Question about Philips 42PF9630A 42 in. Plasma Television
Blue Haze comes out the left side of screen top to bottom about 3 or 4 inches.
  • 36 Answers
What needs to happen is three specific voltages need to be adjusted on the power supply, You need to set the Ve voltage to 100v, the Vset voltage to 188V and the Vs voltage to 190v. Monitor the set for 24 hours, if haze doesn't come back the unit is considered repaired. If haze returns, then the problem is with the panel itself and wouldn't be worth it to replace because it will cost more than the tv cost you originally
Posted on Aug 19, 2008
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Mar 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv comes on for a few minutes then goes off
If you take off the front bottom panel of the tv wich is easy. Then you will see 6 tuning knobs at the bottom middle of the tv .the top 6 control contrast for the lights dont mess with those. the bottom 3 are the power to each light.red is bottom left if your screen went blue it makes sense that the red is starting to go but if you turn down the power to it left 1/8 turn it should fix it for awhile .Its easy.
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Blue haze on my plasma screen
I had the same problem, I had to send it back to Philips to get a $900 part replaced. Thankfully I had the warranty with it.
Aug 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
The driver boards on that side of the set need to be replaced, about $400 for parts.
Jul 02, 2008 | Samsung HP-T4254 42 in. Plasma Television
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
Blue "Haze" at top of screen
My VPL-HS51 just started doing the same thing. There's a lot of similar reports out there and they all end up at the same bottom line - the problem is due to a design defect in the 'prism block' (LCD panel) and the only option, other than to throw it away or sell it for parts, is to pay Sony about $2300.00 to fix it. Good luck!
Dec 18, 2007 | Sony Cineza VPL HS2 Multimedia Projector
Green dot in middile of my screen
The green dot in the center sounds like a burn mark on one or more of the picture tubes inside the set, and the curved lines are telling me that you have a problem in the convergence circuits. The blue haze around everything white tells me you either have a lot of dust build up on the lens over the CRTs, or your picture tube(s) are very weak. If this set is over about 12 years old, I would replace it. I doubt if you will be able to get the green dot out of the picture without changing the tubes which would be VERY expensive.
Jan 05, 2007 | Philips 60PP9401 60" Rear Projection...
Philips 42PF9630A 42 in. Plasma Television Logo
195 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
