Question about Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator
Vegetable crisper drawer problem with food freezing
All of my vegetables in the crisper drawer are iceing up. The Refrigerator is set at 5. Should I lower it to 3?
  • 3 more comments
  • elgen Jun 01, 2008
    crisper on left side off refrigerator freezes vegetables, crisper on right side is fine
  • Anonymous Jan 03, 2009
    WTF
  • crisper Apr 11, 2009
    My setting at 3 with the same problem; however wouldn't you want to go UP to 5 for a HIGHER/WARMER temp..since going down in my refrigerator 3-0 is the colder setting? Wasn't sure if 5 would be cold enough for the shelf food.
  • Anonymous Mar 23, 2014
    how to put back the plastic top of the crisper drawer after cleaning
  • Anonymous Mar 25, 2014
    bottom crisper drawer will not come out. Seems to be stuck on the left front
  • 828 Answers
Absolutely lower the setting.
Posted on May 21, 2008
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
Vegetable drawer freezes items
Adjust your thermostat / temperature setting to a warmer temperature.
You could also have a lot of food placed in front of the vent in the top of the refrigerator compartment. Tall jugs (like milk jugs) are usual culprits of this one. Cold air is deflected in other direction, it might be going straight to the crisper rather than diffusing first.
Jan 04, 2010 | Jenn-Air JCD2389G Side by Side...
Bosch Refrigerator ice forming in vegetable drawer
Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Amana Bx22s5W freezes food in the crispers
I've had the same issue with an Amana BX21TL. In my case, the problem was that the various air flow adjustments were all directing the cold air to the bottom of the fridge, underneath the vegetable crispers.
What I've done to fix this was:
1- Made sure there was a tight seal between the vent opening at the back of the fridge (at about mid-height) and the rubber/plastic duct that directs air to the meat/cheese drawer.
2- Made sure that the adjustable opening at the back of the meat/cheese drawer was fully open.
3- Made sure that the adjustable opening at the back of both vegetable crispers were fully open.
Hope this helps.
Jan 25, 2009 | Amana Refrigerators
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Jan 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Bottom Door Shelves and Vegetable Crispers Freezing up
I just had a similar problem, and the bottoms of both sides were cold but the top shelves were warm. I found that the condenser fan, the fan right above the cooling coils was not working. This fan circulates the cold air and if it's not working it can't move the cold air to the top or over to the refrigerator side. Open the freezer door and press the switch that tells the computer the door is closed (so the light goes out), if the fan doesn't come on shortly, or only sputters that could be the problem. You will need to take out the back cover over the coils, the ice maker tray and auger motor if you have one and some other parts. Play around with the plug where it goes into the side wall, if you can get the fan to come on and off, it's most likely a bad fan motor....about $55 to replace. As you take it apart, be sure to take some digital pics of the process so you can remember how it goes back together!
Jan 12, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Vegetable draw is freezing the vegetables
if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hotpoint HTS20GCNWW / HTS20GCNCC Top Freezer Refrigerator Logo
3,305 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
