Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Service Menu Code
Hi, avid_imps, you seem to be an expert in all things Philips/Magnavox. I saw you were able to supply the service menu code for another user's Magnavox television. Do you happen to know the one for this yet?
My remote control doesn't have MENU, STATUS, or INFO buttons. I did a bit of research and found that one of the ways to enter the service menu was to use a combination of numbers and those buttons.
The one you suggested for another user: ON, OFF, 2, 7, 1, MUTE didn't work for me either. Is there potentially another code I can try? My television desperately need adjusted. Brown colors show up as purple splotches.
Thank you for your time.
  • 1 more comment
  • Biggiesized May 21, 2008
    So, if I am to understand this correctly, I have to modify my remote control (the one that comes with the television set)? Will this damage the remote in such a way that it will no longer function as normal?
    You've been incredibly helpful thus far.
    Also, the purple splotch is actually only problematic in one area of the CRT, the lower left corner. Is there something that can be used to fix it, like a magnet (just throwing that out there--I'm no electrical engineer)?
  • Biggiesized May 23, 2008
    Why would I want to de-gauss the set? Wouldn't that only fix the magnetic problem temporarily? Is there a more permanent solution to the problem?
    Also, how would I short circuit pins 10 and 17 (theoretically). What tools would I need? A regular piece of wire? How do I get a current running?
  • 476 Answers
Its unlikely that the purple splotches can be cured from the service menu.
Assuming your TV is the Magnavox 20MC4304 combi, then the tv does not have a service code. There is an alternative though.
Details can be found in the service manual:
https://www.p4c.philips.com/cgi-bin/dcbint/sget?url=/mprdata/051111/0511110565_sma.zip&ofn=20mc4304_17.zip
Posted on May 21, 2008
  • David Simpson May 22, 2008
    The "splodge" is most likely to be caused by a magnetic field close to that area, such as a speaker or transformer.
    The only thing that might be worth checking internally, is the de-gaussing circuit. This is a wire that runs around the back of the tube in a loop, and is plugged into the main board. It is usually held in place by a spring in each corner.
    Follow the wire and check the connection to the main board.
    DISCONNECT THE MAINS POWER AND TAKE GREAT CARE IF YOU REMOVE THE BACK OF THE TV.
    IF IN DOUBT, DO NOT REMOVE THE BACK COVER.
    I have never tried the remote conversion, so I cannot advise on this.
  • David Simpson May 23, 2008
    The de-gaussing circuit works every time the tv is turned on. If it's not working, then any magnetic interference caused by, say, a speaker near the disturbance, would never be fixed.
    As for shorting the pins, you can use a thin piece of wire, preferably insulated, so as not to touch anything else.
How to reset access code on magnavox 20ms233s
Hi. It's really necessary to have the original remote. All so called replacment do not have the "menu" button. In Philips TV's access code is not rquired. In your case, some channels are "whiped" and cannot be recalled. If you can go into setup-menu, things can be rearranged. There are numerous web-shops where you can buy an orignal remote. I recently bought an original remote for my DVD player. This however was at an on-line shop in Belgium. Just surch for Pilips on line shops in your country. Good luck.
Sep 10, 2014 | Philips Magnavox 20MT133S 20" TV
I Need The region Free to DVD Player Magnavox MWD200F
if you looking for that code thing...
it's Code = 0247
Aug 13, 2008 | Philips Magnavox DVD Player MWD200F
Service menu code for philips 29pt6807 tv remote -rcla021 type
kinly send remote code for philips vaardaman model
Jul 15, 2008 | Televison & Video
Phillips magnavox big screen
That is the service menu code. I forgot the code but you can search it on this sit jou will find it. But be cearfull jou can damage your set.
Apr 05, 2008 | Philips Magnavox 9P6034C 60" Rear...
Child Locked TV and Remote
Press MENU to show the on-screen
menu.
Press VOL+ or VOL- to highlight SET.
Press CH+ or CH- to highlight
PARENTAL CONTROL.
Press VOL+ or VOL- to display the
SECRET CODE
screen.
Press VOL+ (on the remote) and the
CH+ button on the front of the TV
at the same time.
Press the Number buttons to
enter a four-digit code. The code will
appear on the screen as you enter it.
The code "0000" is the default of the
TV. If you have not set up a code previously,
then "0000" is the code.You cannot
use "0000" after you set your own
code (unless you reset the code to
"0000").
Press MENU to save the code.
Hope this helps. :}
HERE IS A LINK TO THE USER MANUAL:
http://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
Mar 31, 2008 | Philips Magnavox 27MS343S 27" TV
Magnavox MT1340B Service menu
Try:
0 6 2 5 9 6 i
Where i is the i+ or info button.
Mar 14, 2008 | Philips Magnavox MT1340B 13" TV
Need the codes to enter the service menu
First, you will need to fix the convergence problem by replacing
the convergence IC's,then activate auto focus and last,if necessary, enter the servicer mode................T.
Nov 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
I do not have the code for my Phillips-Magnavox 27" Tv and it will not come on
generally philips code is press 0 6 2 5 9 6 followed by MENU BUTTON
Sep 18, 2007 | Philips Magnavox 27MS343S 27" TV
Vert adjustment
To enter the service menu (use the button on the set)turn on the tv, then turn it off, using remote enter 2, 7, 1, then mute with in 5 seconds. Then press 9 and select V-S, display chnages from V-S and V-P. Then use channel up and down to adjust. When down use the power on the set to turn it off.
Apr 11, 2007 | Philips Magnavox 20MS233S 20" TV
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
530 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
