Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
I have the opposite problem
I changed the filter on my refrigerator, and now the water in the door takes its time to stop when I release the lever. Prior to changing the filter, it stopped as soon as I released it. I have a Kenmore side-by-side, model 106.57372700 with the Pur water filter at the bottom.
  • 828 Answers
You may have air in the system. When you actuate the dispenser it opens an electric valve in back to start the flow of water. When you release the dispenser air in the system expanding will cause the water to continue to flow until the pressure equalizes.
Posted on May 23, 2008
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Whirpool Gold 21 Cu. Ft. Side by Side. Water dispenser will not dispense water. I hear the solenoid click. I think the line in must be frozen some where.
Do the following: Flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use.
Ensure that the freezer door is closed completely? Close the door firmly.
Ensure that the water shutoff valve is fully open.
Ensure that the water pressure is at least 30 psi (207 kPa)? The water pressure to the home determines the flow from the dispenser.
Check for any kinks in the home water source line? Straighten the water source line.
Check the water filter. The filter may be clogged or incorrectly installed.
if still there is problem of water flow then please take assistance of a technician to check the plumbing.
If the fridge is new and in the warranty period get in touch with the service center and ask for free service.
Feb 01, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water dispenser dripping water all the time
First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
Hope this will be useful.
Thank you
Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Please tell me how to replace the water filter and reset the "change filter" light on my Maytag Refrigerator MSD2756GEB. My light stays red after I change the filter. Thanks
The filter status display will help you know when to change your
water filter. When the display reads 10%, order a new filter. It is
recommended that you replace the filter when the display reads 10% OR when water flow to your water dispenser or ice maker decreases.
The filter should be replaced at least every 6 months depending on your water quality and usage.
Step 2
Press the eject button to release the filter from the base grille.
Step 3
Pull the filter straight out.
Step 4
Turn the cap counterclockwise to remove it from the filter. IMPORTANT: Do not discard the cap. It is part of your refrigerator. Keep the cap to use with the replacement filter.
Step 5
Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
Step 6
Remove the protective covers from the O-rings. Be sure the O-rings are still in place after the covers are removed.
Step 7
Push the filter into the base grille. The eject button will pop back out when the filter is fully engaged.
Step 8
Flush the water system. Use a sturdy cup or glass. Depress and hold the
water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat this process until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever. Hold down for 5 seconds and then release for 5 seconds. Do this on/off process for about 2 minutes. This will flush air from the filter and water dispensing system.
Take care......
Aug 13, 2010 | Refrigerators
Kitchen Aid water dispenser makes a hammering sound when in use.
this is a pressure problem . some times caused by line size . but generaly changing the water valve will correct this problem . ****
Jan 06, 2010 | Whirlpool GS6NBEXR Side by Side...
Icemaker isn't working well. Very few cubes are made and those that come out have a hole through the middle. What do I do?
Have you replaced the water filter lately? If not I would start by changing your water filter. It's down below the freezer door within the toe kickplate, push the release lever just to the left of the filter cap and at the same time pull the filter out towards you, reverse the process to replace with the new filter.You do not have to shut the water supply off to change the filter! Good luck!
Nov 26, 2009 | Whirlpool GD5SHAX Side by Side...
Brand new GE side by side refrigerator. Water in door takes 5 seconds to slow and stop after releasing lever
Since it's a new refrig , you need to call GE and have it repaired under warranty . Thru my experience , this sounds like the water valve , is not cutting off , immediately , after releasing the pad . Replace the water valve , due to possible weak spring .
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the...
when you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Oct 14, 2008 | Whirlpool Refrigerators
Monogram refrigerator side by side
Robert, it almost sounds like your water reservoir is freezing some. This is located in the back of the lower section of the refrigerator behind the drawers. You can also check to make sure the water lever is making the switch and calling for water. The next time this happens, take a hair dryer to the water reservoir and go over it lightly back and forth. See if it makes the difference. Catriver..post back.
Oct 24, 2006 | GE PSC23NHN Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
172 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
