Question about Kodak Digital Science 3520DP Path-Through Scanner
TROUBLESHOOTING A KODAK DS 3500 SCANNER COMMUNICATION ERROR
I'm working on a Kodak DS3500 scanner that is giving me a can't communicate error.(check the cables and card)
Also I'm looking for information on testing the circuit boards or other hardware inside the scanner.
Thanks in advance for your assistant
Andre
  • Anonymous Mar 25, 2009
    same problrm
2 Suggested Answers
  • 14 Answers
SOURCE: Kodak DS3500 scanner
Are you using a Kofax SCSI card or an normal SCSI controller like Adaptec?
By using a normal SCSI controller, is there an ASPI driver problem after a WIN XP update? After an update check the ASPI dlls in \sytem32. They should be version 4.71 or higher.
Check the SCSI connector pins and the terminator.
If available change the cable.
Scanner check:
Is the green lamp (Ready) on or is the red lamp (Error) on?
- green lamp on:
the internal self test is ok, but the internal SCSI interface may possibly faulty.
- red lamp on:
the internal selftest detect an error.
It's possible that the DC/DC power board, the CPU board or the power supply inside the scanner is defective.
After reassembling the front side camera you will see at the bottom a PCA board with some LEDs whitch indicate by red light the different voltages when power is on. You find the different voltages printed at the PCA close to the LEDs.
In case on or more LEDs don't shine the according DC/DC transformer on the PCA is defective.
Futher you see LEDs at the camera PCAs. They should be on too.
In case the CPU board has an defect you must have an special Kodak activation tool to unlock an new or used CPU board after exchange.
Posted on Jul 18, 2008
How to fix half of a ds without screwdriver nor black and white whire
First, learn to communicate better. Your issue is indistinct and your question is unclear. Proper communication skills are necessary, especially when trying to troubleshoot technical issues. If you are no more capable of communicating in writing than what you wrote, just give up.
Second, BUY A SCREWDRIVER.
Jul 20, 2014 | Nintendo DS Lite Console
"cycle error" - scanner powers up ok but will not scan due to this error ID=055
Error 55: "Lamp I2C error reading from DAC". Operator log message: "Cycle power, if problem persists, call service.". This error is involves communication errors between the LED AY and the DAC. A couple things can be done to alleviate this issue but unfortunately, as a user, you can only perform the first step. The other steps require a Kodak Field Engineer to complete. First step, upgrade your Firmware. Firmware updates can be found at the following web page: http://graphics.kodak.com/DocImaging/US/en/Support_Center/Document_Scanners/Production/i5200_Scanner/Support/Drivers_And_Downloads/i5000_Series_Scanner_Firmware/index.htm. If you still experience issues following the firmware upgrade, call Kodak Service & Support to schedule a field engineer to be dispatched to your site.
Mar 03, 2014 | Kodak i5200 Document Scanner
Kodak ds 3500 science is showing red light on LED after i have serviced the scanner. Please help resolve the issue
If you used alcohol or abrasive cleaner to cleaned scanner it will ware out the reflective tape/sensors in scanner. You should replace all the reflective tapes.
Jun 03, 2011 | Kodak Digital Science 4500D Path-Through...
Where can i find a manual for Kodak ds Scanner
There is an online version here at fixya. Here's the link.
http://www.fixya.com/support/p308736-kodak_digital_science_3500d_path_through/manual-4679
Good luck & peace-out
Feb 26, 2010 | Kodak Digital Science 3500D Path-Through...
Kodak i250 can't communicate with the scanner
I found it was a Microsoft update. Re-built the PC with XP sp2 no updates or patches all working again
Feb 13, 2009 | Kodak (R) i250 Simplex Scanner
Scanner check:
- green lamp on:
- red lamp on:
Jul 12, 2008 | Kodak Digital Science 3520DP Path-Through...
E40 error message on Canon DR5020 scanner
The error code E40 is caused by communication failure between CPUs- " Can't communicate with CPU on on Pick-up control CPU(80_SUB)".
The solution is" Check the connection and replace the PCB." This solution also applies to error codes: E41, E42 and E44.
Hope this information is helpful.
regards, TechSatya
Jun 30, 2008 | Office Equipment & Supplies
SuperPen (Wizcom) does not Communicate with PC
Just bought the pen and I've got the same problem. I've tried 2 PCs, one with XP SP2 and the other Vista (using Vista driver from Wizcom). Both give me the same "cannot communicate with Pen" error message. I've double checked every recommendation I could find on Wizcom's website and the internet, but looks like either the cable or pen is faulty. Would be good to know if the new cable they're sending you fixes the problem.
Jan 11, 2008 | Office Equipment & Supplies
Kodak Digital Science 3520DP Path-Through Scanner Logo
586 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
