Question about Ovens
Monitor 422 oil stove error codes
I have a Monitor brand oil stove heater, and it is showing me EO1, I live in the bush alaska and i can't find a manual for it can one of you guys show me what that means
  • kadak Jul 28, 2008
    Monitor 422 error code E01. Stove had been completely reconditioned by Monitor tech and ran fine for about a week then sat unused for 3 months.
  • Anonymous Dec 07, 2008
    I have a 441 with the same problem??? Anyone know what it means????
Put some lime say about 2 tea spoons with about 3 oz of synthetic 4 cycle engine oil
yhen heat to 188 degrees
pour about a cup of red devil drain cleaner into da mix
add 4 oz's of duck weed then add to fuel
wait a week and then turn on da stove
Posted on Sep 18, 2008
How to replace hinges for Defy 422 stove
Im not finding this model #422 are you sure its correct?
You may be able to find the manual located here once you check the Model # search here hope this helps?
Jan 07, 2016 | Ovens
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
Error code F5E1
According to the manual, If the error code is a letter followed by a number, you need to reset the display.
Press LOWER OVEN CANCEL / OFF, UPPER OVEN CANCEL /
OFF or CANCEL OFFIf it comes back it needs to be serviced call
1-800-422-1230.
Please rate my solution, Thank you
Oct 26, 2012 | KitchenAid Architect Series KEBC107KSS...
We have a neighbor who just got a monitor oil stove. She does not have the book. It keeps saying E13. We aren't sure of the model but could you help answer why it says E13
E-13 indicates no fuel to the heater. Look on the bottom right side of the heater. You'll see two small screws and a large screw. Shut off fuel flow to the heater. Make a U shaped channel with a piece of heavy duty aluminum foil and place it under what you see there. remove the LARGE screw. This bleeds off any fuel in the sump. Now remove the two smaller screws and the plate and gasket. Pull out the spring which is connected to the stainless steel filter basket. Clean the filter with GUMOUT. Use a Q tip with GUMOUT on it and clean out the recess where the filter element went. Re-assemble the chamber, turn on the fuel and start the heater. Press the RED button. This will release the internal float.
Dec 19, 2010 | Ovens
Error code shows E1 -F3- on a
F3 E1 IS THE OVEN SENSOR IT IS ON THE BACK WALL HELD IN BY TWO SCREWS IT LOOKS LIKE A ROD,MOST OF THE TIME YOU CAN PULL ITHE WIRES THROUGH OR YOU MAY HAVE TO DISCONECT FROM BEHIND
Jan 12, 2010 | Kenmore Ovens
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Power went out. Back on now, monitor won't show on range. Can't set clock, so my stove won't work now. Any suggestions?
HI, you will need to replace the EOC/clock. the power surge has fried the chip set. Replace the control board.
Jun 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Ovens Logo
805 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
