SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
SOURCE: Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
SOURCE: after rebooting my cpu my mouse stopped working.
Did you try to reboot?
Do you have an optical mouse? (if yes: is the red light on?
(Then the mouse is recognized and you must configure your mouse options)
Did you try to connect your USB mouse to another connector?
Or if PS2 connector: Turn of the pc and connect the mouse and power on.
Did you install a new driver? (then uninstall this driver)
Try looking for the most recent mouse driver on the manufacturer site.
SOURCE: HP Pavilion a1610n will not boot up. I get the
You are probably installing a version of XP which is prior to service pack2.
Only SP2 or 3 will have the native drivers to get you machine functional, then you can use the HP motherboard drivers disk.
See the procedure on the microsoft website or other tecchie sites to SLIPSTREAM SP2 files on to your licensed SP1 disk and create a bootable copy.
SOURCE: acer aspire m5620 freezes, no mouse, monitor shows
Hi..
Restart your PC and keep tapping F8.. choose startup repair and let it diagnose and fix --
Hope this helps !!
