Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Machine error 76 for brother fax 4750 - Brother IntelliFAX 4750 Plain Paper Laser Fax
    Problem Solver:
  • 13 Answers
The error is related to the fuser assembly overheating. The only course of action you could take would be to turn off the machine for an hour or so to give the memory time to reset. If that does not resolve the problem, then the fuser assembly needs replacement (Part# LJ7759001). This should be replace by a certified tech.
Hope this helps!
Posted on May 21, 2008
2 Suggested Answers
  • 47 Answers
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
Error 76
try this- press the "menu/set" button, then " *2864 " . the *2864 you have to enter within a 2 second window, so you may have to try this more than once. when you hear a long beep, you got it. press "91". you should see "parameter init" on screen. wait for that message to disappear. unplug machine at this point, wait 5 seconds and plug back in. if it comes up with that error again, then you truly have a problem with your fusing unit and will have to have repaired. sometimes though, this error can be caused just by a power outage or fluctuation. if thats the case it should come back up to normal after you successfully do this procedure.
good luck
razors
Sep 21, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
My Brother 4750e promted: Machine Erroe 71 unplug machine and call service
that error code points to your laser unit and unfortunately for you will require a tech.
razors
Mar 28, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Machine error 78 offline
You have a bad FUSER. There's nothing you can do. A dealer must replace the fuser.
Jun 26, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Apr 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Laser fax 4750
look in back of the fax, it probably has a parralel plug, if yes just plug in and voila( may have to download driver from brother)
Jan 22, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother 4750 fuser replacement
The entire front, sides, and rear cover is all one piece. Take the screws out and lift straight up.
Dec 14, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
2,282 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
