Question about GE Spacemaker JVM1640SJ Microwave Oven
BROKEN GLASS COVER UNDER NIGHT LIGHT
LEFT THE NIGHT LIGHT ON OVERNIGHT AND IN MORNING FOUND THE GLASS COVER SHATTERED ---LOOKS LIKE BULB OVERHEATED AND CAUSED GLASS COVER TO BREAK. IS IT SAFE TO REPLACE BULB AND BROKEN GLASS OR COULD THERE BE A MORE SERIOUS PROBLEM??
SAME PROBLEM FOR ME...I REMOVED THE BOTTOM COVER AND FOUND THAT ONE LIGHT WAS NOT FIXED AND WAS LOOSE AND WAS TOUCHING THE GLASS. THIS HEAT WAS WHAT BROKE THE GLASS COVER. CLOSED INSPECTION SHOWED THE LIGHT SOCKET WAS TOO LARGE FOR THE CLIPS AND WERE NOT SECURED WHEN PURCHASED. I GOT SMALL SCREW AND NUT, BENT CLIPS SO THE SOCKET HOLE MATCHED THE HOLE MADE BY THE CLIP AND SECURELY ATTACHED THE SOCKET. THIS WILL SECURE THE LIGHT AND KEEP IT FROM TOUCHING THE GLASS..........IF I CAN EVER FIND A GLASS REPLACEMENT....MAY JUST HAVE ONE CUT. NOW THE PROBLEM IS TO REPLACE THE LIGHT AND MICROWAVE FUSE WHICH WAS BLOWN WHEN THE GLASS BROKE.
Posted on Mar 07, 2010
    Genius:
  • GE Master
  • 1,635 Answers
I would take the oven to the GE service rep and find out exactly what happened. This does not sound right!
Jerry G.
Posted on May 21, 2008
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Light bulbs in built in microwave have come apart when we tried to unscrew them for replacement. How can we get the broken end of the light bulb out of the sockets?
Most Samsung microwaves use a bulb and bracket assembly that is meant to be replaced as a unit, not disassembled (see image). If the bulb base was secured using epoxy or some other means, it may not be possible to remove without damaging the bracket.
That said, you can try traditional methods for removing broken light bulb bases. Remember to always unplug the fixture/appliance, or shut off and mark the breaker serving it, before working.
A cut potato or carrot can sometimes be pushed onto the broken glass left in the base, to provide a handle for unscrewing the base. On smaller bulbs, I have successfully used the eraser on the end of a pencil.
If the bulb was really stubborn, I would probably try filling the base with a hot glue gun, then pushing a screwdriver into the soft glue. Once the glue hardens, turning the screwdriver should unscrew the bulb base (if it is at all possible).
As you may have discovered, pliers and the like tend to just break off small pieces of the broken glass bulb.
Jul 13, 2011 | Samsung Microwave Ovens
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I WAS UNDER THE ASSUMPTION THE GLASS TURNTABLE WAS TEMPERED GLASS, 2 MINS IN A COOKING PROCESS IT SHATTERED. THE MODLE IS MW8115SS
Even tempered glass can shatter. It could have been a factory defect, or a small crack that had gone unnoticed until now. The glass is supposed to be durable, but it does happen from time to time. I found a replacement tray at repairclinic.com for $42. You can search by your model number or use item number 1174113. This was the only site that I could fins that carried the part for your oven. I hope this is helpful to you.
Sep 10, 2009 | Microwave Ovens
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Jun 26, 2009 | GE Microwave Ovens
Shattered inside door glass on Sharp model R1870
It must be tempered glass and I would suggest using only the correct replacement.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the
free Adobe Reader to view or print them.
The manuals have exploded views, part numbers, and disassembly info.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Dec 30, 2008 | Sharp R-1480 Microwave Oven
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Bulb replacement
NO,If you can get to the three phillips screws directly over the vent door then you do not have to take the unit down. Unplug the unit. Remove the top three screws over the center of the louvre and then carefully lower the vent louvre. (Lowering helps me get a better grip on the louvre assembly. Then you will slide the vent louvre assembly about 1/8" to the left and then it will pull straight back and out. In the center is an aluminum cover which has a phillips screw facing you. Remove this screw and the cover plate. The light bulb is directly to the left of the inside of the cover plate. You will see the metal tabs which hold it in place. Pull the bulb housing assembly straight out (to your right) as you face the microwave. Then you will locate your halogen 120V 20W bulb. I just received this from a fellow guest on fix it and I was able to fix my unit 10 mintes ago.Also another tip was to take the inside glass out when reinserting the bulb unit back in because it does get in the way. Good Luck
Aug 08, 2007 | GE JVM3670 Microwave Oven
Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Aug 06, 2007 | GE XL1800 1100 Watts Microwave Oven
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
May 03, 2007 | GE Advantium SCA1001SS Convection /...
GE Spacemaker JVM1640SJ Microwave Oven Logo
353 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
