Question about Samsung SGH-T519 Cellular Phone
Water Damage I am able to charge the battery completely. When I unplug the power the phone shuts down. Not exactly sure how to troubleshoot a water damaged phone. Any suggestions? please email me bobby.burn@gmail.com thank you.
    Sergeant:
  • 218 Answers
U must remove its battery and do not charge it before u get it serviced from a mechanic and ask it to clean its battery connectors too...
Posted on May 21, 2008
I dropped my galgaxy s3, it started randomly shutting down, then after awhile died and now it wont even charge.
The charge port might be damaged, I would recommend trying to charge the battery with another charger / phone, or try another battery.
The shutting down part, I will assume something either got loose or the power button might be cause the issue. Which means you might need to replace that, depending on the phone, it might need soldering.
The last idea I can come up with is water damage, you would have to open the phone to make sure, but I wouldn't recommend it unless you know what you're doing.
All in all I would say bring it to a repair store near you.
May 16, 2014 | Samsung Galaxy Cell Phones
1100 dead mo
Due to this phone being 8 years old, the battery may be completely dead and non-rechargeable.
You can try plugging it in and turning it to see if it turns on. If it does, but shuts off when unplugged from power, then you know the battery is dead.
Here is a link to batteries for sale.
If the phone does not turn on at all, it may have water damage or the electrical components could be shot.
Mar 03, 2011 | Nokia 1100
My mobile is damage by water how can i solve this problem
Get the Phone Out of the water. Do NOT power it on.
This may sound too obvious a step but a few extra seconds that your phone spends in water can reduce whatever chances you had of saving your phone.
If however your phone has spent more than a few minutes in water try removing the battery when the whole gadget is under water itself .
Powering up the phone when it is wet causes the maximum damage to your phone.
2 Remove the battery and SIM card
Water + battery is a bad combination for your phone. Remove the battery as soon as possible. SIM card too must be removed immediately as water on SIM cards may erase all your contacts stored in the SIM.
3 Dry the phone as much as possible
Try and pat dry the phone, the battery and the SIM card. Using a paper towel is advisable for removing water quickly.
4 Metciulously Disassemble the phone completely
This is one of the most important steps on your phone's path to recovery. If possible take your phone to a local mobile phone servicing shop and ask him/her top disassemble the phone completely for you. Make sure the circuits are not powered up by the shopkeeper.
If you are worried that disassembling the phone will make your warranty/guarantee void you need to know that phones come with Water Damage indicators which change colors with the slightest hint of water. No phone warranty covers water damage.
5 Dry all the phone components with a dessicant
After disassembling the phone immerse each component in a bowl of uncooked rice / silica gel packs. These dessicants absorb water effectively and draw out water from all nooks and corners of your phone. Heating / Vaporising the water is a bad idea cause that would leave salts on your phone's circuitry and cause corrosion and eventual death of your phone. Hence drying with uncooked rice/silica gels where water is removed by absorption is the best option. Leave it there for a couple of days.
6 Show patience and let every component lie under a table lamp for a couple of days
Now your phone is almost on its way to complete recovery provided you show Adequate patience. You may keep the bowl of rice under a table lamp for this duration . Changing the rice /silica gels though not a mandatory step, can be pretty effective and useful.
7 Assemble , Pray and Switch on!
Jul 14, 2010 | Nokia 1661 Cell Phone
My nokia 6120 classic shuts down momentarily from time to time, several times a day. what could be the problem?
Hello :
I think that your phone has water damage .
If you are sure , that there's no water damage with your phone , then try this please :
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to switch on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory setting.
By restoring factory settings your problem will be solved for sure if there's no water damage .
good luck .
rate please !
Mar 20, 2010 | Nokia 6120 classic Cellular Phone
Nokia 1661 slight water damage - test mode
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Feb 14, 2010 | Nokia 1661 Cell Phone
Phone won't hold charge
You can get a universal charger that charges the battery independent of the phone at :
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm#instructions
I got one for my phone and it works GREAT!
Sep 23, 2009 | LG enV VX9900 Cellular Phone
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
Verizon Voyager will not chage or work on battery, fine on AC
Sounds like the battery connections may be corroded, try gently cleaning them with a pencil eraser. Clean the connections on the battery and in the phone. Water damage is indicated by a red indicator in the phone. if it is red it indicates water damage which is probably why they will not replace it. If you have insurance on the phone that may be an option for you.
Apr 21, 2009 | LG VOYAGER VX10000 Cellular Phone
Water damage/charging problem
Dec 01, 2008 | Samsung SGH-T619 Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
Samsung SGH-T519 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
