Question about Intel D845GVSR Motherboard
Win XP & Win 98
I have used both OS in my system. I have a problem in Win 98 OS so i have format this drive & reinstall win 98. Now i can use only win 98 os. I didn't get startup choice. So How can i solve it this or reinstall xp.
Thank you for your best support. I will try & i am sure that using this i can solve my problemm
Posted on May 28, 2008
  • 165 Answers
  • Philip Markert May 28, 2008
    When you install win98, the boot sector and the xp boot menu gets wiped, use the xp recovery menu to reinstall the xp booy menu.
    Use the fixmbr command then use
    bootcfg /rebuild
    to find all windows installations and rebuild the boot menu.
I have a 40GB HDD with dual operating system Win XP & Vista. Now Win XP not work properly. So I have to format that HDD n install only one operting system Win XP. But Win XP bootable not work properly...
Hi and welcome ygshaikh !
Here is one solution ( there are maybe others ) easy to use if your pc is a desktop :
extract the hdd from your machine and connect it to a healthy computer ( in a external USB box or strait inside the pc ) . Format the drive and reinstall it in your machine . You will now be able to install Win XP .
Best regards .
Feb 14, 2011 | Computers & Internet
Trojan on HDD want to Zero out and reinstall OS
Just to make sure of a few things, you actually want to install windows 98 when you could install windows XP? and the other thing is that you do not need to acutally "Zero" the drive out -as in writing zeros to all sectors- formatting it will suffice to remove a virus.
Jun 07, 2009 | Gateway GT4022 PC Desktop
Insataling windows xp problms
i believ ur using 32 bit operating system.change the boot sequence by pressing F12 at restart and select cd/dvd rom option while the windows cd still inside the drive,,format the c drive completely{if possible format the whole hdd} and then reinstall the windows os xp..i hope it will work fine,,just follow the screen prompts very very carefully and u will find everything mentioned,,best of luck
May 14, 2009 | HP Compaq Presario CQ60Z Notebook
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Not able to install win Xp
CHECK THE CMOS SETUP OF YOUR MOTHERBOARD,CHECK THE CMOS BATTERY AND MOST IMPORTANT READ YOUR MOTHERBOARD MANUAL INSTRUCTIONS
Feb 04, 2008 | Asrock M810LMR Motherboard
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
SAN DRIVE DRIVER download free FOR OS WIN 98
Not sure what pan/san is but what I do know is win 98 is obsolete and is not supported by anyone. My sugestion is to at least upgrade to Win Xp. That should solve the issue.
Nov 19, 2007 | Microsoft Windows 98 for PC
Format a gateway hardrive
insert a windows cd...boot from it and format the drive.
How to install os
This is a little difficult but it can B done :) Firstly I dunno if ya need to re-format ya drive? perhaps first ya could try to "Repair" of Win98? If that doesn't work,then, perhaps ya may have to re-format. If the Win98 is on a SEPARATE drive or Partition this also makes a difference.... Basically ... repair/re-install win98, then do a repair of ya Boot menu for XP, as Win98 sets up an incorrect Boot up for XP, and thus must be "Fixed" so XP will boot & show a Dual boot menu.. here are some links to help you step by step... http://pcworld.about.com/magazine/2109p156id111652.htm http://www.thehindubusinessline.com/ew/2004/08/30/stories/2004083000250400.htm
Aug 21, 2007 | Microsoft Windows 98 for PC
3.5 Floppy drive
Hi, i have installed thousands of Internal Floppy drives and there aint no conflicts between win/95/98/me and xp. all discs should be compatible, unless you took it from a apple machine for example. did it work when you put in a new floppy drive? all the best John
Feb 21, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Intel D845GVSR Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
