Question about Frigidaire ATF6000ES Front Load Washer
(Partial, intermittent) Fill after final spin: Frigidaire front loader
Sometimes, my Frigidaire front loader slowly (1-2 hours) fills after a wash cycle is complete. It just started doing this after a move. I don't know where to start troubleshooting. When I see it filled, I have pulled the soap tray and it does not appear that there is a drip.
  • eneal May 31, 2008
    Thanks. It took me two tries to get the right part, but you hit the nail on the head. After your post, I did notice a slow drip from the valve that was not easily visible from the area around the detergent tray.
    Problem solved for $28, which is a fraction of what I would have to pay a repairman to knock on my door.
  • 868 Answers
Replace the water valve and your problem is gone.
Posted on May 21, 2008
I have a Frigidaire washer 2003 model no. gitr 1670 aso front loader that will not wash or spin. Everything else works like fill with water and water drains.
Hi friend, thanks for your post!
I see that your Frigidaire washer is not washing or spinning but everything else is working properly. I would advise you to check over the drain hose, make sure it is not restricted or too far down the drain pipe. If that checks out it could be a possible problem with your motor or control panel. One of those components could need to be replaced and for proper replacement I would recommend assistance from a technician to have a proper diagnosis completed. I hope this is helpful. -Matt
Oct 08, 2014 | Frigidaire GLTF1670A Front Load Washer
My Frigidaire front loader washer drum will not turn or agitate but will fill water and drain water, what is the problem?
Hello acoach194 - If the washer is not agitating try the following steps:
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this. If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, then it will need to be replaced. If it is loose, then it will need to be tightened. A professional will need to do so by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt.
Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, once again call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem.
Dec 17, 2012 | Frigidaire FTF530FS Front Load Washer
I want the washer to fill it up but it goes to final spin
Is it a front loader or top loader? It almost sounds like a front. If so, you have a malfunction in your control panel. You will have to have GE do a test on the circuitry to verify that that's what it is. But if it's a top loader, it most likely has a mechanical timer. If THIS is the case, there's a chance that someone tried to do a second final spin then interupted it before it was done and threw the cycle off. My parents had a HOTPOINT that did that. Just set the timer to the desired starting point, and let it run from there to the end (UNINTERUPTED). This will reset it. Any more problems, let us know.
Dec 16, 2009 | GE Washing Machines
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin in final spin out
Hello harley1964dm
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Most likely cause is partial blockage in the pump or filter. refer to your manual for access to your pump filter..most manual's show you how to do this and is not a difficult procedure. Good idea to do this on a semi regular basis as front loaders do build up with lint in this area
Dec 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
No final extract spin
P-bass, sounds like your problem is in the lid switch actuator that mounts to the bottome side of the top. I have found a bunch of these actuators just missing making the switch. Therefore the intermittent problem. Solution is to just bend it enough to insure making the switch on every closure. back.
Nov 29, 2006 | Whirlpool CAM2752KQ Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
135 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
