Question about Clarion DC625 6-Disc CD Changer
Clarion 1577A I have an old Clarion Car Radio Cassette Model 1577A and it seems the sound not working. The LED flashed and the power to the radio ihave no problem I already checked the fuse, the cable, the wire to the speaker and it seems have no problem at all.. I didn't used Power Amplifier and the cable to both speaker is connected, i cannot fixed it myself because i didn't have the wiring diagram for this model. Can you please help me.. Or can u find out for me the wiring diagram? I really appreciate it.
simplemitch
  • 752 Answers
SOURCE: clarion marine stereo M2455
Don't worry about the brown wires. They are for telephone mute.
The yellow is Memory (constant 12 volt, so battery is fine), but the red should go to a 12 volt source that turns on and off with the key.
Posted on Aug 05, 2008
rteemon
  • 578 Answers
SOURCE: wiring confusion
yellow constant
red switch
black is ground
blue power antenna if any
dimmer i/illumination is optional
front- right-red/green-+
front-left-blue/green-+
rear-right-red/yellow-+
rear-left-blue/yellow-+
these are all the positive side wire for all your spkr
Posted on Jun 25, 2009
  • 4886 Answers
SOURCE: I NEED A RADIO CODE FOR MY CAR RADIO CLARION
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with C7000000 + + + +  on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
There is a 20% chance of your PU-9990B  having this barcode Serial Number
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Posted on Nov 06, 2009
Testimonial: "YES MINE HAS THE NUMBER YOU WRITE ABOUT HOW DO I GET THE CODE TO UNLOCK IT FREE."
  • 4886 Answers
SOURCE: How to remove a Clarion AB213R radio-Cassette ?
It depends on the type of Clarion Radio.
There are 2 types of Clarion Keys depending on the size of the removal slots in your radio  ...the older , larger version or the later slim version.
See the difference here
http://www.incaripod.com/Brand/Radio_Removal_Tools
Available on Ebay , local car radio store etc
Posted on Jan 22, 2010
iadame
  • 676 Answers
SOURCE: need to know the wiring color code for the clarion
I have a attache dthe color codes for the stereo. Hope this helps. Good Luck and please rate. Israel
Posted on Jun 14, 2010
My husband has a clarion ARX3170E RADIO CASSETTE COMBINATION in his car but is unable to get the radio working on it ..
If the radio is blank and no power then check all fuses......in fuse box and behind the radio unit!
if the radio requires a code check your documents for a 4 digit code.......if you do not have the code try this link: Car radio codes in Uxbridge London Gumtree
Sep 07, 2016 | Clarion Car Audio & Video
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
Jan 22, 2010 | Clarion Car Audio & Video
Ay need codes
The radio will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Please note: Not all stereo codes can be calculated from the Serial Number
May 30, 2009 | Clarion ARX6670Z Cassette Player
How to put in the radio code, have no manual
CLARION code entry instructions can be found here
Select your model from this long list
http://www.radio-code.co.uk/code-entry-help-Clarion.htm
May 24, 2009 | Clarion ARX6670Z Cassette Player
Blaupunkt car 300 (D) radio fitted to P registered Vauxhall Astra Merit
you could try holding the power and AS button simultaneously until your hear a dull beep. then it should allow you to enter the code
Nov 10, 2007 | Car Audio & Video
Clarion DC625 6-Disc CD Changer Logo
259 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
