Question about Sony Computers & Internet
Blending? i cut a track in the middle and i brought add the beggining and the end of track together but you can tell there is a skip at the joining point and i had tried to clean the skip but cant figure it out.....can you please tell me how to do it?
  • 75 Answers
Posted on Jun 11, 2008
Need to disconnect water line at back of frig to move it temporarily while floor is replaced. Connected with compression fitting and ferrule.
You may be forced to cut the copper pipe and buy a new compression fitting and ferrule and add it to the cut off end of the copper tubing when you decide to re-hookup the refrigerator.
Remember to cut the pipe , if you choose to do so, with a tubing cutter so as not to "smash" the cut end.
This problem can happen any time dissimilar metals are joined, they can "freeze" together.
God bless your efforts.
Apr 07, 2016 | Freezers
Pel job 250 track removal procedure
First step is to remove any tension in the track by loosening off any adjuster rollers or springs.
the normal method to remove tracks on a machine is to remove a pin about the middle of a front sprocket in the track and then back the machine along the track until the undone part falls to the ground
jack the machine off the track and work on the sprocket. Replacement is to tie the end of the track back onto the drive sprocket and drive forward until the track is on top of the sprocket. undo the tie and retie it to the front sprocket and continue to slowly drive forward. eventually the ends of the track will be almost together. One end will be on the ground and the other end will be just above it . Use some method of holding the two ends together so that the pin can be reinserted.
If it is a small machine and runner tracks you may be able to undo a pin in the middle at that top and just lay the ends back wards and forwards. fix the sprocket and then pick the ends up and rejoin.
Feb 20, 2015 | Cars & Trucks
How do I replace power cord for a hoover u6311?
Well if your not good at soldering I would go to the hardware store and buy a adapter that will join the two halves together cut the called where any short or cuts/grading is and add the new adapter and the new cord.
Jun 28, 2014 | Bissell 6594 PowerForce Bagless Upright...
Windshield washer flood sprays out near my fender, how do i attach the hose
Sounds like the hose has separated or been cut, find the joining end and marry them together, if it is split, cut it and rejoin it, good luck
Oct 28, 2013 | Jeep Liberty Cars & Trucks
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 | Toys
Alpine CDM 7874 won't play rest of CD after track 1.
It could be a bad burn or an issue with the receiver. Try re-burning the CD and see if that helps.
Jan 14, 2010 | Alpine CDM-7874 CD Player
VW Polo disconnected electric window wire
Yes, add a piece of wire, so they can flex, and twist together and cover with electrical tape.
Dec 14, 2009 | 1995 Volkswagen Jetta
How do I join two tracks that belong together?
Are you talking about playing the tracks back to back? If so, make sure that the tracks are in the same folder under "albums". Go to the tracks file property and make sure the track numbers are correct.
Apr 23, 2009 | Creative Labs ZEN V Plus MP3 Player
Turntable swingarm skips to last song
Most likely your stylus (needle) is bent, broken or missing. Check to see if it's there or not. If it's broken or damaged, you will need to replace it. Under the cartridge, you should see a small arm that has the actual diamond on the end of it. If the arm is there, but the diamond is missing off the end, the arm won't stay in the groove and will instead skip across the record to the middle.
Mar 01, 2009 | Sony PS-LX250H Turntable
1999 Sable Brake line fluid leak
Cut that out. Replace it with a compression fitting. Bleed the system.
Feb 27, 2009 | 1999 Mercury Sable
Computers & Internet Logo
27 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
