ACER I HAVE AN ACER LAPTOP AND COUPLE MONTS AGO THE IMMAGE STARED FADING AT TIMES, USED TO COME BACK AFTER MOVING THE LCD UP OR DOWN , NOE TURNED BLUE AND THE IMAGE IS NOT SHOWING ... ANY THOUGHTS
  • 50 Answers
The screen cable has come loose just needs pushed back in look up how to take the case apart (the screen and above the keyboard is usually all you need) locate the cable and push it in all the way if it is a plug then usnplug it and plug it back in on both ends. Put it back together enough to power it up and see if it worked.
Posted on May 21, 2008
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
I bought this computer a couple of months ago and have used it about 3 times. When I turned it on, there was no power and it was fully charged before I went offline the last time. Now my battery icon...
Then, it should be FULLY covered under WARRANTY, either from the store from where you bought it, or from ACER.
> new battery from COSTCO
It's probably 100% fine; it's your laptop that is the problem.
Exercise the WARRANTY to get the laptop repaired/replaced, at NO COST to you.
Jul 25, 2011 | Computers & Internet
Blue Screen
please remove battery and ac-power for a couple of minutes and then try to reboot the computer.
if it still doesnt work, shut it down, remove battery and ac.
remove ram
connect ac-power
try to boot without ram
remove ac power
insert ram
insert battery
connect ac and try to boot again.
when the blue screen appear, please write down the top line that looks something similar to this:
IRQL_LESS_OR_NOT_EQUAL_ETC_ETC
and the line close to the bottom that says
STOP: 0x000021 (0x000+++alot of not needed numbers)
when you have done that please come back to me.
May 29, 2009 | Acer Aspire 4520-5141 Notebook
My Acer laptop just crashes randomly..i used to have vista, but once it started to crash on vista i installed XP thinking it would stop the crashes....it didnt. now i cant install Vista for some reason.....
Acer usually has a hidden partition which allows you to reinstall the OS back to factory setting.When you boot hold down the ALT + F10 button and it should boot into the recovery disk
Apr 27, 2009 | Acer Aspire 5610-4648 Notebook
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Tv powers off and on after operating for about 1 hour
Same happened to me with my old panasonic set. It was a dry-joint. You can try re-soldering the circuit.
Good Luck.
P.S. - Check the Power Suply area closely.
Feb 20, 2009 | Hitachi 60VX915 Rear Projection Television
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Connecting an external monitor to acer 5720
I have had this before with my Dell Latitude C540/640. I don't know the ACER 5720 but here's a couple possible fixes for you.
1. Press the function key ( "fn" key, generally a blue key or blue lettering and usually in the bottom left corner of your keyboard) and press F8 (may be a different key on your laptop, again, not familure with the acer. The key usually has either CRT/LCD printed on it, or two monitors on it, one its just an outline of a monitor and the other is filled in. This will run you laptop through the three monitor options it has. (LCD - LCD & External - Just External)
2. Try closing and opening the lid of your laptop. Sounds a bit strange but it works sometimes for me. My guess is when you close you screen it would "dim/turn off" the LCD and re-opening it convinces it to turn the screen back on.
Hope this helps!
-David-
Jan 09, 2009 | Acer Aspire 5720 Notebook
Don´t star my Asus P5S800-VM
Try this
Remove side of case and check that everything is set in properly
Probably with moving it around and the final bump has loosened something
CPU. Video card. Memory ETC
Aug 22, 2008 | ASUS P5S800-VM Motherboard
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
