Question about ASUS Maximus Formula Motherboard - 45nm Support, Intel X38, Socket 775, ATX, Audio, CrossFire Ready,
Overclocking my Intel Q6600 CPU on my ASUS Maximus Formula?
I have all the cooling I could need but i want to know how fast I can overclock my computer and be safe.  I also have 4 Gigs of Transcend aXe RAM EPP ready 240pin DDR2 SDRAM 1200Mhz (PC2 9600) running at 5-5-5-15 timing.  I have an HIS Radeon HD 3870 512MB 265bit GDDR4 PCI Express 2.0x16 HDPC Crossfire ready video card.  It also has a LG Blu-Ray/HD-DVD drive, and lastly Im running Windows Vista Ultimate.  I forgot I have an OCZ ModSTREAM Power Supply 550/620 max watts.  I use this as my HTPC and its in a silverstone case  which I also installed a multi card reader in the front on the lower panel.  I want to make this thing as fast as I can, it has all the updates for everything installed on the computer including service pack 1 for windows vista.  Can you give me some good advice please.  I know I have a very good computer and Ive spent alot of money building it, but I want it to be the monster I know it can be. Thank You, Joshua
  • 31 Answers
Q6600 can overclock reaching 4GHz on water cooling. but be careful though always watch your processor's temperature keep it as low as possible and if it overheats try lowering the processor speed and voltage.
Posted on Jun 09, 2008
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one. . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    What arethe compatible components of this kind motherboard
    CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
    - Intel® Core™2 Quad Ready
    - Intel® 45nm CPU Ready
    - FSB 1600(O.C.)/1333/1066/800 MHz
    - Intel® G31/ICH7
    - Dual channel DDR2 1066(O.C.)/800/667
    - EZ Flash2 & CrashFree BIOS3
    - 8 Channel High Definition Audio
    Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
    *Refer to for Intel CPU support list
    Chipset Intel® G31 Intel ICH7
    Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
    Dual Channel memory architecture
    *Overclock speed
    **Refer to or user manual for Memory QVL (Qualify Vendor List)
    ***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
    1 x PCIe x1
    2 x PCI
    VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
    Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
    1 xUltraDMA 100/66/33
    4 xSATA 3 Gb/s ports
    LAN Realtek RTL8102EL 100/10 LAN
    Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
    Anti-Pop Function
    Jack-detect & Multi-Streaming
    Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
    - FSB tuning from 200MHz up to 600MHz at 1MHz increment
    Overclocking Protection
    - ASUS C.P.R.(CPU Parameter Recall)
    Special Features ASUS MyLogo 2
    ASUS EZ Flash 2
    ASUS CrashFree BIOS 3
    ASUS Q-Fan
    Back Panel I/O Ports 1 x Parallel
    1 x VGA
    1 x PS/2 Keyboard
    1 x PS/2 Mouse
    1 x LAN(RJ45) port
    4 x USB 2.0/1.1
    1 x COM port
    8 -Channel Audio I/O
    Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
    1 x Floppy disk drive connector
    1 x IDE connector
    4 x SATA connectors
    1 x internal speaker connector
    1 x S/PDIF Out connector
    1 x CPU/ Chassis/ Power Fan connector
    1 x Front panel High Definition audio connector
    1 x Chassis Intrusion connector
    1 x CD audio in connector
    24-pin EPS 12V Power connector
    4-pin ATX 12V Power connector
    1 x System Panel connector
    BIOS 8 Mb Flash ROM
    DMI 2.0
    WfM 2.0
    SM BIOS 2.5
    ACPI 2.0
    Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
    1 x UltraDMA 133/100/66 cable
    1 x Floppy disk drive cable
    1 x SATA cable
    1 x SATA power cable
    I/O Shield
    Support Disc Drivers
    ASUS PC Probe II
    Anti-virus software (OEM version)
    ASUS Update
    Form Factor uATX Form Factor
    9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
    hope this helps
    Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
    System failed due to cpu overclocking. Not setup for overclocking in the bios.
    Reboot, and enter BIOS SETUP mode.
    Choose "Load Default Settings".
    This will "undo" any overclocking of your motherboard and of your CPU.
    Sep 20, 2010 | ASUS P4P800-E Deluxe Motherboard
    Maximus motherboard with intel x38 chipset won't boot
    There's a chance of overclocking, ram failure, bios failure, cpu overheat, power supply problem,etc.. But in the first step, remove everything which are inserted on the board, like power cables, processor, rams, bios battery, Pci cards, sound cards, etc.. and clean them using soft brush, also clean the mother board, there might be dust clogging the chipsets like resistors, transistors and capacitors, and reinsert everything after cleaning... I hope this will help if there's only a small problem except circuit short... Good luck...
    May 06, 2010 | ASUS Maximus Formula Motherboard - 45nm...
    Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
    Check the ASUS WEB site for your model motherboard.
    Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
    Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
    I want to buy the maximus II fdormula by asus my question is can i use the cpu cooler of the gigabytes 775?
    The gigabyte CPU cooler is for socket 775 so it shouldn't be an issue with the Asus Maximus II formula motherboard that has a LGA 775 socket.
    What CPU cooling level you need depends on what CPU you intend to use and what you will be doing with your machine. You'll also want to monitor it after installation to make sure your fan is working properly and within your needs.
