Question about HP DeskJet F380 All-In-One Printer
Looking for 'U2'web site on internet - HP DeskJet F380 All-In-One Printer
Were did i get installer this printer bcoz the cd is broken?what site thanks
Posted on Jun 03, 2008
Problema con mi impresora codigo u2
Codigo de estado U2 / Sub Codigo 01 AVERIA DE LA MEMORIA
La PWB principal detectó una avería de la memoria
Codigo de estado U2 / Sub Codigo 02 AVERIA DE LA MEMORIA
La PWB (Placa de circuito impresa) principal detectó un error de acceso
Procedimiento para ambos casos
Realice el procedimiento de anulacion del codigo de estado U2:
  • Introduzca el código de diagnóstico 16.
  • Pulse Impresión.
Si todavia existe el problema , substituya la PWB principal.
Aug 20, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
I do not have a cd rom only usb so looking for software
If you have Internet access then you don't need a CD ROM drive.
You can download the printer driver from the printer manufacturer's WEB site. I cannot give you the link to the printer manufacturer's WEB site because you have not provided me with the make and model of your printer.
Feb 07, 2011 | Office Equipment & Supplies
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Xerox 5314 copier giving error code of u2
A U2 means the machine did not see the lamp scan. The lamp did not leave the right side of the machine. May be hung up on something, may have broken a cable the scan motor may be bad, I would first of all remove the glass and see if there is anything binding the lamp and keeping it from scanning. If you think it feels tight to move, that is normal on a 5314. What I am looking for is the lamp stopping not being able to move.
Mar 14, 2009 | Xerox Office Equipment & Supplies
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code U2 on a AR201 copier
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
U2-40 error etc.
U2 is a memory error. It's either the RAM or the ERPROM. A techincian has to look at it and determine which part it is and replace it. The copier won't run until it is fixed. It could be a loose memory board as well.
Sep 02, 2008 | Sharp AR-207 Copier
Sharp AR 5316 E photocopier error clearing
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
Jun 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
HP DeskJet F380 All-In-One Printer Logo
14 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
