Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Colour misalignment and focus
Hi I own a Phillips rear projection TV model 55pp8620 around the edges the colours are out of alignment and focus while the centre of screen is fine. I have tried to adjust without success. Does it need the lamps replacing ? Or some opther problem ?
Cheers AL Hi there,
I own a Philips 140cm rear projection TV model 55PP8620 at the bottom left hand corner of the screen it is starting to turn yellow. I rang Philips and they suggested it that the oil needs changing. I never heard of this before. I rang the service centre centre and they quoted 4 to 5 hundred dollors to fix. Does this sound right and if so I fix it myself?
Cheers Tony
  • winter1 May 23, 2008
    Considering the price involved to fix I agree the best course of action is to buy a new TV....Thanks
  • phillW Jun 08, 2008
    Having just spent $680 replacing the convergence ic's now they claim the digital module is faulty also. Is it worth fixing? I dont want to just walk away away being that im into it for near 700 bucks already, what should I do?
    55pp8620 (australia)
    Habit-Forming:
  • 55 Answers
I just had my convergence fixed and now I am having problems getting the right colors matched up from the panel inside the tv. You know where the RGB and focus settings are? Is there an easier way of adjusting this? I have spent hours on this and still always have blue grass or green hair, any suggestions? Thanks alot! And buying a Plasma is out of the question right now unfortunately. Thanks.
Posted on Jun 22, 2008
    Genius:
  • Philips Master
  • 1,689 Answers
Inside of the tube assembly, there is a cooling liquid. This could be a job to change, and then re-adjust everything. It is also possible that on top of this, there are problems with the convergence and bias control circuits.
Typical repairs can run in the area of about $400 to about $800 depending on the amount of work and type of parts required.
Personaly, I would go out and get a good Plasma or LCD TV at this point!
Jerry G.
Posted on May 21, 2008
Size of phillips 55pp8620 There is no picture and
Good day!!!!
I need to know first if your TV is on standby mode (red LED lit) or not?..If the green light lit your TV your high voltage (HV) is switch but you have open line on heater that cause of no picture and the sounds is chirping because of analog(antenna)/digital connection or bad audio chips..
I need this information above for specific diagnosis and to prevent more damage and failure..Also I need this information to avoid mistakes to buy a parts with no help...
also I need the model # because on my tread there are 2 model # which are correct? is it 60PP9202 60" or 55PP8620?..for specific diagnosis and for possible get a diagram..
Thank you very much for choosing my service!!!!
Rossiel Gomez (nineng)
Jan 20, 2012 | Philips 60PP9202 60" Rear Projection...
Out of focus doble colours
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Samsung HCM4215W 42" Rear Projection...
Colours on the right side are unbalanced
run auto convergance from the menu it might be called touch focus on that model
Nov 21, 2009 | Toshiba 42H83 42" Rear Projection...
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
Hitachi 43FDX20B 43 in. Rear Projection Television magic focus
Hi, replace the convergence IC`s and any fried resistors and chemical fuses (if any), do not push magic focus anymore it will not correct the prroblem and it will evenntually corrupt the DCU and cause you more problems (and of course more money), questions? ask awayy, video-tek
Feb 02, 2009 | Hitachi 43FDX20B 43" Rear Projection...
You need a new convergence board. Not an easy fix, sorry.
Nov 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Philips Rear Projection Model 55PP8620 - convergence problem
Manufactures sometimes contract with other tv companies to build their tv. Regardless of the internal hardware you still have a philips tv. I beleive this set was made by Hitachi. And what you are looking for is a replacement board. This board is referred to as the small signal module. When contacting a rebuilt board, have the model# and the chassis# available. And contact PTSELECTRONICS.com or Andrews Electronics.com. The board you seek is in the rear lefthand side on the floor of the TV. You will see a pair of tall aluminum fins. Theses are the heatsinks for the convergence ICs. I would definitely replace this small signal module, as repair on the local level will require pulling the board in and out of the tv several times. The company will give a part number and then you may order this. Striving for success the first time!!!!
Sep 13, 2008 | Philips (867093110009) Projector Lamp for...
If you feel dull image and any yellow color problem you can change the lamp other wise no need to change the lamp.
There will be patten settings are there. so please inform service center service engineer will do this job.
Regards,
Prakasam
Feb 17, 2008 | Office Equipment & Supplies
Samsung SP42W5HFX colour misalignment
Hi. Did the ngineer say that it was problem with convergence pcb ? To be honest the lil git hitting the screen is more likely to damage the screen than convergence. Try going in to the menu then convergence & adjust red & blue to try & get the crosses white with no coloured halo around. Post on here with results your model of tv is pretty straight forward I work for an indepedent tv repair shop the manuals are easy to get hold of thats if he even needs one. Chris..
Oct 06, 2007 | Samsung HCM422W 42" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