    Jan 27, 2009 | Computers & Internet
    Asus Maximus Motherboard memory problerm with Corsair Dominator 1 GB DDR2 x 4
    Hi XaaX,
    Sorry to hear about your troubles. I have built over 100 machines using ASUS MB's and I've never run into a problem like yours. I'd suggest that you check a couple of things: 1) Make sure that all your BIOS/clock settings are correct, not just the memory frequency. As I'm sure you know, you need to check the CPU settings (voltage and clock speed), FSB settings, memory settings, and voltage settings, as you could be overclocked without knowing it. Also on overclocking it is sometimes a bit of luck of the draw, as some CPU's out of the same batch will overclock 20% or more and some will not overclock at all (if you haven't read about how Intel and AMD decide what speed to market the CPU's at as they come off the line, you should; I think you'd enjoy it!). The second thing I'd do is to get memtest (you can Google where to download). Make sure you get the version that runs at the system level, not the version that runs inside Windows. It is free. If you let it run for a couple of hours, it will tell you EXACTLY what, if anything, is wrong with your memory.
    In any case, you should be able to run any ASUS board at 100% of factory specs and never have a HW related crash. If you can document your saga to ASUS, I'm pretty sure that they will MRA the board for you, assuming it's still in warranty.
    I hope this is helpful. If you think it appropriate, I'd very much appreciate a Fix Ya rating on this solution. Good luck!
    Oct 29, 2008 | Computers & Internet
    Asus maximus formula
    Yea- its really simple with the Maximus Formula's (well.. I have a Maximus II Formula....)
    Under the BIOS, you should have a tab called "extreme tweaker" or something similar. Go under that and there should be a nice CPU level up option. For example, mine has 3 options: (i have an E8400)
    1.) Auto
    2.) E8500
    3.) Crazy
    Another solution is to get the ASUS utility called CPU Level Up. It installs under windows, and lets you switch your CPU settings easily. Although this may be a Republic of Gamers specific utility.. not sure.
    Jul 01, 2008 | ASUS Maximus Formula Motherboard - 45nm...
    P35 Neo2 Motherboard Jumpers
    a quad Q6600 is manufactured @ .273 overclocked from the factory. at no time should this cpu ever be overclocked anymore unlessd you are using a watercooling system that keeps the cpu @ 69 degrees for stability. anything else will burn it out. lala linda
    May 31, 2008 | Intel Motherboard
    Open Questions:
    Supreme FX II Won't work Ok, let's start from the top- Bought an ASUS Maximus II Formula mobo off of NewEgg. Open box version, since I'm an idiot. That was my first mistake obviously. So, naturally, it doesn't come with ANY of the parts it's supposed to- LCD Poster, Supreme X-FI II, nothing. yay. Anyways, I finally tracked down a sound card (the X-Fi that was actually supposed to come with the motherboard). Installed it- nothing. Didn't show up in device manager, nothing at all. So, I swapped PCI-E slots, and still nothing. (PCI-E x1). So here I am, mad that I bought a sound card from some guy that didn't work. Well, I happened to come across another one, same exact card. So I tried it, all happy and everything, as I KNEW this one worked. NOTHING. Updated the BIOS- nothing. Changed a few settings, such as turning off PnP OS, tried a couple other small things- nothing.,... I'm beginning to think that the mobo has bad PCI-E x1 slots- all other slots work though. Is there any other way they could possibly be disabled by something? Please give some ideas to try, including the simple ones- I'd like to try to solve, as the mobo did cost a good bit. System Specs: Vista Ultimate, XP Pro, 7 RC (tri-boot) (card does not show up in ANY OS) - All have updates. 4Gb DDR2 1066 (OCZ) Intel 3.0 Ghz E8400 CPU Nvidia 9500 GT 1Tb total drive space. Currently having to use a POS Soundblaster Audigy (original) To be honest, I could care less about the X-FI. I just want my FP audio to work. But the mobo has no headers- the FPAUD header is on the sound card. But, the X-FI would be a nice upgrade.... Please help- I can't afford a new mobo right now. Like I said, even give me simple solutions- sometimes we just skip the easy stuff without realizing it lol And you don't have to use laymans terms with me- I repair PC's for a living lol. Update- Tried placing sound card in x16 slot- lit up (which it did before), but still not showing up in device manager. Tried placing it in same slot my video card was in (since I know that slot works) - nothing. So, now we know its not a faulty slot. Tried disabling PCIE Spread Spectrum, CPU Spread Spectrum. Nothing. Tried both cards in all 4 PCI E slots - nothing still... Also removed Audigy while doing this. So- we know the card works, as I saw it work earlier on a different PC. We know the slots on the mobo are fine. I've tried everything in the BIOS I could think of. When I try to install the drivers- says no supported device found. Update- Took both cards up to work. Plugged into one of our shop machines- still nothing. HOWEVER. The second card that I had come across, was out of a customers machine- and of course, it works in his with no problem. So I know the card is good. Yet, it won't install on ANY other machine.
    May 08, 2009 | ASUS Maximus Formula Motherboard - 45nm...
    ASUS Maximus Formula Motherboard - 45nm Support, Intel X38, Socket 775, ATX, Audio, CrossFire Ready, Logo
    160 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
