Question about Paradyne (6211-A2-200) Router
How can I create PVCs on 6381-A2-200?
Hello, All!
How can I create PVCs on 6381-A2-200? I want to use one PVC for voip, and another one - for internet connection. As far as I know it is possible to set different qos (priority) for different PVCs and hense voice quality will be better.
Thanks in advance for your support.
Sorry for my bad English.
  • Coss May 11, 2010
    Please explain what you mean by PVC's ?
    There are about 30 different connection types it can be.
I mean that PVC is "private virtual circuit".
Posted on Aug 24, 2008
Hello, I have x-lite on my computer, i can make VOIP cal for a limited time only, then I loose the DSL connection, and the dlink modem require restart (internet status went off). any support please
Does this problem (internet status off) happen even when you are not using x-lite?
It's very unlikely that it's the software disturbing the connection. I suspect your VoIP calls are interrupted because the connection is dropping, and not the contrary.
May 09, 2011 | Westell Wirespeed LiteLine 6100...
My company provided me wired internet using Paradyne 6381 wired modem. it works fine. I have D Link 2640 T wirelss modem + router available with me. Please advise me how do I connect available D link 2640...
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be 192.168.0.1 or 192.168.1.1.
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
Oct 23, 2017 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Hello there, need to know how to config a phone line modem Zhone 6381 I guess its called the Zhone 6381-Ax Router. I happen to prees the reset button and losst the programed IP. how can I go about...
To configure your router, make sure you are connected to it first, open your web browser. Ignore any error about lacking a connection. Type the default IP address (192.168.1.1) into the Location field of your browser and press the Enter key. The following screen appears.
The default user name is Admin and the password is Admin. Both are case-sensitive.
Note: You should have your PCs configured for DHCP mode (if your router will be), and have proxies disabled on your browser. If you see a login redirection screen when you access the web interface, verify that JavaScript support is enabled in your browser. Also, if you do not get the screen shown above, you may need to delete your temporary Internet files.
The first screen that appears after the log in screen is the Home page.
From this screen you can configure the LAN and WAN connections, configure the router's security, routing, and filtering, access debugging tools, obtain the status of the router, and view the online help.
From here, go to the Setup Tab and click the New Connection on the left.
Input your numbers and don't forget to save.
Hope this helps!
Dec 21, 2010 | Zhone (6218-I2-200) Router
How to do internet settings manually on nokia e71
BEFORE YOU BEGIN, please note the following:
On the Nokia E71 some of VoIP settings are hidden by default, and you will need Nokia's new VoIP SIP application.
This application can be used to configure VoIP settings on your Nokia. You can create new VoIP profiles and modify the existing ones, and create and modify VoIP parameters and NAT/Firewall traversal settings and that are normally not visible on the device UI, such as codec settings and SIP domain-specific NAT/FW settings. It is also possible to save all the VoIP profile settings to a text file. It also enables VoIP over WCDMA which means you can make VoIP call over 3G Internet connection.
Using your PC you can download free Nokia SIP VoIP application from here or you can check Nokia web sitefor latest version.
Extract and install SIS file using Nokia PC Suite software on your PC.
Once installation is complete you will be able to see "SIP VoIP Settings" application under Applications menu on your Nokia, which you will need in STEP 5 of this configuration guide for better voice quallity or enabling VoIP over 3G Internet connection.
Here you can find Nokia E71 SIP settings for voip setup and SIP client configuration guide with VoIPVoIP service.
STEP 1 Go to Tools / Settings / Connection / SIP settings. Create the following profile
Profile Name: VoIPVoIP Service
Profile: IETF Default
Access point: (your WLAN AP name)
Public user name: 5551231234@sip3.voipvoip.com ( Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. When recorded your phone will show sip:5551231234@sip3.voipvoip.com )
Use Compression: No
Registration: "Always on "
Use Security: No
STEP 2 You do not need to enter Proxy Server settings
Proxy Server Address: none
Registrar Server:none
Realm: none
User Name: none
STEP 3 Enter the following for Registrar Server settings
Registrar Server: sip3.voipvoip.com (When recorded your phone will show sip:sip3.voipvoip.com)
Realm: voipvoip.com
User Name: 5551231234 (Instead of 5551231234 account number example, use the account number assigned to you when signed up for VoIPVoIP service. )
Password: Enter the password that you chose when you signed up for the service.
