Question about Keurig B100 Coffee Maker
B100 only dispences about 2 ounces of water
B100 only despences about 2 ounces of water
  • 5 Answers
I removed the top from the hot water tank & repaired the split hose on the intake side. I also disassembled the the right side air pump & freed up the motor that was frozen. apperantly the check valve leaks very slightly & causes some rust build up on top of the pump motor. Should any one need a new motor you can find a universal hobby motor that you could make fit. these motors run on 3 to 18 volts which should be ok. After the repairs I did a good cleaning with whit vinagar. The machine now works as good as new. Hope this helps out other people with the same problem.
Frank Urbano
Posted on May 24, 2008
New out of the box. won't dispence water to make espresso
Hi. Is your pump working. Should be able to hear it. If its making a really loud noise then it could be an air lock in the line. Try using the hot water button to bleed the system. Also see if it will despence water wiyhout any coffee in handle. Dazza REPAIRER
Sep 23, 2011 | DeLonghi EC155 Espresso Machine
My water despencer suddenly stops working after every use and will only give about 5 ounces of water then stops.Can any one help me with this problem please.
Hello, Thank You for using FixYa. I will be helping you today.Did you try replacing the water filter? It sounds like a bad filter or low water pressure to the unit.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
Dispencer doesn't work for fabric softner or bleach
Remove the lid and check the dispensor solenoid
Feb 26, 2010 | GE WSXH208A Front Load Washer
Does not dispense enough water. I get about 2 ounces of coffee at a time. How do I adjust the water level?
When was the last time the unit was descaled? A build up of scale will gradually restrict and then stop the water flow.
Feb 02, 2010 | Keurig B100 Coffee Maker
Ice despencer opening keeps freezing and wont dispence
you have a bad door seal. replacement is better than repair. warm moist air is getting in and the condensation is freezing.
Nov 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Keruig b100, no longer disperse's full cup of water
use 1/2 vinger an water and use filter no coffee should clean it out
Sep 04, 2009 | Keurig B100 Coffee Maker
Plhs67es fridgidaire refrigerator no water despence or making ice
Always remember Safty First to turn off power and water supply and only turn them on as needed!!!
I checked water supply it was great and then check the valves (solinoids) and the power and all was good. The next thing I checked was the water from the supply valve to the filter at the same time I put some water in the ice maker to make sure it was working (leave it to make sure it drops the ice). The filter was new but was defective. Water went to the filter but did not return any to the despencer or the ice maker. During the different test I performed I also found that the lines hook to valves that the filter plugged into and since the new filter fixed the problem those valves were ok but could have been the problem therefore I suggest if you have this problem remove the filter and depress the small valve with a small object (like a hollowed out pen) and call for the water to be dispenced. If the water does not spray out then you have another problem...I went threw the whole system to find a bad filter, which I thought in the begining but since the other filter was new I done all of the above.
Although I figured out the problem myself this is a great Web Site. Thank You
Mar 22, 2009 | Whirlpool GS5SHAXN Side by Side...
Keurig B100 Coffee Maker Logo
299 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
