Question about Cameras
New kodak digital camera problems
I have a new kodak eashshare m763 digital camera. i bought it about a month ago. it was working fine until about two weeks ago. my camera stopped responding to computers and my charager. today i bought a new recharagable battery. it works fine but its not charaging. i tried to hook up my camera to three different computers and none responded to it. any ideas on what the problem may be?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey hashbrownz,
What it sounds like to me is the drivers required for the camera to communicate with your computer have either been deleted or corrupted. I would try reinstalling the software that came with the camera, and I have provided a link below from the manufacturer on how to troubleshoot this problem. I hope this helps!
http://www.kodak.com/global/en/service/publications/urg00810toc.jhtml?chapsec=urg00810c6s2&pq-path=12693
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 27, 2008
My cam doesnt switch on
i there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
May 13, 2010 | Kodak EASYSHARE M763 Digital Camera
Hi i have a problem with my digital camera kodak m763
There is nothing you can do to change the quality of the picture you have already taken. But for future pictures please change the resolution within Menu, Camera Settings, picture Quality (it shows stars)
Jan 02, 2010 | Kodak EASYSHARE M763 Digital Camera
My Kodak M763 camera won't turn on, ( It is not the battery because I bought a new one)When I press the on button, It looks like is going to start, but it turns off again.
If the camera has recently been dropped you may have lens damage which is preventing it from powering up. If it hasn't been dropped, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Dec 04, 2009 | Kodak EASYSHARE M763 Digital Camera
I have a Kodak M763. The camara don't want to turn on. Don't work
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Kodak EASYSHARE M763 Digital Camera
My camera worked perfectly fine until the battery went dead. it wasnt the original battery that came with the camera and i charged it with the charger that did come with the camera so i thought the charger...
your battery area is infected with the chemicakl that is leaked from your old battery.
get it cleaned by an expert with chemical treatment.
also fornat your emory after cleaning
sagar
Jul 29, 2009 | Kodak EASYSHARE M763 Digital Camera
My kodak c813 digital camera will not turn on
I bought this model several months ago and it was working great up until Christmas time.  For some reason it just stopped working.  I couldn't get it to turn on OR sometimes it would turn on after several attempts.  I kept changing the batteries and sometimes that would work, but it was more or less random successes.  I found this link on FixYa : http://wwwuk.kodak.com/global/en/service/batteries/batteryDigCamChart.jhtml?camera=C813
I was using generic batteries (Philips) which I bought in bulk from a discount tech store and these batteries were working in the camera since I bought it.  The batteries were new; just generic.  By coincidence I ended up buying KODAK branded alkaline batteries from the same store.  I replaced the older generic ones with the KODAK batteries and the camera came back to life!  I'll leave it off for a day and see if it turns on tomorrow.
Dec 28, 2008 | Kodak EasyShare C743 Digital Camera
Kodak Easy Share M763 Won't turn on!!
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Sep 02, 2008 | Kodak EasyShare C533 Digital Camera
Cameras Logo
71 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
