Question about Nokia N95 Cellular Phone
The phone will not turn on
I turned the phone off and it wouldn't turn back on when i pressed the powere button
  • Anonymous Jun 06, 2008
    I turned the phone off and unable to turn it back on. I took the battery out for a while, still nothing. The battery is fully charged.
  • kez1 Jun 23, 2008
    I have an N95 that the power on button has broken. Are there any other short cuts to turn the phone on? I want to remove all my precious photos before I send it for repair
  • 3 Answers
All your power button does is short from one side to the other so access your power button & put something metal from one side to the other, across where the power button is soldered to, wait a few seconds & it will switch on. Remove your back cover by simply peeling it off, check youtube for the video, takes a few seconds.
Posted on Jun 23, 2008
N95
    Sergeant:
  • 282 Answers
May I know what is your phone model?
Posted on May 21, 2008
How to reset blu neo jr
Since you didn't suggest which one you wanted, soft or hard reset, I have included answers for both:
To Soft Reset. First method:
1) Remove and replace the battery.
2) Press the Power Button.
Second method:
1) Press the Power Button until the menu which shows "select option turn off phone" appears or
Third method:
1) Press the Power button until the phone turns off, then press it again until it turns back on.
There are a couple of methods to hard reset your Blu Neo phone back to default factory settings.
1) Depress the power button until the unit is on.
2) Browse to Menu > Settings > Privacy > Factory Data Reset > Reset Phone.
The resets your phone to out of the box settings. Only to be used if you wish to return the phone back to the condition it was in when you first purchased it.
The second is to:
1) Turn you phone off.
2) Hold the Volume Down and Menu and Power buttons [all three at the same time]. Hold all three fingers down on those buttons until you see the Recovery Menu [it may take a few moments], then release your fingers from the three buttons listed above.
3) Select "Wipe Data/Factory Reset" using the volume buttons to navigate between the choices. The use the Power Button to select the choice.
4) Confirm "Yes - Delete All User Data"
Either of these two methods will reset your Blu to its out of the box configuration. BE SURE you have a back up if you wish to restore your settings.
I hope this helped you.
Mar 13, 2015 | Blu Cell Phones
My Kyocera Event 3g smartphone keeps turning off and on by itself over and over again every time i take the battery out and put it back in i don't even have to press the power button because it turns on by...
Sound like you have to restore the phone and if still persist..phone replacement if battery is good.If you have an SD card in phone remove it please. Make sure your picture and contacts are backed up to SD card. This will take phone back like new.
    • Turn off the phone.
    • 2 Hold down the "Volume," "Power" and "Home" buttons at the same time. Continue holding the buttons until the 3-D Android logo and a menu of system options appears on the screen, and then release the buttons.
    • 3 Press the "Volume" button to scroll through the menu options and highlight "Wipe Data/Factory Reset." Press the "Power" button to select the option.
    • 4 Use the Volume button again to highlight "Yes, Delete All User Data," and then press the "Power" button. The Event deletes all your personal data and settings from the phone and then returns to the first menu.
    • 5 Highlight "Reboot System Now," and then press the "Power" button to restart the phone. After several minutes, the Event starts up and opens the main screen, giving you the option to set up the phone just as if it were brand new.
Feb 10, 2015 | Kyocera Cell Phones
Can I reset my htc pd53100 without turning the phone on?
Performing a factory reset while phone is turned off
1. Press and hold the VOLUME UP, VOLUME DOWN and POWER/LOCK SCREEN buttons.
2. When prompted, press VOLUME DOWN to perform the factory reset, or press any other button to cancel the reset.
3. When prompted, press VOLUME DOWN to turn on the phone.
If your phone hangs or freezes, remove the battery, wait for a few seconds, and then put it back in. After reinserting the battery, turn the phone back on.
Jan 01, 2013 | HTC Freestyle F5151 Pd53100 Unlocked...
I was updating my iphone 4s and decided to turn it off in the process of updating as the internet connection was too slow. When i tried to turn it back on, it just wouldn't load. What should i do?
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 31, 2012 | Apple iPhone 4S
Lenovo P650WG Phone Won't turn on
5.Wait 10 seconds.
Step
Thanks
Aug 04, 2012 | Cell Phones
Iphone shuts off and won't turn back on what do i do?
You might try holding down the power and home buttons at the same time. Wait until you see the silver apple. Thats what I did when mine wouldn't turn back on.there is an easier way instead of just guessing....
when you plug it into any form of charging source...just completely shut down your iphone...and leave it there for how ever long it takes to charge...(to be able to use it again is about 30 minutes)depends on your energy sourceFirst open iTunes and Conect your iPhone cord to your computer, but do not plug it into your iPhone. Then press and hold the home button on your phone while conecting the iPhone cord into your iPhone continue to hold down the home button. Then click restore in iTunes
Feb 15, 2012 | Apple iPhone 4 Black Smartphone
Network failure
Call customer service from your service provider.
AT&T Customer Service 1-800-288-2747
You can also try a soft reset on your phone with the phone ON remove the battery wait 5 seconds put the battery back in the phone and turn it back on. Or you can do a wipe/hard reset
Samsung GT-i9000 Galaxy S hard reset
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 master reset
Aug 16, 2010 | Samsung Galaxy S GTI9000 Smartphone
I clicked reboot not my iphone wont turn back on what do i do????
Iphone Connect With Itune
Turn Off Your Phone
Press Home Button for 5 Second
After 5 Second Press Power Button for few second
Release Power Button
Still Holding The Home Button
Itune Detect Your Iphone In D.f.u Mode
Release Home Button.
Jan 20, 2010 | Apple iPhone Smartphone
What is the tiny black button on the back of my black berry storm for? Its behind the back cover.
New Power / Lock button usage
Using the Power or Lock button on the top of the BlackBerry smartphone, you can perform the following tasks depending on the state of the BlackBerry smartphone:
State of the BlackBerry smartphone: Unlocked and the back light is turned on
Action: Press and release button.
Result: Locks the BlackBerry smartphone and turns off the back light.
Action: Press and hold button.
Result: Turns off the BlackBerry smartphone.
State of the BlackBerry smartphone: Unlocked and the back light is turned off
Result: Turns on the back light.
Result: Turns on the back light and displays the power off prompt.
State of the BlackBerry smartphone: Locked and the back light is turned off
Result: Turns on the back light and displays the unlock prompt.
Result: Turns on the back light and presents the power off prompt.
State of the BlackBerry smartphone: Locked and back light is turned on
Result: Presents the unlock prompt.
Action: Press and hold.
Result: Presents the power off prompt.
Oct 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Phone won't turn on, took battery out and put it back in, still won't turn on, it acts like it's about to turn on and then blinks back off. Battery is charged up, I've only had it for 4 months
When you power up first let it going into off chargeing mode, then hold the power button to turn it on, continue to hold it through this whole process, then after the sitck together box has been completed (which may take a few attempets) rapidly push the right soft key until your phone jump in and out of the t-zones area which should be your default right soft key buttong then you should be able to use your phobe normally, note that it did take me a good half an hour of doing this to make my phone through the whole process. :)
Nov 04, 2007 | Samsung SCH-u340 Cellular Phone
Nokia N95 Cellular Phone Logo
102 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
