Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Can't connect to configure password through web address 192.168.0.50
Dear Sir or Madam,
My friend gave me his D-Link DWL-2100AP, H/W Ver: A2 F/W Ver. 2.00. I reset the unit so it can go back to its default settings. I have a wired router in my office (NetGear) that I can connect this unit to one of the pc's that is not being used and then I can have internet access using 'default' network with my MacBook Pro. My problem is that i need to set up a password to give it some security because when this unit is plugged in, anyone can use it to access my other office computers and it could be disastrous.
I don't know how to connect it so i can access it's menu to configure. I tried directly connecting the unit to my pc and also directly connecting it to my Macbook Pro laptop. Of course, no luck. Any ideas would be greatly appreciated. Thanks.
i want to put security to my router
  • 3 more comments
  • Anonymous May 28, 2008
    Just set up wireless password for my D-link.. it was ok no prob. however, I can't log in to my router anymore = can't change password anymore
  • yoda000009 May 31, 2008
    a friend gave me this route and his son has the cd but cant find ,so what im wish to do is change the network name and make it a sercure network
  • bnartivor Oct 01, 2008
    D-LINK DWL-2100AP
  • troslett Dec 02, 2008
    Dear Sir or Madam,
  • Anonymous Feb 14, 2009
    I can't access Internet trough router
  • 667 Answers
Hi blanx - don't rate this yet. Are you just trying to access the D-Link to secure the network? Have you determined your setup and simply need to secure the D-Link? Thanks.
Jeff
Posted on May 21, 2008
2 Suggested Answers
  • 135 Answers
SOURCE: can't connect to configure password through web address 192.168.0.50
what you were missing is the fact that if you directly connect router to pc you will have to change ip on pc to match router i.e you are trying to connect to router through ip listed above then you should make ip on pc 192.168.0.***.
Posted on May 11, 2009
Wizard admin dap. i reset the dlink airplus xtreme g dwl 2100ap but i cannot get into it with the default ip that is 192.168.0.50
Connect your computer to the router.
Under Windows 7, click the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Enter 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Dec 11, 2013 | D-Link AirPlus Xtreme G DWL-2100AP...
How to set password
if your router doesn't have password yet, you need to get inside of the router configuration.
follow this steps. open an internet explorer at IE web browser type this default IP address,
192.168.0.1, then put this username ADMIN and leave the password blank.
when you get inside you can see the all configuration that you want.
note: the ip address that i give is the default ip. you cannot use this ip if your router is configuered already, unless you reset it.
hope it will help you.
Jan 13, 2011 | D-Link AirPlus Xtreme G DWL-2100AP...
Unable to connect D-link Air plus xtreme g wireless access point from pc for making configuration
Under Windows 7, press the "Start" button.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Jan 10, 2011 | D-Link AirPlus Xtreme G DWL-2100AP...
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
May 11, 2009 | Computers & Internet
Configure dwl-2100ap
yes you can do it put access point dricetly to the modem then you get it
Mar 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
I need help on how to use setup wizard
hat type of connection do you have? if you connect everything and put 192.168.0.1 in the address field in the browser you will be taken to the dlink router setup page. the default username is admin and the password is admin. from there you should see a setup link.
Oct 29, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Here is what you can do. You need to access the setup page of your Dlink Access Point.
1. connect a computer directly to the access point (via ethernet). Then assign an IP address on the computer (IP: 192.168.0.10 Subnet Mask 255.255.255.0 DG: 192.168.0.1 ). It is necessary for you to assign an IP address because your access point does not have the ability to assign an IP address to the a computer, its is not like a router.
2. After you assigned an IP address, you can now access the Dlink Access point's setup page. To do that open your browser in the address bar type http://192.168.0.50 (this is the address of your access piont) and it will ask you to put a username and password. Just type admin for both username and password field. And it will take you to the setup page of the access point.
3. To enable a wireless security, just click the tab on the left hand side that says Advanced, it will populate the options under Advanced and select security. On the main screen you will now have an option for security modem, you can select wpa-psk, then on the Key box you can type any password that you want (8-63 characters). Then click update there at the bottom of the page. If you also want to change the name that the Access point is broadcasting you can go to the on the left hand side that says Wireless and put any name that you want on the box that says SSID. After that click updat button again.
4. Now after updating the settings, You can reconnect to the network. And this time you will now be asked for the network key. Just type your network key. That's it.
Just reply to this post in case that you need more help.
May 20, 2008 | D-Link AirPlus Xtreme G DWL-2000AP...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
903 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