Transport Type: UDP
Port: 5060
STEP 4 Go to Tools / Settings / Connection / Internet Tel. Settings
Create a new profile for "voipvoip"(555123xxxx), name it "voipvoip"
Choose "voipvoip" as Preferred profile
STEP 5 For better voice quality or in order to be able to make VoIP calls over 3G internet connection you need to use Nokia SIP VoIP Application you installed.
Go to Applications on your phone and click on "SIP VoIP Settings" application. Choose VoIP services/VoIPVoIP (or the name of your VoIPVoIP account Internet profile.)
Click on "Profile Settings" and find "Allow VoIP over WCDMA" option and change it to "ON" This change allows VoIP over 3G connection on Nokia phones.
For better voice quality go to Codecs and delete all codecs except G729. There should be only G729 codec left under codecs setting
STEP 6 Reboot your phone. Once your phone is back on it will automatically register to VoIPVoIP.
Once it is registered you can start making calls.
Default call type: To switch between normal GSM calls or VOIP calls, navigate to Tools / Settings / Call / Default call type. Select Cellular to make normal calls to the phone number or Internet to use VoIP to call the number or address
Make Calls!
To dial any phone number that is part of the NANP (North American Numbering Plan), you must dial:
1 + Area Code + Phone number
To dial any phone number that is outside of the NANP (North American Numbering Plan), you must dial:
Country Code + City Code + Phone number
For example if you want to call Brazil (country code 55) phone number in Rio de Janeiro (city code 21) you must dial 5521 and phone number. + sign can also be used and number can be dialed as +5521xxxxxxx
BUT RATHER THAN FOLLOWING THESE PLS CALL TO YOUR CUSTOMER CARE THEY WIL GIVE THE SETTINGS. SAVE THEM. THEN FOLLOW THE INSTRUCTIONS. THIS DOES NOT COST ANY COST. PLEASE TRY THIS
Jul 07, 2010 | Nokia E71 Smartphone
I have Nokia E72, how can I connect to VOIP service in our office?
go to Tools > Settings > Connection > SIP settings
Profile name: any
Service Profile: IETF
Default Access point: select your access point
Public user name: sip:your-voip-ext@voip-server.com
Use compression: No
Registration: select your preference
Use security: No
Proxy server: empty/no settings
Registrar server:
> Registrar server address: sip:voip-server.com
> Realm: asterisk
> Username: voip-ext-no.
> Password: voip-password
> Transport type: Auto
> Port: 5060
Then go back to Connection > Internet Tel.
create profile and select the SIP settings you just created.
May 06, 2010 | Nokia E72 Smartphone
Connecting VOIP device without having any router, but wifi intern
hi yvo2000. Sorry, you cant do that. That router (well, the SPA2102) needs a cable from your neighbor's router in order to provide internet to the POTS jacks. Please don't forget to rate my answer if it helped you. Thank you :D
Apr 28, 2010 | Linksys Computers & Internet
Is it possible to use Voip without a direct Internet connection?? For example I use wireless Internet from my neighbors connection.
LOL!! I know with Vonage you need a hard line cat 5. With the usb things like magic jack, since that directly plugs into your computer, my assumption is it wouldn't matter whether you were wireless or not.
Aug 21, 2009 | Linksys VoIP Telephone
Using both USB and Ethernet to connect to the internet
Does your router suports usb ports, normally routers do not support usb ports, please check if your router first suports usb ports
Jul 22, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Using both USB and Ethernet port to connect to the Internet
Hi; I have used it with both ethernet and usb connections at the same time. I have never used the bridge, but I use it at home.
Try this ( I have XP SP3): Right-click on the monitors where the clock is (lower right corner), select "Open Network Connections". Go to the LAN connection and r-click "Properties". On the "general" tab select "Internet Protocol (TCP/IP)". There you select "Obtain IP address automatically" and "Obtain DNS server automatically" then click "Ok" until exit. Either Shut Down or Restart the PC. Check if this work.
Jul 19, 2008 | Paradyne 6381 ADSL2+/ReachDSL Router...
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne (6211-A2-200) Router Logo
94 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
