Question about Kenwood VR-209 Receiver
Un-known red light
This isn't rally a problem but once in a wile i get a red light on the side of the screen where it says clip indicator. what does that mean?
  • todd w
    todd w May 21, 2008
    i was woundering what that was thanks.
Your bass in to high on the receiver or you need to upgrade your speaker wire to handle the power given to your speakers. Or you speakers can not handle the power of the amp. but 1st try adjusting your Bass Level down some to see if that works.
Posted on May 21, 2008
KNOCKING SOUND EVERY FEW MINUTES
Could be the ice dropping, could be the auger moving which it should do once and a wile, your compresser could be short cycling and turning on and off irraticly which means your thermostat isn't working properly of the condenser is plugged off and needs to be cleaned ASAP. Or the freezer fan could be hitting some ice build up
Sep 06, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My ps3 isn't working. It turns on but it dosen't go to that main screen where you can choose the user. i have had it since last christmas. but i don't think that's a long time. can i do...
Do you just have a blank black screen once powered on? If you hook up the controller with the usb link cable, do the lights on the controller flash all four or is the 1 solid? If they are flashing, then you have what is commonly known as the Green Light of Death. It's when everything appears normal but no picture. If you have no flashing red lights on the controller, please post. MikesPS3repair(dot)com.
Sep 22, 2011 | Sony Playstation 3 (PS3) Console
After I changed my Toyota Yaris (2006 model) battery, the audio system is dead with message SEC indicated on the screen. How could I resolve this? Thanks. Patrick
Issue with Date & Time Setup... Please enter Date & Time then Unit will turn on .... Press and Hold power wile you pressing on Volume un and down for date and time ...Good Luck
Oct 06, 2010 | 2007 Toyota Yaris
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
I have a 86/87 Nissan king cab SD 25 diesel truck. The right side rear turn indicator light doesn't work . Its not the fuse and it's not the bulb. I need a wiling diagram.
its probly a stripped wire in the back wher the wires split 2 go 2 each side. check the red wire with wire tester 2 locate wher you have power up 2
Feb 13, 2010 | 1986 Nissan King Cab
Red light stays on after changing the water filter and running about 2 gallons through it
Light (select models)
To Reset Indicator:
successfully reset.
Nov 27, 2009 | Maytag MZD2665HE Side by Side Refrigerator
Change filter light
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Only red light bliking, no screen
the red blinking light is indicating that you have a missed call, unread message, or unread email.
which makes sense if you cant see the screen.
holding the power down for 5 seconds doesnt do anything?
how about pulling the battery and replugging it in and turning it on via the Red hangup/power button?
this is known as hard-resetting the handset.
if its under warrenty you might be able to get the screen swapped out.
Jul 14, 2009 | RIM BlackBerry Pearl Smartphone
Color is mostly yellow and blue with double images
you have lost the convergence IC`s in your set, this really isn`t a diy repair unless you are very proficient in un-soldering and re-soldering components, once replaced there will be an alignment procedure as well that will require the service manual also, if you have more questions feel free to ask away, video-tek
Feb 04, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Kenwood VR-209 Receiver Logo
103 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
