Question about Car Audio & Video
Car Audio I have a 2005 Pathfinder, with stock speakers and everything, I was wanting to get a sub and all that! Any reccomendations?
    Problem Solver:
  • 8 Answers
Find out if the stock stereo has RCA line level outputs.
If it doesnt, you might want to use a speaker level to line level adaptor box. This will drop the amplified signal that runs your speakers to a low level you can feed into the amp.
If it does have the RCA lines, those would be preferred.
Choose an amp that puts out at least 200 watts RMS. Many amps are overrated. Look for the RMS rating in the fine print.
Dis-reguard the "Peak Power" ratings. They dont mean a whole lot.
The box the subs are in is one of the most important things in the system, because if the box doesnt preform right, you simply wont get the bass. You might get a box at a second hand store or garage sale that would out preform some of the boxes you might find at a WalMart. (The design of the box is everything)
Then make sure you get some quality subs in the box.
Also remember that sometimes a SMALL, quality sub could out preform a LARGER sub of lower quality. Theres no need to use up all of the cargo space in your vehicle for the sub and not have room for anything else.
God luck!
Posted on May 27, 2008
Custom center console box with a sa-8 (8" sundown audio sub) with it no higher the the stock jump seat in a 2005 dodge ram 1500 with sub facing down.. is this possible
If you are removing the jump seat, i would just mount the sub facing rearward to the back of the cab, and port firing down(aeroport),or slot port forward.
the12volt.com has some great box port calculators.
Jun 13, 2014 | Car Audio & Video
2005 nissan pathfinder xe 8 speaker wiring COLOR
Check this for...
2005 Nissan Pathfinder with Bose Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: Green
Car Stereo Amp Trigger Wire: Green
Car Stereo Amplifier Location: Under the Driver Seat
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
2005 Nissan Pathfinder Car Radio Wiring Diagram
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Left Front Speaker Positive Wire (+): Brown
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 20, 2011 | 2005 Nissan Pathfinder
I bought a sony deck to replace the bose stock deck on my 1996 nissan maxima. I purchased the wiring harness and antena adapter also. I hooked everything up right and getting power but im not getting no...
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
Jul 02, 2011 | 1996 Nissan Maxima
Trying to put ported reccomended subs in sealed box.
Well, 1.6 cubic foot for a 15 is not nearly enough. A ported box for 1 15 should be in atleast 3 cubes by itself. I suggest building a new box yourself or getting someone else to do it for you. If factory specs on those subs is no larger than 3 cubes per sub then I'd get the box built to 3 cubes per sub after all displacement and tune it in the upper 30's range. Putting big subs like that in a small sealed enclosure can and will damage a sub. and if you try to port an enclosure that is too small to begin with that will also hurt the woofer. Do it right or learn the hard way.
May 26, 2010 | Kole audio KMX-15 Car Subwoofer
Hello, need to know how i should wire a single 14" sub spk to my ST4-720 ??
havent heard of too many 14" speakers... but it all depends on what ohm the speaker is. single 4 ohm- bridge it on one set of channels. left + right- . if its a dual 4 ohm i wouldnt reccomend using it at all. you could technically bridge each coil on each set of channels. but it may not sound right. kinda hard to set the gains and match them. dual 2 ohm- run the sub stereo. one coil to one channel, the other coil to the other channel. single 2 ohm. dont use it unless you get another sub like what you have. then run it stereo. one sub to one channel. the other sub to the other channel.
Dec 27, 2009 | Sony ST4-720 SPL 4-Channel Power Amplifier...
Front Speakers And Stock Sub Stop Working HelP!!!
do you need all this noise whilst driving the car,could you hear an emergency vehicle ??check the fuses first and connections ,try speakers direct to radio
Nov 11, 2008 | 2005 Nissan Sentra
Do i need compassitor i have stock radio with brand new subs with XL2 1600 amp
This commonly happens when the ohm load is too low. Double-check the wiring to confirm that the speakers are wired properly.
Nov 19, 2007 | SPL Dynamics XL2-1600 Car Audio Amplifier
Car audio
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well. are you sure the cables are suitable for your amp?
Sep 11, 2007 | MTX RT202 Car Audio Amplifier
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
