Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Westell versalink 327w i need default password
Im try to add my new laptop to my wireles modem but i never got a password
  • 5 more comments
  • phibetasigma Aug 20, 2008
    how do I make my laptop work with the westel model 327w
  • ktidd Sep 16, 2008
    I have a westell versalink 327w. I was never given a user name and password to open up versalink gateway password. any ideas?
  • nocturne Nov 07, 2008
    i can't access the setup for the VersaLink 327 W modem, and my MacBook can't seem to see it.
  • debbrunnett Dec 02, 2008
    I want to be able to not let people on my network.
  • Anonymous Dec 21, 2008
    need password to connect by wi-fi
  • lakeside2814 Dec 21, 2008
    need password to connect wii
  • Anonymous May 21, 2009
    i recently got an ipod touch and i need my internet password so i need to know ho to login to my westell 327w so i can get or change my password. no i dont have a manual.
    Problem Solver:
  • 4 Answers
If the 327 was never set up for wireless you need to connect to it with an Ethernet cable and plug that into your Mac and one of the RJ45 ports on the back of the 327. Type http://192.168.1.1 into your browser, this should take you to the Westell Home Page (Your Router). The default for wireless in this router is disable. There are tabs across the top on the page, select Configuration>Wireless>Basic. This opens the Wireless Operation Window. If Wireless is disabled, click arrow to enable. You can also enable and disable encryption in this same window and if you choose to use the basic WEP in the device, the WEP key is on the label on the bottom of the router. If all this is good your laptop should be able to detect the wireless connection, the default is the serial number on the bottom of the router so you will know which connection is yours. REMEMBER TO CLICK SAVE before exiting the window! Hope this helps.
Posted on Nov 10, 2008
I think the password is "password".
Posted on May 25, 2008
  • 3 Answers
Use serial number
Posted on Dec 06, 2011
  • Sue licatese Dec 06, 2011
    That should be wp number on bottom of router
Posted on Feb 10, 2011
I reset my router but what is new password is my rougter?
here is the manual - there should be non but if this is a device from a telecom, it will be their default password and username.
http://www.westell.com/docs/support-documents/327w11_06_ug.pdf
Apr 12, 2014 | Westell Versalink 327w Wireless Modem...
Change Password
you will have to reset it. there is a small inverted reset button, hold it in for 30 seconds and it will reset to factory default. There will be a factory default user and password you will need to use at that point.
Oct 09, 2012 | Westell Versalink 327w Wireless Modem...
Need to reset password
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
•All your settings will be lost including network encryption information,
MAC Address filtering information, and any SSID information you have entered.
•The gateway user name and password will revert to the default of Admin as the user name
and Password as the password.
•You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network
configuration. This includes the default SSID and network encryption key.
You must re-configure your VersaLink gateway to match your previous settings
that were assigned to all other devices on your wireless network. Otherwise,
no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or
solves the issue, please rate it and give a testimonial for my response
Dec 04, 2011 | Westell Wirespeed VersaLink...
Westell versalink 327w from bellsouth can't connect
Howdy,
I do not think this modem will work for you. Contact O.T.C. to be sure. For a few details...
I presume that you can access your Westell wireless modem/router 327w with the IP address of - 192.168.1.254. (Or you can simply type "launchmodem" in the address bar - (one word - no quotes)) This will definitely get you in. You will then see the setup menu. If you see the Bellsouth FastAccess Internet Service logo then you know you definitely have a Bellsouth modem.
Now, let's presume, you are using a Westell wireless modem/router 327w made for Bellsouth/ATT. If this is the case, as stated above, you will see the Bellsouth Logo on the setup page. Additionally, it is stated on the page below, that you cannot use a Bellsouth modem/router for any other ISP (Internet Service Provider) This is due to the Bellsouth/ATT firmware that Westell builds into this modem/router.
This is the page link:
http://www.dslreports.com/faq/bellsouth/3.141_Westell_327W__wireless__Info#13772
This is the relevant quote:
"The BellSouth supplied 327W (model C90-327W30-06) is made exclusively for BellSouth FastAccess. They are functionally different from retail Westells (or any model designed for use with other ISPs) and the firmware between them are not compatible and can not be interchanged."
That being said, you still might attempt to use this 327W with orlando telephone company but I do not know if it will work. (Doubtful...) I use the Bellsouth 327W and it is GREAT. (With Bsouth/ATT) Good luck.
P.S. - Please be advised that Westell does manufacture an identical 327W that does NOT have the Bellsouth/ATT firmware.installed. This is the "generic" version I suppose but I have no experience with this one. If you need more just ask. :)
Good luck,
J
Oct 07, 2009 | Westell Wirespeed VersaLink...
I need the key towestell 327w router
The default user/password is "admin" & "password". If that doesnt work then you'll need to reset the router if you forgot the login password. The tiny reset button is on the back or underside.
Jun 17, 2009 | Westell Wirespeed VersaLink...
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
I have a westell versalink 327w date on the bottom is 07/2007
You'll need to go into the administrative interface of the router and enable the wireless network and then you should be able to see if from any laptop/PC with a wireless networking card in it.
Feb 05, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
VPN through Westell Versalink 327w
do you have login access into the Modem/Router?
if yes, look for port forwarding and set it to your IP of your computer. open port 500 or what ever is required by MS fro the VPN
Nov 01, 2007 | Westell Wirespeed VersaLink...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
6,624 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
