I HAVE A lINKSYS nh 100R 5 PORT NETWORK HUB THAT I WAS RUNNING 2 COMPUTERS. i GOT A LAPTOP AND WHEN I TRIED TO CONNECT IT WOULD NOT CONECT. THE CABLE COMPANY SAID TO RESET THE CABLE MODEN AND IT WOULD FIX THE PROBLEM, WHICH IT DID NOT. WHEN I RESET IT, NONE OF THE COMPUTERS WOULD CONNECT. I NOW HAVE 1 CONNECTED. I DONT HAVE THE MANUAL. PLEASE HELP
    Champion:
    Scholar:
  • 209 Answers
Since you have one computer connected, try to go to linksys website. I think it is a problem with your IP adresses. If you connected your laptop and it is using the IP adress of one of the two computers, and you turn on one of your desktop, Maybe, there is one IP adress reserved and there is a conflict.
Only an hypothese...
Posted on May 23, 2008
Linksys SD216 isn't working when different laptops are connected
Sounds like either a bad cord or a bad port. have you tried to replace ethernet cable or plugging it into another port.
Feb 24, 2014 | Linksys SD216 16-PORT 10/100 DESKTOP...
I have a Linksys 5-port switch connected to a cox cable modem and I'm trying to use it to connect two computers at the same time. Only one works at a time and I have to reset the switch and modem to get...
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Aug 27, 2010 | Linksys EZXS55W EtherFast 10/100 5-Port...
5 port network hub
Connect the power supply.
connect the ethernet cable from your router (or the box that your isp gave you to get the internet connection) to the port labeled "Uplink" on the hub.
Connect the ethernet cable from your computer or another device to be connected to any of the ports 1 to 4. Do not use port 5 (that port is used to "chain" another hub)
Please be aware that a network hub is basically a very simple device that will not assign an internal ip number to your devices or computer, and if you have two or more devices or computers, you do need that either your "modem" (the device that is installed by your isp) is capable of handling more than one computer, or you will also need something to act as a router (your computer can do it, but you will need to know how to set up that).
Hope it helps
May 14, 2010 | Linksys (NH1005) 5x10/100 Mbps Networking...
When I plug a cable into port 8 it will shutdown the switch
Your router supports a total of 8 connections. However, on the back there are 9 physical ports. Port 8 has two physical connectors where one (we will call it port 8a) is used to connect to a PC and the other (we will call that port 8b) is used as an uplink port. The uplink port (8b) cannot be used if something is pluged into 8a. If you are trying to use all 9 physical ports that is likely ther problem. If you need more than 8 devices connected to your switch get another 8 port switch (any brand will do) and connect the two switches via the UPLINK port with a 7 foot CAT-5 cable. Do not use a CAT-5 patch cable less then 7 feet long to connect two network devices together such as computer to switch or switch to switch as that will probably cause another problem with timing.
Another possibility is that the device at the end of port 8 has a malfunctioning network adapter. Try connecting a laptop to port 8a using a 7' CAT-5 cable. You may also want to try pluging the problem cable into another port as a way to test if the problem is somewhere along the cable run.
Oct 29, 2009 | Linksys EtherFast EZXS88W (DSLSEZXS88W)...
Want to have wireless with my Limksys Sr2016 switch
Go to: www.speedtest.net with a laptop on your network.
Find your speed. now repeat on same laptop plugged directly into the cable madem.
Do the settingsa change much?
If so, your network is at fault. If not, Comcast is lying to you.
May 12, 2009 | Linksys SR2016 16x1000 Mbps Networking...
How do I connect a LInksys NH1005 hub to a wireless router? Do I have to connect directly to the dsl modem first? change the ip address and then connect the router?
If you have a port in the back of the wireless router open which you should just run a CAT 5 (network cable) from the back of it to the Linksys hub. That should do it. This way the wireless router won't have to be messed with and you shouldn't have to change a thing.
Feb 28, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Slow internet.
Your hub can support more that fiber optic puts out. Problem might be a slow computer. Run a internet speed test see what it gets through hub and then straight to the computer bypassing the hub. If possible. If there is a big difference either way what ever is slower is most likley the issue.
Feb 22, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Lost connection between switch and hub - LED flashes every 5 secs
You say you have the same problem when you connect the cable directly from router to laptop, so it apparently is not a hub problem. That leaves the router and the cable. You're fortunate in having a working system on the other port. Why not try swapping pieces to see which is the failed piece? For example, what if you swap the ports for the cables? If it's a router problem, then the "bad" cable should work when in the other port. What if you swap cables? That would reveal a bad cable. Finally, swapping computers would show a computer configuration problem, such as the connection not being set to automatic.
Jan 23, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Switching from Linksys 5 port switch to Netgear 8 Port Gigabit
Kindly check the Gateway used in the computer where internet is working.....
to find gateway follow this
start menu >>> RUN>> CMD>>>> Ipconfig
then configure this gateway in all other systems and ask for DNS from you isp as well..to provide DNS manulay.
If still dont work ...
tell me the all information you get by useing ipconfig command in the PC where internet is working.
like IP address
Gateway
DNS
i will make you a map to follow.
best regards,
Dec 02, 2008 | NetGear ProSafe GS108 8-Port Gigabit...
Migrating from two netgear hubs to 3Com Baseline swithch:
to connect 2 computers without a hub/switch you need to have a cross-over cable. Normally a network cable only uses pins 1, 2, 3 and 4 with pairs 1,2 and 3, 6 on both ends. A x-over swaps the pairs on one end.
Go to a computer store near you and ask for one. Don't pay more than $10.
If you can't find one or it is expensive, let me know and I'll make an adapter for you and just charge around $5 for the parts and shipping. My email is fixya@pcsports.org and put "X-over Cable" as the subject.
Jeff
Feb 07, 2008 | Computers & Internet
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
