade their bios just to get XP to work properly with some specific hardware.
A couple of items are really important if you decide to flash. First. Make sure the updated bios addresses the issue you are trying to solve. eg many motherboard makers update their bios's for many different reasons. A reason may simply be to get a certain big name brand of pc to work correctly with a new cd writer big brand pc is selling.
So you really have to read the docs so see if the upgrade addresses your specific niggle or concern. Secondly, try your motherboard maker first to see if they have the files you need. Bios's upgrades are best had, if available, from the company that made your motherboard or pc. In most cases these are free.
Thirdly, READ THE DOCS CAREFULLY AND FOLLOW THEM TO THE LETTER. Dont skip any steps, especially the backup option if available. Fourth, if the upgrade calls for a clean bootdisk, use one. The disk I made especially for bios flashing is the one you can download above. It's a DrDOS bootdisk with NO drivers loading up in config.sys or autoexec.bat which is very important. My bios flash bootdisk is recommended by the most popular motherboad makers.
If you dont have a 1.44 drive I also created a utility to use to flash from a CD which you can add the new bios and flash utility to and then burn it.
It should have room to add your new bios, the flash utility, and also have room for the backup. If not one can always use another disk for the info. Always use BRAND NEW MEDIA when dealing with flashes.
In order to locate the correct bios upgrade for your motherboard you need to know who made it AND you need to know the model number. If your PC was made locally perhaps you have the manual. If not, then you need to find out the maker and model. Or, and very common with major brands, your computer maker will/may have the updated bios's on their website.
I have one windows and three dos utils that find your motherboard maker and model number. One of them should work for you. The DOS utils are on my DOStools Page under Diagnostics, and are called CTbios, MBID, and HW iNFO. The windows utility is called BIOS Agent and is on my Utilities Page under Hardware .
Once you ID your motherboard and model go the the manufacturers website and see what they have available. Note that some upgrades will come with their own bootdisk/utility so you may not need the disk I made.
Again, note that even tho many people flash their bios regularly to get the latest features and never have a problem, I still recommend it as a last resort as a flash gone bad will make your pc unusable if the backup doesn't work. Look at it this way, suppose I have a used 80 gig drive I want to resuse and my old P400 cant even detect it so I have an unusable pc. This is the best, and most common reason to flash.
On the other hand, if you have a more modern pc that cant see lets say a 180 gig drive and but all else is working properly then you may want to consider a PCI hard drive controller card which has an onboard bios that will see your new large hard drive and also come with 2 more IDE channels you can use in addition to the 2 channels you already have. This is safer than flashing the bios.
Sep 10, 2009 | Toshiba Satellite M30 Notebook
Multimedia Audio Controller Needed as Well!
I find VGA and Audio triver for motherboard MSI-661FM3
Jun 02, 2009 | MSI 661FM3-V Motherboard
File P4P800SE.ROM not found
Sounds like you're trying to flash the bios..
Using ASUS EZ Flash to update the BIOS: The ASUS EZ Flash feature allows you to easily update the BIOS without having to go through the long process of booting from a diskette and using a DOS-based utility. The EZ Flash is built-in the BIOS firmware so it is accessible by simply pressing <Alt + F2> during the Power-On Self Tests (POST). To update the BIOS using ASUS EZ Flash: 1. Visit the ASUS website (www.asus.com) to download the latest BIOS file for your motherboard and rename the downloaded file as P4P800SE.ROM. Save the BIOS file to a floppy disk. 2. Reboot the system. 3. To launch EZ Flash, press <Alt+F2> during POST
Hope this helps
Chris (ziraffa)
Dec 31, 2008 | ASUS P4P800SE Motherboard
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
Nov 06, 2008 | Computers & Internet
IBM eserver xSeries 200 8479 Logo
148 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
